Lupine Lighting Interbike 2013
Interbike Sponsored post
Jon Kokus from Lupine Lighting, which is manufactured and engineered in Germany, shows us the 2014 product lineup that includes the Piko, Wilma and the Betty. All three lights feature interconnectivity and interchangeability so that all batteries work with all lamp heads. The color temperature of the lights are similar to the sun, making for a more realistic night ride.
The Piko features 1200 Lumens, weighs in at 55 grams (lamphead only) and 180 grams for the total package including the battery. It can be mounted using an optional CNC handlebar mount, as well as to a headband or helmet. The Wilma features 4 LEDs, 2800 Lumens, and can be mounted to a handlebar or helmet. The flagship Betty features 7 LEDs, 4500 lumens and includes wireless handlebar remote which can also be mounted to your wrist.
Lupine also features a range of Lithium Ion batteries from 2.0 Ah all the way up to the Big Ben Bottle battery at 17.5 Ah. The Lupine SmartCore series has a LED indicator on top so you know how long your ride can last. The new 2014 FastClick battery option allows you know that your battery is locked and secure.
For more information visit www.lupine.de.
Lupine Lighting Interbike 2013 Gallery
of
Lupine Betty R14
Lupine Betty R14 lamphead with wireless remote button. The brightest helmet lamp in the world has just become even brighter. Our top model emits almost unbelievable 4500 lumens, outperforming everything you might have seen by far. In addition to the Betty R‘s extensive setting options, the revolutionary wireless remote control offers unprecedented ease of use. With this floodlight you are the king of the night. Betty R 14 comes with an 13.2 Ah Smartcore battery and a helmet mount; to put it on a handlebar an optional mount-set is available.
Piko 4 SmartCore Battery Headlight
The Piko comes with a 3.3 Ah SmartCore battery and was developed as the world’s best headlight but we would not be Lupine if we did not offer an optional nice quick-release handlebar mount as well.
Piko Lampheads Anodized Colors
The Piko rules with its concentrated light power of 1200 lumens and its compact size smaller than a matchbox and a weight of only 55 grams. The ratio of weight and performance in the Piko is unrivalled throughout the world. Whether as a helmet or head lamp – our Piko is the perfect lamp for biking, jogging, trail running, geo-caching, alpine touring, rescue missions, fishing, boating and much more. It isn’t difficult to build a 1200 lumens light, what makes it hard, is to make it so small and lightweight you can’t even feel it on your helmet.
SmartCore 13.2 Ah Battery
The SmartCore battery comes with powerful electronics: simply push the control panel and the remaining battery capacity will be indicated in steps of 10 %. The advantage is obvious: The capacity may be checked at any time no matter if the battery is in use, being charged or has been lying in the hall for two weeks and waiting for the next adventure.
A rear and running light function may also be activated by the push of a button. The balancing function also integrated additionally increases our batteries performance and life.
Lupine Piko Road Application
The quick release mount allows to put the Piko on a handlebar. Cause of its design, the light will sit right in front of the stem. The mount itself is only 7 mm wide and does not need much space on the bar. The mount is cnc machined and even the screws and bolts were CNC machined out of V4 stainless steel.
Betty TL Photo Application (Joby Tripod)
This is an standard Joby Gorillapod which you can use as an tripod for the new Betty TL2.
Fast Click 2.0 Ah Battery
With this modification kit you can turn your old Piko Headlight into a new one. The modification kit does contain 3 items: One 2.0 Ah SmartCore FastClick battery, FastClick backpart and an old style backpart: just in case you want to convert backwards.
Betty R Lamphead on Uvex Helmet
The helmet mount is attached by help of a velcro, which you put through the venting slots. The helmet bracket can be attached to virtually any helmet that has ventilation slits.
GoPro Mount
With this adapter you can attach the light on the GoPro mounts.
Lupine Lighting Interbike Booth
