Loaded Precision Interbike 2013
Interbike Sponsored post
Mike Mulder from Loaded Precision shows us their much anticipated 2014 Carbon product lineup, that includes the Napalm Carbon stem, Xlite Ultra Carbon seatpost, AmXC, Xlite and Napalm Carbon handlebars, and the X-lite and X-lite Ultra Carbon wheelsets. Also featured are the X-lite Ultra Aluminum seatpost, AmXc and X-lite Ti stems, AmX Signature pedals, AmXc Pistol and AmXc NoSlip grips, and the AmX Step Down axle.
The Napalm Carbon handlebar is for the weight conscious XC racer, weighing in only 114g. The typical manufacturing process forms the bar in 3 pieces which results in unnecessary added material and weight in the fusing process. Loaded has come up with a different process which uses a styrofoam mold that allows for a one pass, complete layout for the entire bar, that eliminates extra material. During this process, the styrofoam also evaporates and goes away. Also for 2014 is the new Napalm Carbon stem, that features Titanium hardware, full Carbon faceplate, weighs in at 91g and is available in 90mm 100mm 110mm and 120mm lengths.
The AmXc Carbon handlebar has a 760mm width, a UD finish, cool graphics and weighs 210g. It’s suited for the Cross Country, Freeride or lightweight DH bike. The X-lite Carbon handlebar also features a UD finish, no slip overlay on the grip and stem mounting sections, and is available in a 680mm width with 15mm rise (133g) and a flat 710mm with 0mm rise option (142g).
The brand new X-lite Ultra Carbon wheelset is available in 27.5″ and 29″ with DT or Loaded hub options. They are hand laced in San Diego, CA, have an internal width of 19mm, quad buted spokes and are perfect for XC racing. They can weigh sub 1300-1450g depending on the configuration. Another new wheel set is the X-lite Carbon. The X-lite Carbon wheelset features a 21mm internal rim width, DT Swiss or Loaded hubs, TBT tubeless technology, fortified nipple bed technology, Carbon knitting technology that takes the Carbon thread and knits the lamination layers together, as well as elastomers that are added during the resin process, which increases the strength and makes it impossible for the Carbon to crack. The 29″ inch wheels can go up to a 2.3 width tire and come in Red and White color options. It is specifically designed for hardcore Trail, Enduro and XC use and is perfect for the lightweight race bike that needs to be durable.
To round out the new Carbon lineup is the X-lite Ultra Carbon seatpost, which has Titanium hardware, a simplistic design and weighs 142g.
The AmXc stem is forged and CNC Machined and is perfect for a XC, Trail or Enduro bike. It features stainless steel, tapered hardware on the stem and Loaded has taken out as much material as possible to bring the weight down while still maintaining strength. The Xlite Ti stem is CNC Machined out of 7075 Aluminum, features a Carbon Fiber faceplate, Titanium hardware, low stack high height and weighs in at 99g.
The X-lite Ultra Aluminum steatpost is brand new for 2014. It is a one piece machined tube with a simple design and weighs 166g. The AmX Signature pedals come in 2 axle configurations, Titanium (266g) or Chromoly (326g), with a 12.9mm thickness, wide platform and dual oversized bearings. The new AmXc Pistol grip features a patented “Anti-Slip” compound of high grade, sticky rubber that’s hydrophobic and oleophobic. It also features a machined “c clip” and end cap combination that helps to evenly load the handlebar and supports the interface. Lastly, the AmX Step Down axle made from 7075 Aluminum, is specifically for frames 135mm wide that have a quick-release or 10mm dropout and want to secure rear wheel with locking axle.
For more information visit www.loadedusa.com.
Loaded Precision Interbike 2013 Gallery
of
Loaded Napalm Carbon Bars
The Napalm Carbon handlebar is for the weight conscious XC racer, weighing in only 114g. The typical manufacturing process forms the bar in 3 pieces which results in unnecessary added material and weight in the fusing process. Loaded has come up with a different process which uses a styrofoam mold that allows for a one pass complete layout for the entire bar that eliminates extra material. During this process, the styrofoam also evaporates and goes away.
Loaded Napalm Carbon Stems
The new Napalm Carbon stem, that features Titanium hardware, full Carbon faceplate, weighs in at 91g and is available in 90mm 100mm 110mm and 120mm lengths.
Loaded AmXc Carbon Bar
The AmXc Carbon handlebar has a 760mm width, a UD finish, cool graphics and weighs 210g. It's suited for the Cross Country, Freeride or lightweight DH bike.
Loaded 29-Inch & 27.5 X-Lite Carbon Wheelsets
Loaded 29-Inch & 27.5 X-lite Carbon Wheelsets
The X-lite Carbon wheelset features a 21mm internal rim width, DT Swiss or Loaded hubs, TBT tubeless technology, fortified nipple bed technology, Carbon knitting technology that takes the Carbon thread and knits the lamination layers together, as well as elastomers that are added during the resin process, which increases the strength and makes it impossible for the Carbon to crack. The 29" inch wheels can go up to a 2.3 width tire and come in Red and White color options. It is specifically designed for hardcore Trail, Enduro and XC use and is perfect for the lightweight race bike that needs to be durable.
Loaded 27.5 X-Lite Ultra Carbon Wheelset
Loaded 27.5 X-lite Ultra Carbon Wheelset
The brand new X-lite Ultra Carbon wheelset is available in 27.5" and 29" with DT or Loaded hub options. They are hand laced in San Diego, CA, have an internal width of 19mm, quad buted spokes and are perfect for XC racing. They can weigh sub 1300-1450g depending on the configuration.
Loaded 29-Inch X-Lite Ultra Carbon Wheelset
Loaded 29-Inch X-lite Ultra Carbon Wheelset
Loaded AmX Carbon Rims
Loaded X-lite Ultra Carbon Seatpost
The X-lite Ultra Carbon seatpost has Titanium hardware, a simplistic design and weighs 142g.
Loaded AmXc & AmX Wheelsets
Loaded's Signature AmXc 26" wheelset features our Signature Series Hubs paired with our 25mm-wide AmXc 26” Rim. Whether it’s Cross-Country, or All Mountian- the Signature AmXc 26” wheelset offers the rider incredibly strong, extremely durable, and exceptionally eye –catching performance at a value-based price.... Available Hand Built from our USA Warehouse with 7 different color options for hub, rim, and spokes or as Pre-Built with Matching Rim/Hub. All Signature Series Wheelsets include Front Axle Options (9mm, 15QR, 20mm) and Rear Axle Configurations (9x135mm, 12x135mm, and 12x142mm).
  • Price: 599.99
  • Weight: 1936g
  • Size: 26in
  • Disc Mount: 6 - Bolt
  • Hole: 32H
  • Hub Body: Alloy
Loaded's Signature AmXc 29" wheelset features our Signature Series Hubs paired with our 23.5mm-wide AmXc 29” Rim. Whether it’s Cross-Country, or All Mountian- the Signature AmXc 29” wheelset offers the rider incredibly strong, extremely durable, and exceptionally eye –catching performance at a value-based price.... Available Hand Built from our USA Warehouse with 7 different color options for hub, rim, and spokes or as Pre-Built with Matching Rim/Hub. All Signature Series Wheelsets include Front Axle Options (9mm, 15QR, 20mm) and Rear Axle Configurations (9x135mm, 12x135mm, and 12x142mm).
  • Price: $599.99
  • Weight: 2,073g
  • Size: 29in
  • Hole: 32H
  • Axle: Aluminum
  • Spacing: 135x9mm, 135x12mm, 142x12mm
  • Hub Body: Aluminum
  • Cassette Body: Cro-Mo
Loaded's Signature AmXc 26"/29" Single Speed wheelset delivers a simple solution to your horizontal dropout needs! Our Signature Series Hubs combined with our 25mm-wide AmXc 26” Rim / 23.5mm-wide AmXc 29” Rim makes for the perfect blend of reliability and performance.... Available Hand Built from our USA Warehouse with 7 different color options for hub, rim, and spokes or as Pre-Built with Matching Rim/Hub. All Signature Series Wheelsets include Front Axle Options (9mm, 15QR, 20mm). Signature Series Single Speed Rear Hubs include a 10mm Bolt On axle and a 16t cog for simple SS Setup.
  • Price: 629.99
  • Weight: 2072g (26") 2209g (29")
  • Size: 29in / 26in
  • Hole: 32H
  • Axle: 10mm Bolt On
  • Spacing: 135mm
  • Cassette Body: Stainless Steel
Loaded's Signature AmX 26" wheelset features our Signature Hub laced up to our 29mm-wide AmX Rim. This combination provides the rider with a wheelset that is built specifically for the demanding conditions of today's modern All Mountain and Trail Riding conditions. AmX Wheelsets are incredibly strong, extremely durable, and exceptionally eye -catching.... Available Hand Built from our USA Warehouse with 7 different color options for hub, rim, and spokes. All Signature Series Wheelsets include Front Axle Options (9mm, 15QR, 20mm) and Rear Axle Configurations (9x135mm, 12x135mm, and 12x142mm).
  • Price: 599.99
  • Weight: 2270g
  • Size: 26in
  • Bearings: 4 Sealed(rear) 2 Sealed (front)
  • Hole: 32H
  • Axle: Alloy
  • Hub Body: Alloy
Loaded AmXc & AmX Rims
Loaded AmXc rims are strong, stiff, and durable- while still maintaining a respectable weight. These aluminum rims are designed for today’s ‘All Country’ riding- Cross Country weight, with All Mountain durability and strength. 7 different color options make these a great way to build up a very unique Custom handbuilt wheelset.
  • Price: 79.99
  • Weight: 430g (26") / 480g (29")
  • Material: 6061 Aluminum
  • Diameter: 26in / 29in
  • Width: 18mm X 25mm (26") / 17.5mm X 23.5mm (29")
  • ERD: 540 (26") / 598.5 (29")
  • Disc Mount: Disc Only
  • Hole: 32H
Amx Rims are a freeriders dream. Durable and strong, these rims can take a pounding without hesitation. Rock gardens, drops or tricks, regardless of the feature, AmX rims can take the heat.
  • Price: 79.99
  • Weight: 615g
  • Material: T10 Aluminum
  • Diameter: 26in
  • Width: 29mm
  • ERD: 532
  • Disc Mount: Disc Specific
  • Hole: 32H
Loaded X-lite Ultra Rims
All X-Lite Ultra Rims feature True Bead Technology- Loaded’s very own Tubeless System that provides an efficient interface between the tire and rim for easy installation and inflation. With a reinforced internal beam (I-beam) to provide torsional rigidity, the X-Lite Ultra TBT Rims provide the rider the ultimate balance between weight and durability.
  • Price: 89.99
  • Weight: 374g (26") / 412g (29")
  • Material: 6066 Aluminum
  • Diameter: 26" / 29"
  • Width: 19mm Internal
  • Size: 26in / 29in
  • ERD: 547 (26") / 608 (29")
  • Hole: 32 Hole
Loaded X-lite Ti Stem
We designed this stem with one goal in mind... to manufacture the Lightest Mountain Bike Stem in the Industry. We started with a block of T6 7075 alloy, which was forged and then machined to create this masterpiece for 2012 - the Xlite Titanium Stem is Road Bike light, but Mountain Bike strong! Offered in several different lengths, this stem will offer the rider the absolute best in quality, durability, and weight.
  • Price: 99.99
  • Weight: 99g
  • Length: 90mm, 100mm, 110mm, 120mm
  • Clamp Diameter: 31.8mm
  • Material: 7075 Aluminum
  • Diameter: 1 1/8in
  • Rise: +/- 5°
  • Dimensions: 38mm Stack Height
Loaded AmXc Stem
Loaded AmXc Stem
The AmXc Stem was developed to offer a unique stem choice to the rider - bridging the gap between ‘Lightweight’ XC Stems and their ‘Heavy’ trail bike counterpart. The AmXc stem meets a specific need for the modern trail bike - a lightweight, yet durable solution that provides absolute control and strength. Crafted from T6-6061 Aluminum, the AmXc Stem is forged into its initial form, then CNC Machined, anodized, and laser-etched resulting in a beautiful work of art that will find itself home on any trail bike. AmXc stems are available in 70mm, 85mm, and 100mm lengths and feature a 5° positive or negative rise.
  • Price: 79.99
  • Weight: 133g (85mm Length)
  • Length: 70mm, 85mm, 100mm
  • Rise: +/- 6°
Loaded AmX Stem
Loaded AmX Stem
The Loaded AmX Stem is a Downhill & Freerider’s dream come true. This stem is strong, light, and ready to handle anything the mountain can throw at it!
  • Price: 69.99
  • Weight: 211g
  • Length: 45mm
  • Material: 6061 T6 Aluminum
  • Diameter: 1-1/8
  • Rise: 0°
  • Dimensions: 37mm Stack Height
Loaded AmX Direct Mount Stem
Want strength, performance and styling for your DH machine? Bring it direct with Loaded Precision Direct Mount Stems. Dual-mounting positions make it possible to adjust between 45mm and 50mm stem length. Lightweight, durable and strong, Direct Mount stems fortify your downhill setup.
  • Price: 89.99
  • Weight: 154g
  • Length: 45mm / 50mm
  • Material: CNC Machined 6061 Aluminum
  • Rise: 0°
Loaded X-lite Seatposts
The X-lite Seatpost offers maximum strength without the weight. Utilizing a 3-step manufacturing process, this Seatpost is first 3D forged, then CNC turned and milled. This creates a one piece work of art without welds or bonding. With its laser etched graphics and visually stunning color options, this Seatpost is certainly “best in class”. The Seatpost features a very convenient dual Ti bolt clamping mechanism which makes attaching your saddle a , breeze. Ease of installation, full angle adjustment, and the engineering that has gone into this piece make it ideal for anyone looking for a simple, elegant, and durable seatpost.
  • Price: 79.99
  • Weight: 280g (27.2mm x 400mm)
  • Length: 400mm
  • Material: 3D Forged 6061 Aluminum
  • Diameter: 27.2mm / 30.9mm / 31.6mm
Loaded Carbon & Aluminum Handlebars
Loaded Step-Down Axles
The AmX Signature Series of Axles offers unique solutions to common axle configuration issues. This Step Down Axle has been uniquely created to match a traditional 12mm Hub diameter, with a 10mm Dropout-equipped frame. Finely CNC machined, this axle is a work of art through and through. To add to the increased rigidity this axle offers, the Signature Series axle includes a specifically designed Nut that is CNC Machined out of the finest quality aluminum, then reinforced with a Steel Insert for added security and strength.
  • Price: 59.99
  • Weight: 60 grams
  • Material: CNC 7075 Alloy
  • Spacing: 135mm standard 12mm Hubs
Loaded Signature Hubs
The Signature Hub is the perfect blend of value, reliability, and consistent performance. Loaded makes a simple task out of converting this hub to match different frames and dropouts- the Rear hub can easily be configured to 135mm x 9mm, 142mm x 12mm , and 135mm x 12mm Configurations. The unique 3 Dual Action Pawls offer precise engagement and deliver quick response through the 24T Oversized Engagement Ring. Anodized in Black, Blue, Red, Green, Grey, Gold, and Silver- match the Signature Series Rear hub to a custom wheel build of your choice and add both performance and styling to your bike.
  • Price: 269.99
  • Weight: 357g
  • Disc Mount: 6-bolt
  • Bearings: 4 Sealed Bearings
  • Hole: 32H
  • Axle: Alloy
  • Flange Diameter: RFD: 49mm | LFD: 58mm
  • Center to Left Flange: 32.5mm
  • Spacing: 9x135mm, 12x135mm, 12x142mm
  • Hub Body: Alloy
Loaded AmXc No Slip Grips
There are very few 'contact' points on a bike, your grips are the main one! The new AmXc ‘NoSlip' Grip was designed to meet the demands of today's trail conditions. Whether it's snow, rain, mud, grease, or just dirt- the NoSlip grip ensures the rider's hands stay exactly where they are needed- ON THE BARS! Available in 6 different lock ring/end cap colors, this grip allows you to add the finishing touch to your unique bike.
  • Price: 29.99
  • Weight: 118g
  • Length: 130mm
  • Material: NoSlip Rubber, Alloy Lock Rings, and End Caps
  • Diameter: 29.5mm
Loaded X-lite Race Day Skewers
If you are looking for the lightest skewers on the market then look no further! This elegantly simple design has enabled us to offer an astonishingly lighweight skewer set with a lightweight price as well! Weighing in at just 43 grams, these Xlite Skewers are a great addition to any bike looking to save weight where it counts.
  • Price: 59.99
  • Weight: 43g
  • Material: 7075 Aluminum Lever
  • Spindle: Titanium 6Al-4V Grade 5
Loaded X-lite Threadless Headset
Your mind will be blown trying to decide what you like best, the 66 gram weight, the dual angular contact bearings set, or the beautifully finished 7075 Anodized and laser etched aluminum. Dollars per gram, dollars for feature, and features per gram… this headset has got it all.
  • Price: 129.99
  • Weight: 66g
  • Size: 1 1/8in X 1 1/8in (1.125 X 1.125)
  • Bearings: Dual Angular Full Compliment Ceramic Hybrid
Loaded X-lite Binder Clamp
Loaded X-lite QR Binder Clamp
How can a Seat Post QR be sexy you ask? Start with 5 axis CNC milled 7075 Aluminum. Everything about how the lever lays back against the detailed clamp, the subtle taper of the lever as it curves to the perfect little ball at the end for the minimalistic, yet comfortable hand feel. God is in the details, it is said--This flowing, slender at a mere 24 grams, and strong from careful detailed design and state of the art material, is guaranteed to put a smile on your face every time you touch it.
  • Price: 39.99
  • Weight: 24g
  • Material: 7075 Aluminum & Titanium
  • Diameter: 31.8mm | 34.9mm
Loaded AmXc QR Binder Clamp
The AmXC QR has a tried and proven streamlined design and ergonomic shape for fast adjustment, and a comfortable hand feel in any condition. Plus it adds a self lubricating DU bushing that makes it smooth in any condition.
  • Price: 27.99
  • Weight: 38g
  • Diameter: 28.6mm / 31.8mm / 34.9mm
Loaded AmX Signature Ti Flat Pedals
Light, Thin, Strong... These are the 3 words that describe our AmX Signature Ti Pedals. These pedals are remarkably thin, at only 12.9mm at its 'thickest' point. Featuring a Titanium Axle machined out of Grade 5 6AL-4V Titanium, this pedal puts your bike on a diet at only 266g. The consistent feel and durability of these pedals are sure to please any rider, on any trail.
  • Price: 269.99
  • Weight: 266g (without pins)
  • Material: Alloy Body, Titanium Spindle
  • Spindle: Grade 5 6AL-4V Titanium
  • Size: Platform 100mm (W) x 110mm (L)
  • Bearings: 4x Sealed Bearings 2x DU Bushings
  • Axle: Titanium
Loaded Interbike 2013 Booth
