Leatt Interbike 2015
Next generation safety
Armor Hydration Interbike Sponsored post
Leatt is tantalizingly close to production of a new full face helmet that features some exciting new safety technologies.
Video: Leatt DBX 6.0, Knee and Elbow Guards, Gloves and Hydration Pack
Stephanie Slatter walks us through some of the new safety technologies integrated into Leatt’s new helmets, gloves, and hydration packs.
Leatt Interbike 2015 Booth
While Leatt has been teasing their much vaunted new full face helmet for some time, they had some pre-production samples at Interbike that looked tantalizingly close to being consumer ready.
The helmet boasts a number of interesting new safety technologies such as Armor Gel. This material is pliable when soft but hardens immediately upon impact. It’s strategically placed throughout the helmet in circular pucks to help with lower speed impacts, as well as rotational forces.
The EPS foam inside the helmet uses a combination of multi-density foams to accommodate a wider range of impacts speeds. These technologies allow Leatt to build a smaller helmet, which transfers less rotational forces to the head.
Other features include huge vents for cooling and removable cheekpads. Weight is 1280g and retail is $499.
The other interesting product on display was the new DBX Enduro Light WP Hydration System. This hydration pack has a built-in integrated CE 1 certified back protector, a reflective liner inside to keep liquids cool, and a harness system with GoPro mounts and a clear smartphone pocket. Additional accessories for the bag include a hands free helmet hose and carbon filter kit.
Gallery: Leatt DBX 6.0 Helmet, Air Flex Elbow and Knee Guards, DBX 4.0 Gloves and DBX Enduro Lite Pack
Leatt Interbike 2015 Gallery
of
Leatt DBX 6.0
The brand new Leatt DBX Head and Brain Protection line redefines the traditional helmet. The patented 360o Turbine Technology significantly reduces rotational acceleration to the head and brain, decreases head impact at concussion level, and improves multi-impact protection! The Leatt® reduced outer shell volume decreases the torque and rotational energy to the head & brain. The helmet is the past, Head and Brain Protection is here and now.
  • Quattro Force Control with Carbon or Composite matrix shell (3 sizes), 3D in-molded multi density V-Foam, 360° TURBINE multiple low energy impact & 360° Turbine rotational acceleration
  • Reduced outer shell volume for reduction in Neck forces & Rotational brain acceleration
  • Optimized Leatt neck braces integration with 360 degree helmet and neck brace match, rear clearance cut for optimal head range of movement & rear hyperextension impact platform
  • Optimized weight. Very light with premium safety
  • 16 large vent ports for maximum ventilation
  • Hydration ready. Optional internal hands-free kit available
  • Low friction cheek pads for emergency removal (patent pending)
  • Moisture-wicking, breathable and anti-microbial snap-out liner
  • Visor break away function
  • Certified and tested: EN1078; US CPSC; ASTM F1952 – 10
  • 2 Junior sizes: M 51- 52cm & L 53 - 54cm
  • 6 Adult sizes: XS 53 - 54cm, S 55 - 56cm, M 57 - 58cm, L 59 - 60cm, XL 61 - 62cm, XXL 63 - 64cm
Leatt DBX 6.0
  • Multi-Density impact foam
  • Deforms and compresses to better absorb impact
  • Reduces G-forces transferred to the head and brain
  • Medium & High energy impact protection
Leatt DBX 6.0
Leatt 3DF Airfit Body Tee Lite
Leatt’s top of the line in soft body protection features lighter weight, more ventilation and an ultra secure strapping system. The perforated, multilayer, 3DF Airfit impact foam offers a soft and flexible fit, yet instantly transforms into a harder, energy-absorbing protector upon impact.
Leatt Air Flex Elbow Guard
The new AirFlex Pro elbow guard uses Armourgel, a non Newtonian gel that locks up the molecules and becomes hard on impact. This revolutionary gel has great test results in both low and high impacts, works in hot and cold conditions and is soft, flexibleand comfortable. Its ultra slim design meets and exceeds CE certification for impact like all current Leatt elbow guards, but with little to almost no bulkiness.
  • New single sizing for perfect fit
  • New silicone printed cupped elbow grip
  • 6mm CE impact certified profile
  • Feather light at 110gram each
  • 3D molded Armourgel impact absorbing gel
  • New MoistureCool and AirMesh fabrics. Wicking, vented and antimicrobial
  • All protection materials perforated for ventilation
  • Silicone printed elastic non slip cuffs
  • Pre-curved 3D design for better fit and function
  • Independently CE tested and certified as impact protection EN1621-1
Leatt Air Flex Pro Knee Guard
The new ultra slim AirFlex Knee Guard Pro uses Armourgel – a non Newtonian gel that locks up the molecules and becomes hard on impact. This revolutionary gel has great test results in both low and high impacts, works in hot and cold conditions, and offers a soft, flexible and comfortable fit. It also offers extra protection to meet and exceed CE certification for impact like all current Leatt knee guards, but with almost no bulkiness.
  • New side impact protection
  • New upper knee impact protection
  • New silicon printed cupped knee grip
  • Feather-lite at 120 gram each
  • New Moisture Cool and Air Mesh fabrics: wicking, vented and antimicrobial
  • Silicone printed nonslip cuffs
Leatt DBX 4.0 Lite Gloves
New for 2016, Leatt Protective Gloves designed from two levels of impact protection and three cutting-edge materials. Uniquely engineered for maximum riding comfort with best-in-class CE Certified impact safety features.
  • DBX 4.0 Lite vented with premium protection
  • Nano grip palm
  • Vented 3D mesh upper
  • Anatomic 3D moulded self locating Armourgel impact protection
  • Pre-curved snug fit one piece seamless palm
  • Multi-ply Nylon thread stitching
  • CE Certified impact protection to prEN 13594: 4.10.2: level1
  • Thumb visor/sweat wiper
  • Stretch fit comfort cuff
  • 6 Sizes : XS EU6/US7, S EU7/US8, M EU8/US9, L EU9/US10, XL EU10/US11, XXL EU11/US12
  • Nano grip palm
Leatt DBX 4.0 Windblock Gloves
  • DBX 4.0 Windblock windproof with optimum protection
  • Nano grip palm
  • Windproof & water resistant upper
  • Nano grip palm
Leatt DBX Enduro Lite WP 2.0
Leatt’s DBX Enduro Lite WP 2.0 is designed for adventure riding, when you require larger amounts of storage. Includes lightweight helmet carrier system for both full face and bicycle helmets, heat resistant encapsulated bladder pocket, and a lightweight, fully adjustable harness for a perfect fit. Also includes outer pocket for MBT helmet or knee/elbow guards. One adult size fits S-XXL.
  • 2.0L Flat CleanTech Bladder and 5L luggage
  • Fully welded light waterproof outer shell
  • Unique chest harness with storage & cell phone pockets and rock solid fit
  • Independently CE tested and certified multi impact back protection 1621-2 Level 1
  • Lightweight helmet carrier system
  • Dual hydration tube exit for 2-way routing
  • Reinforced Tool pocket
  • Heat reflective inner back panel to keep liguid cool or hot
  • Neoprene Hydration Pocket
  • Optimal AirLine back ventilation
  • Cargo and compression straps
  • Height adjustable harness for load positioning on the back
  • Cell phone chest pocket with touch screen function
