Lezyne Interbike 2014
KTV, Zecto Auto, Macro Drive Duo lights and Control Drive CO2 inflator
Gear Interbike Lights Sponsored post
Lezyne‘s brand new KTV and KTV Pro, Zecto Auto and Macro Drive Duo lights are highlighted, along with their Control Drive CO2 inflator and ABS pen gauge hand pump.
Video: New 2015 lights and pumps from Lezyne
Michael Drabousky from Lezyne introduces the brand new KTV, KTV Pro, Zecto Drive Auto and Macro Drive Duo lights, along with the Control Drive CO2, ABS pen gauge and improvements to their Floor Drive pumps.
Lezyne Interbike 2014 Booth
Brand new for 2015 is Lezyne’s KTV and KTV Pro “Be Seen” lights. The KTV front light features 15 Lumens, 3 modes, 9.5 hours of run time while the KTV rear features 5 Lumens and 8.5 hours of run time. They are USB rechargeable with a battery indicator and a MSRP of $20. The KTV Pro has 70 Lumens, is CNC machined and USB rechargeable.
Another light is the Zecto Auto LED, a motion detected light that’s great for any commuter. It features 20 Lumens and 10 hours of run time, auto shut off after 3 minutes, CNC machining and is USB rechargeable.
The Lezyne Macro Drive Duo is a front and rear helmet mounted light with 400 Lumens in the front and 5 Lumens in the rear, giving it 180 degree visibility.
Also brand new for 2015 is the Control Drive CO2 twist to inflate inflator. It is CNC machined and is fully controllable based on how much air you desire.
The ABS pen gauge in Lezyne’s hand pump line is new for 2015 as well. It features an inline gauge attached to the hose with Presta and Schrader valves.
Lezyne also has big improvements for their Floor Drives, including the CNC, Alloy and Classic. Now with a larger 3.5 gauge, updated internals and 220 PSI.
Gallery: Lezyne KTV, Zecto Auto, Macro Drive Duo lights, Control Drive CO2 inflator, gauge and Floor Drive pumps
Lezyne Interbike 2014 Gallery
of
Lezyne KTV Drive Pro
  • Compact, aluminum bodied, high visibility, two LED safety light
  • Clip-On System provides versatile strap or clip mounting
  • Side visibility lens design to provide 180 degrees of visibility
  • Intelligent Power Indicator LEDs monitor battery power and charging status
  • Integrated USB stick makes recharging convenient and cable free
  • Available individually or as front/rear pair with KTV Drive Rear
Lezyne KTV Drive
  • Compact, aluminum bodied, LED safety light
  • Side Visibility lens extends beyond the body to provide 180 degrees of visibility
  • Front produces 15 lm, Rear produces 7 lm
  • Available individually or as front/rear pair combination
Lezyne KTV Drive Tail Light
Lezyne Zecto Auto Pro
  • Motion detecting system triggers automatic shutoff of light after 3 minutes of inactivity, turns back on when in motion again
  • High visibility safety light with three LEDs
  • Clip-On System provides versatile strapped or clipped mounting for your bike or clothing
  • Intelligent Power Indicator LEDs monitor battery power and provide side visibility
  • Rechargeable via Micro USB cable for ultimate convenience
  • Lightweight CNC machined aluminum helmet front light with integrated rear light
  • Constant Lumens power management drive the front LED to 400 lms and 5 lms for rear
  • Side visibility design allows 180 degree visibility and increases user safety
  • Rechargeable via Micro USB cable for convenience
  • Capable of fast High Efficiency 2 amp charging with compatible wall adapter
  • Includes snap-fit CM helmet mount easily adjust to many styles of helmets
Lezyne Control Drive CO2
  • CO2 inflator made of all CNC machined aluminum and brass
  • CNC control knob twists for easy and precise inflation
  • Twin Slip Chuck head slips on to Presta and Schrader valves
  • Neoprene sleeve insulates hand from cold during discharge
  • Compatible with threaded CO2 cartridges, comes with one 16 g cartridge
Lezyne Gauge Drive HP
  • Compact, lightweight hand pump with overlapping handle, designed for high pressure tire
  • CNC sculpted aluminum barrel, handle and piston, CM end caps
  • Equipped with the ABS Pen Gauge, precise and compact in-line pressure gauge compatible with Presta and Schrader valves
  • Includes a CM frame pump mount
Lezyne Gauge Drive HV
  • Compact, lightweight hand pump with overlapping handle, designed for high volume tires
Lezyne Alloy Floor Drive
  • Aluminum and varnished wood handle with steel piston
  • Oversized 3.5 in precision gauge measuring 220 PSI
  • Extra long, standard rubber hose with aluminum connectors
  • Durable, anodized, high-polish finish
  • Equipped with ABS Flip-Thread Chuck, Speed Chuck, ball/bladder adapters
Lezyne Classic Floor Drive
  • Machined aluminum base, steel barrel and piston
  • Varnished wood handle
  • Premium metallic paint finish
Lezyne CNC Floor Drive
  • The ultimate high pressure floor pump
  • All CNC machined aluminum construction
  • Extra long, nylon-reinforced, braided hose with aluminum connectors
Lezyne RAP 21
Lezyne RAP
  • Functional, entry-level multi-tools
  • Ergonomical forged aluminum side plates
  • Forged, wrapped Center-Pivot, Chrome Vanadium steel bits
  • Chrome Vanadium steel fastening hardware
  • Cast stainless steel chain breaker (8/9/10/11 speed chains)
  • (RAP 20 and 14 only)
  • Three spoke wrenches integrated into the chain breaker
RAP LED
  • RAP tools with a compact, 1 lumen LED light tool tip
  • Light body is made of CNC machined aluminum
  • Activated with simple on/off twist operation
  • Light slips over 5 mm hex, held in place by spring loaded ball
  • LED is powered by 2 AG1 button cell batteries
