Magura Interbike 2013
Interbike Sponsored post
Jude Monica from Magura shows off the new eLECT automatic compression damper, the TS8 650B fork and the TS RL rear shock. The eLECT automatic, electronic compression damper locks out and unlocks the compression of the cartridge of the fork. It features a wireless remote that communicates via ANT+, automatic mode, manual mode, a micro-USB charing port and fits into existing forks (back to 2010).
New for 2014 is the TS8 650b fork with a new casting that features a wider crown for more tire clearance.
Also shown is the TS RL rear shock that comes in 4 different lengths 165mm, 190mm, 200mm, 210mm.
Visit magura.com for more information.
Magura Interbike 2013 Gallery
of
eLECT Control Unit
Intelligent 3D acceleration sensor and incredibly light weight.
eLECT Control Unit
eLECT Remote Control
The intelligent eLECT module from MAGURA senses the riding situation, second by second, meter for meter. Due to the effectiveness of the 3D-acceleration sensor any changes to the inclination or impacts are immediately registered. Completely independent of your adrenaline level. In short: Your mode automatically.
eLECT matches all MAGURA TS8 R, TS6 forks and all suspension forks from MY2010 on. The wireless module can also be fitted directly to MT brakes. To all other types it can easily be added with an extra clamp.
DLO³ Suspension
Stiffer. Lighter. Easier. Feel the difference! The outstanding features of our new products are low maintenance and reliability. The new DLO³ has an innovative, ergonomic adjuster knob for three different damping settings:
  • Open Mode - The fork operates with optimal response and utilizes the full travel.
  • Firm Mode - Designed for aggressive riding styles with reduced sensitivity – “ready to race”. The damping is firmer.
  • Lockout Mode - Blow-off function included.
DLO² Suspension
  • Dynamic Lock Out - The lockout system for TS8 and TS6 suspension forks with a Blow-off function and optimized damping. Operated manually (TS6) or with the handlebar remote (TS8 R).
  • Open Mode - Maximum sensitivity.
  • Close Mode - No bouncing during out-of-the-saddle pedalling.
eLECT Suspension
New for 2014.
SL Suspension
TS RC Rear Shock
New for 2014. The new TS RC suspension strut has an adjuster lever for three different damping settings:
  • Open Mode - The strut operates with optimal response and utilizes the full travel.
Perfect for Trail and Allmountain bikes.
  • RC: Rebound damping and compression from open over aggresive riding up to lockout
  • Custom tuning for compression (high-, medium- and low-speed!) and rebound
  • Tuneable spring rate from „linear to progressive“ by Volume Tuning
  • The ideal partner to complete the MAGURA suspension chassis
  • Intuitive lever positioning
TS RL Rear Shock
TS RL Rear Shock
Magura Interbike Booth
