Last week at the Taipei bike show, Lezyne was teasing two new pumps that look awfully close to production.
A foot actuated lever allows you to pressure (or rapidly depressurize) the air chamber of the new Lezyne Pressure Overdrive Pump (click to enlarge).
The Pressure Over Drive works along the same lines as the Bontrager Flash Charger. Use it like an ordinary pump until you flip the integrated foot lever, which allows the oversized aluminum chamber to be manually pressurized. Hitting the switch releases a shot of air that will help seat tubeless tires.
Side-by-side comparison of the Micro Floor Drive with its new oversized sibling (click to enlarge).
The Micro Floor Drive XL, which is a oversized version of Lezyne's popular floor pump is designed to work with the biggie sized tires found on plus and fat bikes.
Pricing and availability has yet to be announced, but we expect to learn more at next month's Sea Otter Classic.
