Lupine Lighting Systems – Interbike 2018
Showcasing the latest from iconic German manufacturer
Interbike Lights Sponsored post
Lupine Lighting: High-quality German-manufacturing, paired with innovation, guarantees long-lasting products that stand the test of time.
Video: Lupine Lights Blika and SL AF – 2018 Interbike
“For over 25 years, Lupine has offered a collection of the brightest LED lights in the world. High-quality German-manufacturing, paired with innovation, guarantees long-lasting products that stand the test of time. Lupine’s wide range of accessories can transform a single light into a bike light, headlamp, or helmet light; ideal for night-time adventures like biking, skiing, camping, hunting and photography.
“All Lupine lamps are precision-milled from a single piece of high-quality aluminum, ensuring that lamp housing is lightweight, waterproof, and durable.
“Beautiful, intuitive design paired with high-end LED’s, custom optics, hand-selected components, and an internal heat management system, allow Lupine lamps to withstand extremes- sub-zero temperatures, snow and rain, and rugged terrain.”
Lupine SL4
Lupine SL AF
The automatic daytime running light increases your visibility on the road. The beam pattern was especially designed to meet international regulations for road-use headlights, yet still make the most of your riding skills when taking your E-MTB off-road.
Lupine Blika
Lupine Blika
There are lights for running, lights for climbing, lights for biking, and there’s one for all your adventures. Massive 2100 lumens, low and high beam, red and green light, a gentle reading light, and the brand new FrontClick system makes the Blika the most versatile Lupine we have ever built.
Bluetooth control and our range of compatible accessories allow you to maximize versatility, and easily transform your Blika into a headlamp, handlebar-mounted light or helmet light.
Lupine Alpha
Lupine Alpha
The new Lupine Alpha is nothing less than the most powerful bicycle lamp for racing we’ve ever built. A full 7200 lumens, perfect illumination and an enormous range of up to 840 meters make your bike the ultimate nighttime racing machine.
Whether directly in front of the front wheel or several hundred meters away: the Alpha will show you every detail on your trail. The Alpha combines 3 different lens types to create a perfectly illuminated image tailored for racing use. Two 22° lenses in combination with two ultra-wide angle lenses ensure never-before-seen Illumination at close range. Four 18° lenses focus part of the light and generate a range that outshines any comparable lamp.
