Lindarets Thru Axle Wheel Mount
Secure thru-axle wheel storage and schleppage
Components News
Born – as these things often are – of a specific need, the Lindarets Thru Axle Wheel Mount was made to securely hold thru axle front wheels in their workshop and while seeking out new rides in the Sprinter campervan. But it works every bit as well in retail spaces and demo trailers.
The new Wheel Mount is CNC machined from 6061 aluminum and features a stepped stub axle and wingnut that will accommodate 12x100mm (road standard), 15x100mm (mountain standard), and 15x110mm (boost) front hubs.
The axle is mounted at a slight angle to allow space-saving overlap with narrower tires yet keep even 27.5×3.0 knobbies from contacting the mounting surface. The three-inch, four-bolt square base plate can be mounted to walls or posts (you supply appropriate hardware) at any orientation that works for you.
A limited quantity of Thru Axle Wheel Mount is available now for preorder now and will ship in early April. Price is $40.
Technical Details
  • Weight: Approximately 136g
  • Standard Front Wheel Mounts will accept: 12x100mm (road standard) front hubs; 15x100mm (mountain standard) front hubs; 15x110mm (mountain boost) front hubs
  • Mounting holes will accept four #10 or M5 screws/bolts (not included)
  • For indoor use only
For more information visit www.lindarets.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
