Michael Mulder from Loaded Precision shows us the X-Lite Ultra XC wheelset that weighs under 1500g. Also featured are the AmXc trail/enduro stem in 70mm, 85mm and 100mm designed for a flip-flop 6° or -6° compatibility and the AmXc lock-on grips with its unique rubber compound that's hydrophobic and oleophobic resistant. Loaded Components was also showing off some of their products on this Ibis Mojo HD on the back of a mini-Hummer.
From the Manufacturer:
X-Lite Ultra Wheelset
X-Lite wheelsets feature Loaded's True Bead Technology rims- our very own Tubeless System that provides an efficient interface between the tire and rim for easy installation and inflation. With a reinforced internal beam to provide torsional rigidity, the X-Lite TBT Rims provide the rider the ultimate balance between weight and durability. X-Lite Wheelsets feature our tubeless X-Lite Ultra rims measuring 19mm edge to edge, matched to a quad-butted seamlessly drawn spoke. X-Lite aluminum spoke nipples are matched in 7 different colors to the X-Lite series hubs. Hubs are convertible to 9mm or 15QR up front, and 9mm or 12x142mm configuration in the rear. All X-Lite wheelsets come tubeless ready and include skewers.
29-inch Specifications:
- 19mm Rim Width
- 32H
- Front Axle Options (Included)
- 15mm QR*
- Standard 9mm QR*
- Rear Axle Configuration (Included)
- 135mm Standard QR*
- 12x142mm Thru Axle*
- 1561g weight (Fr&Rr)
- 3 Dual Action Pawls
- 24 Continuous Points of Engagement
- 6-Bolt Disc Mount
- 29" Diameter
- 1561 Grams (Set) Weight
- $799.99
- 19mm Rim Width
- 32H
- 15mm QR*
- Standard 9mm QR*
- 6-Bolt Disc Mount
- 26" Diameter
- 1453 Grams (Set) Weight
- $799.99
We designed this stem with one goal in mind... to manufacture the Lightest Mountain Bike Stem in the Industry. We started with a block of T6 7075 alloy, which was forged and then machined to create this masterpiece for 2012 - the Xlite Titanium Stem is Road Bike light, but Mountain Bike strong! Offered in several different lengths, this stem will offer the rider the absolute best in quality, durability, and weight. T6 7075 aluminum is the lightest aluminum alloy for a stem application. We have included Titanium hardware for both the carbon faceplate and the steer clamp, just to ensure we produced the lightest stem on the market. Titanium bolts not only save weight, they also inhibit rust and corrosion. The Xlite Titanium stem is available in a variety of lengths. Anodized, laser etched, and crafted from our passion for the modern bicycle- this stem is at Road Bike light, but Mountain bike bred!
Specifications:
- 38mm Stack Height
- 1 1/8in Diameter
- 7075 Aluminum
- 31.8mm Clamp Diameter
- 90mm, 100mm, 110mm, 120mm Length
- 99g Weight
- $99.99
There are very few 'contact' points on a bike, your grips are the main one! The AmXc 'NoSlip' Grip was designed to meet the demands of today's trail conditions. Whether it's snow, rain, mud, grease, or just dirt - the NoSlip grip ensures the rider's hands stay exactly where they are needed - ON THE BARS! Available in 6 different lock ring/end cap colors, this grip allows you to add the finishing touch to your unique bike. This grip features our patented 'Anti-Slip' compound to ensure consistent traction where the hands meet the bike. We also have included our own 'lock' ring and end cap combination- we have combined a lock ring with a alloy end cap to create the perfect combination of form and function. A little 'thicker' than your traditional grip, we made a grip that feels better than anything we've ever grabbed on the bars!
Specifications:
- 29.5mm Diameter
- NoSlip Rubber, Alloy Lock Rings, and End Caps
- 130mm Length
- 118g Weight
- $29.99
