Introducing KOWA Factory – DJ Fork Kowa and Nemesis Project
News
Folsom, California- Kowa is proud to announce the release of their new Kowa Factory brand; a collaborative effort with Nemesis Project Cycles. Kowa and Nemesis Project have each developed legendary reputations for their suspension products, with Nemesis Project’s aftermarket suspension tuning parts regarded as the best in the business, and Kowa’s forks earning several top ten World Cup downhill finishes. The first product to be released by Kowa Factory is the Dirt Jump fork, developed to address the needs of riders looking for a durable, high performance fork purpose built for aggressive use. The goal was to incorporate Kowa’s proven chassis with the high performance damping which has made Nemesis Project’s tuning products famous. This yields a fork durable enough for abusive riding and which performs properly without the need for extensive aftermarket tuning. The Dirt Jump fork features fully Kashima coated dampers for reduced friction, oversized 36mm stanchions, a 20mm through axle and a CNC’d crown; all designed to produce a fork with unrivaled stiffness, durability and performance.
Specs:
$599.99 SRP
5.6lbs
65mm travel
480mm axle to crown
CNC’d upper crown
36mm stanchion
Coil spring
20mm axle
source: Brad Hodges
Wordpress Comments:
