Australian-based JetBlack Cycling hits 2015 with a new mobile training app and updated stationary trainers.
Video: New 2015 Whisper Drive trainer, Z1 Pro Fluid trainer and new mobile training app
Mike Ely of JetBlack Cycling introduces two new trainers for 2015 and walks us through the benefits of their just-launched iOS and Android-compatible mobile app.
see more photos »
JetBlack is releasing a brand new iOS and Android-compatible mobile training app designed to work with any Bluetooth or Amp+ compatible device. When connected to a compatible device, the app is capable of providing real-time information on heart rate, speed, cadence and power. The app comes programmed with several different training sessions designed by an Olympic-level coach.
Previously the Z1 Fluid trainer, the new Z1 Pro Fluid trainer has been upgraded for 2015 with improvements including a stock flywheel that has increased in size from 2.2lbs to 6.6 lbs. JetBlack tells us amping up the flywheel size results in better on-road feel as well as significantly longer coast down times. The trainer now features hydrogel rollers as well as a patented quick release system which is thru-axle compatible and adjustable from either side of the trainer. Available Fall 2014.
The new Whisper Drive trainer is a direct-drive wheel-off trainer. Compatible with 130mm and 135mm thru axles, the Whisper Drive was designed to center the rider's mass directly over the unit, producing a more stable ride for out-of-the-saddle sprints and climbs. Compatible with their new mobile app, the Whisper Drive will be available in Fall 2014.
Gallery: JetBlack Whisper Drive trainer, Z1 Pro Fluid trainer and new mobile training app
[slider_pro id="1"]
For more info visit www.jetblackproducts.com
see more photos »
[slider_pro id="1"]
