Just In: YEP Components Uptimizer Dropper Seatpost
Components
Yep Components has joined the crowded ranks of dropper seatposts with their new Uptimizer. The Swiss company is run by former Formula One driver Andrea Chiesa, who also happens to be an avid mountain biker. The aircraft-grade 7075-T6 aluminum Uptomizer is cable-actuated and comes in two versions—the externally-routed ST and the internally-routed HC, with travel lengths of 125mm and 155mm, and in 30.9mm and 31.6mm diameters. The hydraulic, air-sprung post features Angst & Pfister seals and dust rings, Motorex grease and oil, and IGUS iglidur bushings. The 500-gram post utilizes a zero-offset saddle two-bolt clamp, and a joystick-style remote lever.
Yep designed their seatpost to run with a lower air pressure (130 to 180 psi) compared to the industry norm of 250 psi, which helps reduce stress on the seals and increase longevity, according to the company. Using a specific internal design and precision build, they focused on hydrodynamic problems, valve shape and oil conducts to avoid vortices and cavitations, all of which provides silent and sensitive progressive action. The synergy of their entire design means it only requires a very light touch on the joystick remote to activate the system.
The externally cable actuated ST version (shown above) connection is located in a small compartment on the collar, much like the KS Lev system, so it’s stationary relative to the saddle’s up and down movement, avoiding interference issues with legs, tires, and linkages. The internally cable actuated HC version connects directly to the bottom of the post, much like the KS Lev Integra, creating a stealth or internal cable routing system.
Installation
The ST version which I tested, can have the actuator collar-box located in either a front or backward facing position, depending on personal preference. Once the positioning is decided, you take off the industrial-strength rubber band on the collar-box, take off the cover, and pop the cable end piece into the actuator lever, and reverse the process for completion. You then cut the housing and cable to the required lengths, snap the remote onto the handlebar, build the joystick remote lever, thread the cable and housing though the joystick, and clamp everything down to specs. It was a pretty simple and fast process to install everything, and I only had to adjust the cable once after things settled in.
Continue reading for more on the YEP Components Uptimizer and full photo gallery.
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • f says:
    Other than being the most expensive post in a market already crowded with expensive posts, I don’t see what this one has to offer vs everything else out there. Plus, added bonus, if it needs warranty work (and only an idiot buys a dropper post without considering that it might) you’ll have to send it to Switzerland, from the US, I’d guess that’s minimum a month you’ll be without.
  • Raym says:
    Not a big fan of product that can’t be user maintain. Make a good tech video and let the customer decide if it’s over their head or not.
  • I'mRight says:
    I agree, if ordering it’s a hassle picture owning it.
  • Nipa says:
    This is a great product! Over a year of abuse and it’s been completely trouble free and smooth. I just had it serviced at the factory because the yearly service was included in the price. In Europe it takes only a week to send it to Switzerland, have it serviced and sent back. Not a big deal IMHO.
  • Thomas says:
    I was hestitant buy this product due the relatively high costs. It turned out a great investement. Not only because it has withstand 2 years of solid riding and quite some abuse. Event though it was still working perfectly I decided to get it serviced. To my surprise the service was very efficent (one week including mailing) and free of any charge.
    I’m not going to tell you how my Rock Shox Reverb performed on my other bike….
