Feature Articles , Pro Reviews
LifeProof iPhone Case and Bike & Bar Mount Review
LifeProof recently released a bike and bar mount for their iPhone LifeProof case, which is a waterproof, snowproof, dustproof and shockproof case. The new mount fits a wide range of bike and motorsport bars, so you can take your iPhone on and off road, and into adverse conditions and environments. The synchronicity of the case and mount, allow you to use cycling GPS apps and normal mobile usage while riding a bike, extending the usefulness of your iPhone.
LifeProof Bike & Bar Mount
The mount is made from a tough high-impact resistant plastic, and it snugly cradles the iPhone case on its back, corners and top edge, without any undue movement. It clamps down with an easy to use handlebar clamp that has three rubber size adapters for varying bar thickness. The thinnest adapter will allow it clamp to fit onto most stems, though I was unable to use it on any of my oversize or irregular shaped stems, as it was too narrow for them.
It pivots and locks down using a ball and socket gimbal system, much like a RAM mount, so the angle can easily be adjusted for personal preferences. It was simple to pop the iPhone in and out of the unit using the top clip-in clasp, as well as the handlebar clamp, making for easy swap outs. It also didn’t need to be over tightened to keep it from moving, but the mount and iPhone aren’t that heavy, so nothing was really torquing things around much. I banged it around on some ugly heinous terrain, through teeth jarring rock gardens, in which the unit was subjected to some severe oscillations, and the iPhone remained rock solid and stable in the mount. Although the mount is designed specifically for their case, other rugged and durable iPhone case types might also fit, but I didn’t test them for sizing constraints nor fit.
Measured Specs:
  • Bar mount – 69.6 grams + 10.2 grams or 8.4 grams or 3.7 grams for each adapter band
Conclusions
The unit is robust, easy to use and adjust, and held their iPhone case in a secure and stable manner, though it would be nice to have a way to attach it to oversize mountain-bike stems. I liked how simple it was to pop the case out of the unit, and that it went right back in and remained sturdy and immobile. I crashed a number of times and hit the mount pretty hard, and although it tweaked it out of position, it didn’t cause any damage. I was truly amazed how freakin’ secure and bombproof this held the case, even on the most rugged and gnarly trails, and it never seemed to waver out of place and remained stable, and it retails for a decent $39.95.
Strengths
  • Durable and rugged
  • Easy to use – bar clamp and case
  • Adaptable to multiple bar sizes
  • Secure and stable
Weaknesses
  • It won’t fit irregular and oversize stems
  • Designed for their iPhone case – not tested with other cases?
Overall Rating: 5 Flamin’ Chili Peppers
Follow Brian Mullin at http://www.gramslightbikes.com
LifeProof Bike and Bar Mount Specs:
  • MSRP: $39.95
  • Website: http://www.lifeproof.com/lifeproof-store/apple-accessories/bike-mount
  • Light weight honeycomb construction with premium high-impact materials for optimal strength to weight ration
  • Accepts LifeProof iPhone 4 + iPhone 4S case
  • Use your performance and navigation apps in real-time
  • All buttons and features accessible in mount, including speaker and microphone.
  • Fits wide range of bars and bar-stems
  • Adjustable for portrait or landscape orientation
  • One-handed release latch for fast insertion and removal of LifeProof case
  • Integrated lock switch to prevent unwanted removal of iPhone.
  • Rear camera compatible – can be adjusted to vertical angle suitable for video recording activities
  • Accepts phone facing in or out
  • Compatible with Bluetooth headsets
  • Gimbal ball-head allows for the fine adjustment of viewing angle
  • Suitable for any use in any weather, seawater, dirt, and snow, including high vibration environments
Wordpress Comments:
  • Jimmy CASANOVA says:
    This mount worked great on handicap scooters too! I have mine mounted on a pride
    Maxima 4 wheel scooter handle bars it’s awesome it’s just like having on bicycle great for
    My iPhone 4s
  • Mark says:
    Case works! BUT no costomer service.. Phone number is worthless no answer,same for twitter account! Bought second gen for 4s people I call have hard time hearing me! Siri can’t understand! Because of design of case I can’t use docking station and the company has a dock extender but it’s been out of stock for months!! Again worst part is lifeproof doesn’t answer any calls,inquires or twitter posts! Sure it works to keep water out but it’s worthless once your $400 phone is in it!! Horrible customer service! Don’t make the same mistake I did and buy this!!!
  • Almeister says:
    DO NOT, I repeat, DO NOT waste $80.00 on a Lifeproof case! If you want to make your iPhone truly waterproof you may want to take a look at Liquipel. After seeing Liquipel demonstrated at CES I could not believe what I was seeing, an iPhone completely submerged underwater and fully functioning! The vendors even had some people call the iPhone while it was submerged to show that it was indeed still working. After seeing that I had my iPhone 4S sent out to them and when I got it back I wanted to put it to the test so I left my iPhone submerged in water overnight and as expected my iPhone was still functioning properly. For additional protection against drops I just put one of the many FREE iPhone cases that I scored at CES. It cost me $60.00 plus shipping to have Liquipel waterproof my iPhone. In my opinion this new technology essentially rendered Lifeproof cases OBSOLETE as far as waterproofing goes and if you’re worried about dropping your phone you can just get an inexpensive case for that. Take my word for it, this stuff really works. If you don’t believe me just check out their website http://www.liquipel.com they got videos of it in action. You can also do a search for them on YouTube, and you’ll see a bunch of videos that were taken at CES last month.
  • Matt says:
    Not bad, but way too many parts. Check out this case, http://www.rokform.com/cart/Rokbed-v3.html.
    To mount it on your bike, you only need this, (check out the video): http://youtu.be/VsuWqsaborc?hd=1
    Case and mount… that’s it. Awesome case, ridiculous quality and craftsmanship. Even better customer service! Rokform makes great iPhone cases! And it’s all made in the USA. Check them out: http://www.rokform.com
    • Brian Mullin says:
      Matt: Thanks for the info. Their case does not seem to be dirt or water proof? And I don’t see the new bike mount on their site?
      Almeister: I have seen that product for other things, jackets, etc. It does make it waterproof, but you’ll still need a case that can be dirt proof, and then a mount that works with the the tougher case.
