Lezyne Interbike 2013
Interbike Sponsored post
Patrick Ribera-McKay from Lezyne shows us the new digital pumps with a digital custom gauge and new riding lights that include the Deca Drive, improved Mega Drive and the Zecto Drive Pro.
The new digital pumps have been introduced across Lezyne’s pump line and feature the digital custom gauge, a 1.5 inch screen, and 2 button operation. The digital pumps are retrofittable to existing Lezyne pumps and are weatherproof, accurate and will be available early October. The main reason of development was for the Shock Digital Drive which is Lezyne’s dedicated floor pump and shock pump with a max psi of 300 for Enduro, DH, and Cross Country bikes.
For this year, Lezyne has refined their lights internally, upped the Lumens, and added better recharging, better power output, and better batteries.
New this year is the high powered Deca Drive, 800 Lumen light. It runs on 3 LEDs and has Lezyne’s Infinite Light design that allows the user to have on-demand battery replacement. The Deca Drive will retail for $160 and will be available in October.
The updated, top level Mega Drive now features 1200 Lumens (up from 1000 Lumens), an increased constant Lumen run time of 1.5 hours, the new Infinite Light design and an improved mount for more durability and stability.
Leyne’s Zecto Pro is a front and rear combo light depending on what you need and has great side visibilty as well.
For more information visit www.lezyne.com.
Lezyne Interbike 2013 Gallery
of
Lezyne Zecto Drive Bike Lights
The Lezyne Zecto Drive Front is a compact safety light with three LEDs designed with a lightweight and sturdy Composite Matrix and CNC-machined aluminum body. It delivers a highly visible 80 lm in Daytime Flash Mode. The Intelligent Power Indicator allows the user to check the power level at any time, and provides Side Visibility, allowing 180 degrees of visibility and increases user safety. It can recharge any time with a Micro USB cable for ultimate convenience. The light easily attaches via its Clip-On System, providing for versatile strapped or clipped mounting. It is available as a single front LED, or as a front/rear pair (Zecto Drive Front and Rear). Zecto Drive Front: $34.99; Zecto Drive Pair: $64.99.
Lezyne Zecto Pro Bike Lights
The compact Lezyne Zecto Drive Pro is a versatile safety light with three LEDs designed with a lightweight and sturdy Composite Matrix and CNC-machined aluminum body. It is dual purpose and can be used in either Front (white) Mode or Rear (red) Mode. The Front Mode uses two white LEDs producing an ultra-bright 160 lm high-visibility Daytime Flash. The Rear Mode activates one red LED that delivers an ultra-bright 40 lm Daytime Flash. The Intelligent Power Indicator allows the user to check the power level at any time, and provides Side Visibility, allowing 180 degrees of visibility and increases user safety. It can recharge any time with a Micro USB cable for ultimate convenience. The light easily attaches via its Clip-On System, providing for versatile strapped or clipped mounting. $49.99.
Lezyne Zecto Pro Light Clip Detail
Lezyne Super Drive XL Bike Light
The Lezyne Super Drive XL has been designed with the XL CNC-machined aluminum body that is lightweight, durable, and promotes LED efficiency. Constant Lumens power management drives LED performance at a bright 575 lumens. Overdrive Race Mode allows quick switching between Overdrive and Economy to optimize the use of power for any occasion. The Side Visibility Cuts allow for 180 degrees of visibility, especially from the side. The Infinite Light design allows the user to replace the Li-ion battery on demand. The Intelligent Power Indicator button allows the user to check the power level any time and choose between fast, high efficiency, 2 Amp recharging with a compatible wall adaptor, or via a Micro USB cable for ultimate convenience. The Super Drive XL comes with Composite Matrix handlebar mounts (25.4mm and 31.8mm) and 2 rubber shims. It is also available as part of a Fully Loaded package with CM handlebar mounts, a CM helmet mount, a spare battery pack, a Micro USB charging cable, and CM storage case. $119.99.
Lezyne Mega Drive Bike Light
With a CNC-sculpted aluminum body in a compact, self-contained configuration, the Lezyne Mega Drive is the ultimate high performance LED light built for trail or road use. It features Constant Lumens power management that drives two LEDs at a bright 1,200 lm. Overdrive Race Mode allows quick switching between Overdrive and Economy, and its Infinite Light design allows for on-demand battery replacement for a blinding light that never quits. Users can choose between fast, high efficiency, 2 Amp recharging with a compatible wall adaptor, or via a Micro USB cable for ultimate convenience. The Intelligent Power Indicator button allows the user to check the power level any time. The Mega Drive’s CM hard mounts secure the light to 31.8 mm and 25.4 mm handlebars. It is available in the Fully Loaded package with aluminum handlebar mounts (31.8mm and 25.4mm), a spare battery pack, a Micro USB charging cable, and CM storage case. $199.99.
Lezyne Deca Drive Bike Light
The Lezyne Deca Drive is designed with a sleek CNC-sculpted aluminum body in a compact, self-contained configuration. It features Constant Lumens power management that drives three LEDs at a steady and bright 800 lm. Overdrive Race Mode makes it possible for quick switching between Overdrive and Economy, and its Infinite Light design allows for on-demand battery replacement. The Intelligent Power Indicator button allows the user to check the power level any time. It is recharged either with fast, high efficiency, 2 Amp recharging with a compatible wall adaptor, or via a Micro USB cable for ultimate convenience. The Deca Drive’s Composite Matrix hard mounts secure the light to 31.8 mm and 25.4 mm handlebars. It is also available in the Fully Loaded package with aluminum handlebar mounts (31.8mm and 25.4mm), a spare battery pack, a Micro USB charging cable, and CM storage case. $149.99.
Lezyne Loaded Bike Light Kit
Lezyne Femto Drive Bike Lights
The Lezyne Femto Drive Front is a bright, ultra-compact, 15 lm safety light. It features an integrated lens switch made of high-grade optical material, which serves as an activation button that cycles through four Flash modes and one Solid mode. The CNC –machined aluminum body is lightweight, durable, and extremely weather-resistant. The Composite Matrix back cap features the Clip-On System for versatile strapped or clipped mounting. The multi-position silicon rubber strap attaches directly to the back plate to secure the light to a wide range of handle bar diameters. The Side Visilbility lens extends beyond the body providing 180 degrees visibility, and increasing user safety. The back cap can easily be unscrewed to replace the two CR2032 disposable batteries. The Femto Drive Front is available as a single front LED, or as a front/rear pair (Femto Drive Front and Rear). Femto Drive Front: $14.99; Femto Drive Pair: $27.99.
Lezyne Femto Drive Light - Clip Detail
Lezyne Tech Floor Drive DV
The Lezyne Tech Floor Drive is a high pressure floor pump with a machined steel barrel and piston, a varnished wood handle, and a molded Composite Matrix base. . It is equipped with ball/bladder adapters, and users can choose to utilize either its ABS Flip-Thread Chuck, or the new Dual Valve head. An extra long rubber hose with Composite Matrix connectors easily reach both Presta and Schrader valves. Its 2.5-inch oversized gauge is precise and very easy to read. An anodized high-polish finish makes this digital pump stylish and durable. $59.99.
Lezyne Dirt Floor Drive
The Lezyne CNC Dirt Floor Drive is the ultimate high volume floor pump optimized for use with mountain bike tires. All components are custom CNC machined aluminum for a durable design. The barrel, piston, hose and connectors are oversized to deliver twice the air flow per stroke to quickly fill tires or seat tubeless tire systems. The ABS Flip-Thread Chuck and long rubber hose easily reach both Presta and Schrader valves on a stand. The Speed Chuck is included for fast press-on valve engagement. The 2.5” oversized gauge is very precise and easy to read. An anodized high polish finish makes this pump stylish and durable. $109.99.
Lezyne Shock Digital Drive
The Lezyne Shock Digital Drive is the ultimate digital high pressure shock pump, perfect for shop use. Compatible with Presta valves, it features a dedicated floor pump configuration for faster shock tuning, with an ultra narrow barrel and piston to allow the user to easily achieve high shock pressure settings. Its varnished wood handle and CNC-machined aluminum and steel construction deliver a durable and lightweight design. Hardened steel APS Shock Thread Chuck allows for precise pressure tuning. Equipped with an extremely accurate Digital Gauge, the Shock Digital Drive pumps a third of the air of a standard floor pump at 300psi with a high pressure, nylon-reinforced, braided hose with aluminum connectors. $109.99.
Lezyne Twin Speed Drive C02 With 25g Cartridge
A compact, 100% CNC machined aluminum CO2 inflator. The simple Theaded Valve Operation allows for easy inflation. The Twin Slip-Fit head presses onto Presta and Schrader valves for fast engagement. The two piece head design allows O-rings to be replaced when needed. It is compatible with threaded CO2 cartridges only and comes with an anti-freeze jacket to protect hands during inflation. $14.99.
Lezyne Shop Shock Drive
The Lezyne Shop Shock Drive is a heavy duty shock pump designed for daily shop use. All components are made of custom CNC machined aluminum. The oversized, oil-filled gauge is durable, accurate and easy to read. The high pressure, steel braided hose threads onto shock valves for a secure connection during inflation. It can be detached from the pump body for storage. The bleeder valve button allows the user to easily adjust pressure. It comes equipped with Lezyne's ABS Flex Hose, which has a threaded Presta connection with ABS on one side and a threaded Shrader connection on the other. $99.99.
Lezyne Hand Pumps
Lezyne Hand Pumps
Lezyne Carbon 5 Bike Tool
Lezyne Carbon tools use carbon, aluminum, stainless steel and titanium to make the ultimate multi tools. FCT carbon fiber side plates and machined titanium hardware keep the weight down without sacrificing tool rigidity or performance. Forged, Center-pivot, stainless steel bits are heavily machined for low weight and durability.
Lezyne Shop Tools
Lezyne Shop Tools
Lezyne Three 3-Way Tools
The Lezyne 3 Way Wrench are shop quality Y-wrenches that feature the Serviceable Body Design for extremely durable, long lasting tools. The CNC machined, two piece, hardened steel body is ergonomically shaped and allows replacement of worn bits as needed. The chrome vanadium steel bits are perfect for heavy-duty shop use. Each wrench comes with a set of replacement tool bits. $19.99.
Lezyne Port-A-Shop
Lezyne Port-A-Shop
The Lezyne Port-A-Shop is a cycling specific tool kit that is small enough to take traveling, yet functional enough to use in the garage. The kit includes tools for basic maintenance and most repairs. The convenient carrying case, with labeled pockets, keeps tools organized and safe. $139.99.
Lezyne Port-A-Shop Case
Lezyne Danny MacAskill Block Bike Tool
MacAskill Block is an extremely versatile, durable tool designed to meet the needs of pro trials rider Danny MacAskill. The CNC-machined I-Beam body design is lightweight and rigid. The forged Chrome Vanadium bits are nickel plated for durability. The long body and 8mm Allen bit provides ample leverage for tightening cranks and pedals. The offset wrapped bit design allows for a compact tool profile. The MacAskill block is simple and elegant with a custom two-tone anodized finish. Danny’s signature is CNC-machined into the body of the tool, proof of his approval. $24.99.
Lezyne Micro Caddy M - Works With Dropper Posts
The Lezyne Micro Caddy is a compact, aero shaped Caddy that tucks close under the saddle, attaching to the rails with a wide Velcro and nylon band for a secure and vibration free connection without the need of a post strap. The labeled cycling-specific organizational pockets keep all accessories in place. It is made of durable woven nylon fabrics, a water resistant zipper, and reflective logo and stripes that aid rider visibility. An easily accessible, external multi-tool compartment allows for quick adjustments. $24.99.
Lezyne Power Cage Bottle Cage
The Lezyne Power Cage is made of oversized hollow aluminum tubing for strength. The wrap-around design securely holds bottles over rough terrain while providing easy on-the-bike access. The aluminum base is welded to the hollow tubes for a durable and secure connection. $9.99.
Lezyne Carbon SLL & SLR Bottle Cages
Lezyne Flow Cage SLR & SLL Bottle Cages
2013 Lezyne Interbike Booth
Wordpress Comments:
  • Ryan Kelley says:
    As always, Lezyne has quality products that work right out of the package. I learned how to pronounce it by watching the video: Luh-Z-i-n-e
    The Interbike booth is slick and shiny. Do I want to impress the customers that come into our little bike shop with a +/- 3% Digital Hand-Pumps? Yes. Will I buy one? We started charging for air. We say: The air is free, but it cost 1.00 to use the pump.”
