Just In: crankbrothers Sterling and Gem Pumps, B-Series Tools
Gear
B-Series Tools
The b-series tools are the latest addition to the crankbrothers collection of multi-tools. This bit based tool system includes a magnetized bit socket that helps keep the bit firmly in place as you work. The bit holder stays closed, so you don’t need to worry about bits falling out and getting lost in your pack. You can even customize your tool based on your needs by simply swapping out bits. The bits are a standard size that can be purchased at any hardware store. The b-series collection of tools includes three models, each with a different set of tools in two size options.
B17
  • Weight: 230g
  • Sidebars: stainless steel
  • Tool Bits: stainless steel, 25mm long
  • Chain Tool: #0, #1 spoke wrenches
  • Hex Bits: 1.5, 2, 2.5, 3, 4, 5, 6, 8
  • Screwdrivers:1-phillips, 2-phillips, 1-flat head, 2-flat head
  • Torx: t-10, t-25
  • Warranty: 5 years
  • Msrp: $33 / €33
B14
  • Weight: 206g
  • Tool Bits: stainless steel, 30mm long
  • Screwdrivers: 1-phillips, 2-phillips, 1-flat head, 2-flat head
  • Torx: t-10, t-25
  • Warranty: 5 years
  • Msrp: $27 / €27
B8
  • Weight: 144g
  • Hex Bits: 2.5, 3, 4, 5, 6
  • Screwdrivers: 1-phillips, 1-flat head
  • Torx: t-25
  • Warranty: 5 years
  • Msrp: $20 / €20
Speedier Lever
  • Weight: 26 g
  • Length: 144 mm
  • Material: nylon
  • Warranty: lifetime
  • Msrp: $7.00 / €7.00
For more info visit crankbrothers.com
Wordpress Comments:
  • Troy says:
    Looks like the gage is on the wrong side? How can I pump and look at pressure if gage is on wrong side??
  • Roger says:
    Troy, turn your wheel so the stem is at the top, pointing down, instead of the bottom and the gauge will be on the right side to pump and watch pressure. ;)
  • MissedThePoint says:
    CB’s method of doing things differently is taking a turn to fashion, rather than engineering. I guess that’s one possible way to try and save CB’s ship from sinking.
