Today Crank Brothers introduced a set of pumps, tools and inflators. The highlight of the line is the Sterling series which feature high quality, polished aluminum pumps for road and mountain biking use. The pumps feature a new universal head, a bigger guage on some models and their familiar high/low volume adjust function.
The Gem series of pumps are more affordable but feature the same head and volume adjust knob. And finally the B-series tools features a bit-based system where bits a placed in a socket for maximum versatility and leverage.
Francis discusses and tries out some of the new pumps and tools
Sterling Pumps
Sterling is the new premium pump collection from crankbrothers. The high polished CNC and laser etched aluminum outer body results in a stunning proprietary design. A universal head works with both schrader or presta valves without adapting the head. To make them even easier to use, the sterling pumps feature a high/low volume function that allows you to adjust for high volume or high pressure. To top it off, the oversized gauge results in accurate pressure control and easy readability. There are four models of sterling pumps in two lengths (short or long), either with or without a gauge.
Sterling LG
- Weight: 173g
- Length: 276mm
- Material: 6061 aluminum
- Pressure: 100+psi / 7+bar
- Air switch: high volume / high pressure
- Gauge:100 psi
- Warranty: 5 years
- Msrp: $50.00 / €50.00
- Weight: 141g
- Length: 198mm
- Gauge: 100 psi
- Warranty: 5 years
- Msrp: $45.00 / €45.00
- Weight: 143g
- Length: 250mm
- Warranty: 5 years
- Msrp: $40.00 / €40.00
- Weight: 116g
- Length: 171mm
- Warranty: 5 years
- Msrp: $35.00 / €35.00
Sterling CO2
To complete the sterling premium inflation line, crankbrothers introduces a co2 inflator and cartridge. The inflator features push spring air control and integrated frost guards that provide hand protection from cold co2 cartridges. The inflator includes two sterling co2 cartridges (16g threaded), which are also available individually.
Sterling CO2
- Weight: 45g
- Body: diecast zinc, tpr cover
- Compatiblilty: threaded 12g, 16g, 20g
- Warranty: 5 years
- Msrp (sold w/ 2 cartridges): $20.00 / €20.00
Sterling CO2 Cartridge
- Weight: 63g
- Msrp: singles $3
Gem Pumps
With their eye catching colors, ease of use, and affordable pricing, the gem pumps are a perfect option for any rider. The reversible internal head easily adapts to fit schrader or presta valves, and the gem pumps include the same high/low volume function as the sterling pump collection. Available in two length options, the gem s is a shorter, more compact pump, and the gem l is longer for higher volume.
Gem L
- Weight: 155g
- Length: 205mm
- Material: 6061-T6 aluminum
- Pressure: 115psi / 8bar
- Color: red, green, silver
- Warranty: lifetime
- Msrp: $27.00 / €27.00
- Weight: 128g
- Length: 176mm
- Msrp: $22.00 / €22.00
Looks like the gage is on the wrong side? How can I pump and look at pressure if gage is on wrong side??
Troy, turn your wheel so the stem is at the top, pointing down, instead of the bottom and the gauge will be on the right side to pump and watch pressure.
