Jagwire Hydraulic Hose Cutter, Needle Driver and Brake Bleed Kits
Brakes Components Video
James from Jagwire shows us a couple of new tools and brake maintenance kits. Jagwire isn’t just colorful cables any more! Highlighted here are the Jagwire Hydraulic Hose Cutters, Needle Driver and two brake bleed kits.
Cutting hydraulic hose with a straight, clean cut is an important part of properly installing any hydraulic hose. Space Age cutters make it easy to cut hose like pro mechanics. The Space Age Pro is a shop-grade hydraulic hose cutter and the Space Age 2.0 is a home mechanic hydraulic hose cutter.
Needle Driver
Installing hydraulic hose fittings shouldn’t be done using a hammer. The delicate brass fittings can easily be crimped or not installed completely, both of which can lead to poor brake performance. The Needle Driver is a simple-to-use tool that secures the end of a hydraulic hose and allows for smooth and gentle installation of hose fittings. No kinked hoses or damaged fittings!
Bleed Kit
Squeeze-bottle design compatible with open-bath systems from Shimano and Magura.
DOT Fluid Bleed Kit for:
  • Avid
  • Formula
  • Hayes
  • Hope
Mineral Oil Bleed Kit for:
  • Shimano
  • Magura
  • Tektro
  • Giant Brakes
For more info: jagwireusa.com
About the author: Gregg Kato
Gregg Kato studied journalism and broadcasting in college while working many different jobs including deejaying, driving a forklift and building web sites (not all at the same time). Kato enjoys riding local Santa Cruz trails. Besides being an avid mountain biker, he is also a motorcycle fanatic. Two wheels, one Passion.
