Loaded Precision Interbike Booth
Interbike Sponsored post
Mike Mulder shows us what’s new for 2013 including the 99g X-Lite Ti stem, 133g AmXC stem that comes in 70, 85 and 100mm lengths, X-Lite carbon fiber handlebar, seatpost clamp offerings, X-Lite wheelsets with new True Bead Technology and the AmX Signature flat pedal.
Loaded Precision Interbike Booth Gallery
of
Loaded X-Lite Ultra Rim
All X-Lite Rims feature True Bead Technology- Loaded’s very own Tubeless System that provides an efficient interface between the tire and rim for easy installation and inflation. With a reinforced internal beam to provide torsional rigidity, the X-Lite TBT Rims provide the rider the ultimate balance between weight and durability. Loaded’s True Bead Technology - Loaded’s very own Tubeless System that provides an efficient interface between the tire and rim for easy installation and inflation. With a reinforced internal beam to provide torsional rigidity, the X-Lite TBT Rims provide the rider the ultimate balance between weight and durability. True Bead Technology makes tubeless tire systems available to virtually all mountain bikes. Utilizing a rim profile that integrates a varied selection of tires and sealants in a tubeless system, TBT delivers consistent bead interface between the tire and rim ensuring a true seal.
  • Material: 6061 Aluminum
  • Holes: 32
  • Internal Diameter: 19mm
  • Weight:  26”=374g/29”412g
  • External Diameter: 23.50mm
  • Tubeless: TBT (True Bead Technology)
Loaded X-Lite TBT Rim
  • I-beam for torsional rigidity
  • Eyeleted
  • 26", 27.5", 29"
  • 19 or 21mm rim width
Loaded X-Lite Tubeless 27.5" Rear Wheel
  • 1500g set weight
  • Tubeless ready
  • Hand built in the USA
  • 7 colors
  • Featuring Tire Bead Tech (T.B.T.)
Loaded X-lite Ti Stem
We designed this stem with one goal in mind... to manufacture the Lightest Mountain Bike Stem in the Industry. We started with a block of T6 7075 alloy, which was forged and then machined to create this masterpiece for 2012 - the Xlite Titanium Stem is Road Bike light, but Mountain Bike strong! Offered in several different lengths, this stem will offer the rider the absolute best in quality, durability, and weight. T6 7075 aluminum is the lightest aluminum alloy for a stem application. We have included Titanium hardware for both the carbon faceplate and the steer clamp, just to ensure we produced the lightest stem on the market. Titanium bolts not only save weight, they also inhibit rust and corrosion. The Xlite Titanium stem is available in a variety of lengths, and can be installed at either a positive or negative 5° rise. Anodized, laser etched, and crafted from our passion for the modern bicycle- this stem is at Road Bike light, but Mountain bike bred!
  • Price: $99.99
  • Weight: 99g
  • Length: 90mm, 100mm, 110mm, 120mm
  • Clamp Diameter: 31.8mm
  • Material: 7075 Aluminum
  • Diameter: 1 1/8in
  • Rise: +/- 5°
  • Dimensions: 38mm Stack Height
  • Price: $99.99
  • Weight: 99g
  • Diameter: 1 1/8in
  • Rise: +/- 5°
  • Price: $99.99
  • Weight: 99g
  • Diameter: 1 1/8in
  • Rise: +/- 5°
Loaded X-Lite Titanium Stem
  • 7075 forged alloy
  • CNC machined
  • 90, 100, 110, 120mm lengths
  • Titanium hardware
  • 99g (100mm length)
Loaded AmXC Stem
The AmXc Stem was developed to offer a unique stem choice to the rider - bridging the gap between ‘Lightweight’ XC Stems and their ‘Heavy’ trail bike counterpart. The AmXc stem meets a specific need for the modern trail bike - a lightweight, yet durable solution that provides absolute control and strength. Crafted from T6-6061 Aluminum, the AmXc Stem is forged into its initial form, then CNC Machined, anodized, and laser-etched resulting in a beautiful work of art that will find itself home on any trail bike. AmXc stems are available in 70mm, 85mm, and 100mm lengths and feature a 5° positive or negative rise.
  • Price: $79.99
  • Weight: 133g (85mm Length)
  • Length: 70mm, 85mm, 100mm
  • Rise: +/- 5°
  • 6061 Forged and CNC Machined Face Plate and Body
  • Tapered Stainless Steel Hardware
  • Available in Black, Blue, Green, Gold, Grey, Red, and Silver
Loaded AmXC Stem
  • Price: $79.99
  • Rise: +/- 5°
Loaded AmXC Stem
  • Price: $79.99
  • Rise: +/- 5°
Loaded AmXC Stem
  • Price: $79.99
  • Rise: +/- 5°
Loaded AmXC Stem
  • Price: $79.99
  • Rise: +/- 5°
Loaded AmXC Trail Stem
  • 6061 forged alloy
  • CNC machined
  • 70, 85, 100mm lengths
  • 5° rise
  • Tapered stainless hardware
Loaded AmX Signature Pedal Ti
Light, Thin, Strong... These are the 3 words that describe our 2012 AmX Signature Ti Pedal best. This pedal is remarkably only 12.9mm at its 'thickest' point. Featuring a Titanium Axle machined out of Grade 5 6AL-4V Titanium, this pedal puts your bike on a diet at only 254g!!! We have narrowed the 'Q' factor for this year to get the absolute best in performance and rider-feedback in the spindle interface. The consistent feel and durability of these pedals are sure to please any rider, on any trail. Grade 5 6AL-4V Titanium is simply the highest grade of Titanium available to manufacturers- that’s why we used it for our AmX Signature Titanium Flat Pedal. We have saved over 45% of the weight used in even the ‘light’ axles used by other manufacturers- which is why our Titanium Pedal comes in at just under 254g!!! The Titanium Axle combined with our 6 Sealed Bearing axle interface, offers reliable performance without sacrificing weight. Whether it’s XC, Trail, All Mountain, All Country, Down Country, Downhill, DJ, or Freeride- these pedals are a perfect way to keep your feet planted on any trail.
  • Price: $269.99
  • Weight: 254g
  • Material: Alloy Body, Titanium Spindle
  • Spindle: Grade 5 6AL-4V Titanium
  • Size: Platform: 100mm (W) x 110mm (L)
  • Bearings: 6x Sealed Bearings 2x DU Bushings
  • Axle: Titanium
Loaded AmX Signature Platform Pedal
  • Ti or Cromo axle
  • Sealed Cartridge Bearings (3)
  • 13.1mm profile height
  • Ti or Cromo axle
Loaded AmX Signature Pedal CroMo
At only 320g, the Signature pedal for 2012 leaves nothing to compromise. This pedal is extremely light, incredibly strong, and looks amazing on any bike. Offered in our full color selection, these pedals will keep your feet on the bike no matter how rough the trail gets. We looked at the 'Q' factor and said to ourselves "How can we get the pedal body as close as possible to the crank?" A narrow 'Q' means better cornering, more consistent pedal engagement, and reliable strength. The AmX Signature Pedal features offset heel/toe edges to provide additional clearance when the bike is leaned over ripping through corners. 6 Sealed Bearings per pair ensure reliable performance and durability in any conditions. At only 320g, these pedals are light, strong, and extremely good looking!
  • Price: $139.99
  • Weight: 320g
  • Spindle: CroMo
  • Price: $139.99
  • Weight: 320g
  • Spindle: CroMo
  • Price: $139.99
  • Weight: 320g
  • Spindle: CroMo
Loaded AmXC Grips
There are very few 'contact' points on a bike, your grips are the main one! The new AmXc ‘NoSlip' Grip was designed to meet the demands of today's trail conditions. Whether it's snow, rain, mud, grease, or just dirt- the NoSlip grip ensures the rider's hands stay exactly where they are needed - ON THE BARS! Available in 6 different lock ring/end cap colors, this grip allows you to add the finishing touch to your unique bike. This grip features our patented 'Anti-Slip' compound to ensure consistent traction where the hands meet the bike. We also have included our own 'lock' ring and end cap combination- we have combined a lock ring with a alloy end cap to create the perfect combination of form and function. A little 'thicker' than your traditional grip, we made a grip that feels better than anything we've ever grabbed on the bars!
  • Price: $29.99
  • Weight: 118g
  • Length: 130mm
  • Material: NoSlip Rubber, Alloy Lock Rings, and End Caps
  • Diameter: 29.5mm
Loaded AmXC Grips
  • Price: $29.99
  • Weight: 118g
  • Length: 130mm
  • Diameter: 29.5mm
Loaded AmXC Grips
  • Price: $29.99
  • Weight: 118g
  • Length: 130mm
  • Diameter: 29.5mm
Loaded AmXC No Slip Grips
  • 7075 CNC machined lock rings and end clamp
  • "No Slip" rubber compound
  • 3mm hardware
  • Patented clamping mechanism
  • 3mm hardware
Loaded AmXC Grips
  • Price: $29.99
  • Weight: 118g
  • Length: 130mm
  • Diameter: 29.5mm
Loaded X-lite Carbon Flat Bar
Flat, Low, light and WIDE!!! That is what sets the Loaded X-Lite Carbon Fiber Flat Handlebar apart from the rest. With a class-leading weight, the X-Lite Carbon Flat Bar features a 3K carbon weave, ensuring that each and every handlebar performs to a level unmatched by any other. With a bold 710mm width, the X-Lite Carbon Flat Bar is sure to offer the rider a unique blend of comfort and control. Carbon Nano Tube Reinforced Directionally loaded lay up design. 3k Weave finish looks amazing and displays the craftsmanship in the Carbon layout. The force directional lay up of the carbon material is specifically designed to inhibit vibration transfer to your wrists.
  • Material: 3K Carbon Fiber Weave
  • Weight: 152g
  • Back Sweep: 0°
  • Up Sweep: 0°
  • Width: 710mm
  • Rise: 5mm
  • Weight: 152g
  • Back Sweep: 0°
  • Up Sweep: 0°
  • Width: 710mm
  • Rise: 5mm
  • Weight: 152g
  • Back Sweep: 0°
  • Up Sweep: 0°
  • Width: 710mm
  • Rise: 5mm
Loaded X-Lite Carbon Flat Handlebar
  • 3x carbon weave
  • 710mm wide
  • 154g weight
  • 5° rise
  • 9° back sweep
Loaded X-lite Carbon Riser Bar
The ULTIMATE carbon handlebar! Loaded set a whole new standard with its nanotube, force directional designed carbon bar that's incredibly light and stiff. Don't let its gorgeous 3K weave and best in class 133-gram weight fool you; this bar is designed to be ridden hard with its aggressive 680mm width, low rise, and amazing feel. Carbon Nano Tube Reinforced Directionally loaded lay up design. 3k Weave finish looks amazing and displays the craftsmanship in the Carbon layout. The force directional lay up of the carbon material is specifically designed to inhibit vibration transfer to your wrists.
  • Price: $139.99
  • Weight: 133g
  • Length: 680mm
  • Material: 3k carbon weave
  • Back Sweep: 9°
  • Up Sweep: 6°
  • Width: 680mm
  • Rise: 15mm
  • Price: $139.99
  • Weight: 133g
  • Length: 680mm
  • Back Sweep: 9°
  • Up Sweep: 6°
  • Width: 680mm
  • Rise: 15mm
  • Price: $139.99
  • Weight: 133g
  • Length: 680mm
  • Back Sweep: 9°
  • Up Sweep: 6°
  • Width: 680mm
  • Rise: 15mm
Loaded AmX Flat DH Handlebar
Keep this bar on the Down-Low and keep your hands down low! Our DH riders told us they wanted something wider and flatter, and we delivered. The new 2012 Loaded Flat Bar is an insane- 32" wide, comes in 7 different colors, and has been tested to get the perfect sweep and bend. Get down on our new 2012 Flat Bar! The flat bar is becoming increasingly popular in the DH and Gravity scene. Flat bars provide the rider the ability to set up their bike to best suit their preferences. This handlebar features pre-measured increment marks to cut the width down to the perfect size- or run them as is and be confidant that you have the widest bars on the mountain!
  • Price: $89.99
  • Material: Aluminum
  • Back Sweep: 8°
  • Width: 810mm
Loaded X-lite SIT Headset
Loaded headsets achieve their remarkable world class lightweight, strength and stiffness by using the more expensive 7075 Aluminum, (nearly as strong as steel) coupled with a dual angular hybrid ceramic bearing set, and meticulous analysis of where every extra gram can be removed. These headsets will amaze you with their smooth operation, and stiff, stable coupling capability. Compare the weight, these headsets set new state of the art standards for weight, strength and durability.
  • Price: $149.99
  • Weight: 99g
  • Size: ZS 44 | ZS 56 (SHIS) or 1-1/8 x 1.5 Tapered Matching Zero Stack
  • Bearings: Dual Angular Full Compliment Ceramic Hybrid
  • Top Stack Height: 6.5mm
  • Bottom Stock Height: 2mm
  • Insertion Depth: 10.7mm
  • Designed for tapered Steer
  • Price: $149.99
  • Weight: 99g
Loaded X-lite SI Headset
Your mind will be blown trying to decide what you like best, the 66 gram weight, the dual angular contact bearings set, or the beautifully finished 7075 Anodized and laser etched aluminum. Dollars per gram, dollars for feature, and features per gram… this headset has got it all.
  • Price: $149.99
  • Weight: 66g
  • Size: 1 1/8 x 1 1/8 (1.125 X 1.125) 46|46 ZS (SHIS)
  • Top Stack Height: 6mm
  • Bearing: Dual Angular Full Compliment Ceramic Hybrid
  • Insertion Depth: 5mm
  • SI= Semi Integrated Headset
  • Price: $149.99
  • Weight: 66g
Loaded X-lite Threadless Headset
  • Price: $129.99
  • Weight: 66g
  • Material:7075 Aluminum
  • Size: 1 1/8in X 1 1/8in (1.125 X 1.125)
  • Top Stack Height: 12.5mm
  • Bottom Stock Height: 10mm
  • Insertion Depth: 9mm
Loaded X-Lite Headset
  • 7075 CNC machined caps
  • Ceramic sealed cartridge bearings
  • Lifetime warranty
  • Alloy top cap bolt
  • Extremely lightweight
Loaded X-lite Race Day Skewers
If you are looking for the lightest skewers on the market then look no further! This elegantly simple design has enabled us to offer an astonishingly lighweight skewer set with a lightweight price as well! Weighing in at just 43 grams, these Xlite Skewers are a great addition to any bike looking to save weight where it counts.
  • Price: $59.99
  • Weight: 43g
  • Material: 7075 Aluminum Lever
  • Spindle: Titanium 6Al-4V Grade 5
  • Price: $59.99
  • Weight: 43g
  • Price: $59.99
  • Weight: 43g
  • Price: $59.99
  • Weight: 43g
Loaded X-lite QR Binder Clamp
How can a Seat Post QR be sexy you ask? Start with 5 axis CNC milled 7075 Aluminum. Everything about how the lever lays back against the detailed clamp, the subtle taper of the lever as it curves to the perfect little ball at the end for the minimalistic, yet comfortable hand feel. God is in the details, it is said--This flowing, slender at a mere 24 grams, and strong from careful detailed design and state of the art material, is guaranteed to put a smile on your face every time you touch it.
  • Price: 39.99
  • Weight: 24g
  • Material: 7075 Aluminum & Titanium
  • Diameter: 31.8mm | 34.9mm
Loaded X-Lite QR Seatpost Collar
  • Titanium hardware
  • Lightest QR collar on market
  • 31.8mm and 34.9mm sizes
Loaded Interbike Booth
Wordpress Comments:
  • Doug says:
    I have the Cromo axle pedals and must say they work great and I may get another pair.
  • JimmyDee says:
    “Most of the stuff you see is made by Mortop bikes in Taiwan (look at thier website). Not a single item made by Loaded. another re-labeling company.” -Mohamed Karim.
    “Most of this comment is made by an ignorant Brit who can’t spell or capitalize properly. Not a single comment about the actual quality of the product or how it is different to design a product and have it made by a factory compared to buying stuff they already make.”
    I’ve met Mike and talked some pretty serious shop with him here in Taiwan. The guy is pretty serious about knowing what he wants, describing what he wants and getting what he wants. Given what I know about the bike industry (I’ve worked for 5 years here in TW) and what I know about Mike and what I know about other products that he makes and who makes them, I’d say it’s pretty likely that Mortrop is taking his designs and selling them on the side.
    It’s a chicken and the egg argument for sure, but I’m pretty sure that this is quite common in the bicycle manufacturing sector.
    Doesn’t change the fact that some excellent quality parts are made in Taiwan.
    After all, what’s the alternative? Should he be making the product in a small factory in his basement in the US? How would that help anyone? I’m guessing that like most Americans, he doesn’t have a rim flash welding machine, a CNC and an anodizer kicking around in a spare bedroom. At some point it is going to need to move to a factory.
  • Marino says:
    Sounds like Jimmy Dee is a clone of Mike! can some one check if they share the same IP address (same computer)?
    Mortop is well established way before the new loaded cowboys here. I wonder if these cowboys make a single item in the USA? Zero is the answer.
    Just come clean and position your self as a Re-labeling company.
    I challenge you on anything that Mike or loaded makes anything at all
    a visit to Mortop Bike will tell you the whole story
    Marino
