The Lefty Supermax fork is touted as one of the best All Mountain forks in existence today. But many of us have bikes other than a Cannondale so the incompatible mounting interface of the Lefty fork has made it impossible to try this fork on our bikes.
Enter Jake Liles of Project 321. Currently based in Fresno, CA, he has used his machining prowess to manufacture conversion kits for the Lefty fork or even the Cannondale Hollowgram crank. He provides sound engineering solutions to fit these components into your existing bike. These adaptor kits are well-designed and finely crafted to provide years of trouble-free performance.
In addition, to adaptor kits, he also manufactures other components. Read on and see some his toys.
Lefty with Enve wheel and Project 321 hubs and a close-up of the Lefty. (click to enlarge)
Project 321 Lefty Supermax adapter
Carbon Lefty Supermax 160mm
Why ride a Lefty?
Perhaps the most distinctive and divisive fork in the market is the single-sided Lefty suspension fork. The latest version dubbed features an inverted 36mm stanchion sliding within a 46mm outer leg the has proven to to be incredibly strong and laterally stiff.
The four-pound, 140mm or 160mm travel fork glides on a set of needle bearings for a smooth, stiction-free action even under high braking and cornering loads. The fork features the Pop Loc soft lockout is mounted on the top of the leg as it was on prior models. Despite looking like half a fork, the Lefty Supermax is one the most accurate steering forks in the market today.
Continue to page 2 for more Project 321 products »
Project 321 / Enve wheel set
Project 321 Hubs
The rear hub utilizes two angular contact bearings, increasing bearing life and lateral load capacity. They can be accurately loaded to adjust bearing preload for zero play and to compensate for bearing wear. The hub is also designed with a very high oil capacity allowing the user to add oil and dampen the noise level if desired. The hub still features the venerated six pawl / 120 point engagement Torch freehub system created by Industry Nine. Weight is a very light 274 grams. A Supermax compatible front hub weighs a scant 114 grams.
Anodized Hollowgram crankset
Project 321 Hollowgram spindle
Summary
Our experience with all these Project 321 components has been very positive. Everything worked flawlessly with no play or creaks. Talking to owner Jake Liles is always a fun, learning experience. He is so knowledgeable yet so humble and fun-loving. He said his grand plan is to move his company from Fresno, CA to Bend, Oregon. Better culture, better trails and better beer await him and his crew.
For more information visit www.project321.com
- For use on tapered headsets only
- Made by Project 321
- Allows use of a SuperMax Lefty on frames with tapered head tubes (1.125"x 1.5")
- Weight 217.5 grams before cutting the steerer tube (weight will vary drastically due the varying clamp spacing of the Lefty)
- Total length from the bottom of the lower collar to the top of the steerer tube is 11 3/4 inches
- Spacers may be needed to complete your specific build. These should be available at your local bike shop
- Stem Cap Kit and Lefty Hub Cap with Titanium Bolt to add some bling to your build
- $95.00
- Also available in a 140mm
- $1520.00 sold by Project321
Why ride a Lefty?
- Hubs are built in CA and hand built in house using Enve M60 rims
- Rear hub offers all current axle configurations and front hubs are available in ISO, Lefty, or Lefty Supermax options
- Build comes standard with Sapim CX Ray spokes.
- Includes ENVE rim tape and valve.
- Hubs come with standard ABEC 5 bearings. Ceramic bearing upgrades avaialable.
- Professional hand build.
- White rim decals standard. Colored rim decals available add $50.
- $2879.00
Project 321 Hubs
- Includes spindle, bottom bracket, spider, and rings
- Available in XX1 or 2x
- $1300.00 ($1200.00 black)
- Allows use of Hollowgram cranksets on any bottom bracket standard
- Hollowgrams where previously only compatible with BB30 and PF30 bb's
- $50.00
Summary
