Magura Interbike Booth
Interbike VTSB
Jude Monica shows us the brake line-up for 2013 that includes the entry level MT2, MT4 with adjustable lever blade options, MTS Specialized brake with special alloy blade and colors, the popular MT6 and the lightest, all carbon fiber MT8 weighing in at 279g.
Jude Monica also takes us through the Magura fork line-up with the entry level TS6 and TS8 for 26″ and 29er that’s available in 80, 100 and 120mm travel and the new TS8 R 150 for the 650B platform that features a tool required 15mm axle and a bracketless 180mm travel rotor adaptation.
Magura Interbike Booth Gallery
of
    Magura TS8 R 150 26" + 27.5"/650B
    • Adjustment possibilities: Adjustable platform compression damping (Albert Select+) or DLO² with dynamic lockout, rebound, preload (air pressure).
    • Travel, weight: TS8 R 150 Fix 26", 1,675g/3,69 lbs (with Maxle lite)
    • Disc mounts: PM 7"
    • Axle to crown length in mm: 530/520
    • Other: Approved for disc brakes up to 210 mm/8.5".
    Magura TS8 R 100 29er
    Onwards and upwards is the theme for 2013 for our Team Suspension. The new Suspension Fork Range features a new design, a new name and new internal componentry. The perfect option for BIG WHEELS comes in the form of our new 29er Forks.
    • Adjustment possibilities: Dynamic Lockout² (DLO²) or Albert Select +, rebound, preload (air pressure).
    • Travel, weight: 120 mm: 1,715 g/3.78 lbs; 100 mm: 1,655 g/3.65 lbs; 80 mm: 1,655 g/3.65 lbs.
    • Disc mounts: PM7" (thru-axle lower leg).
    • Dropouts: Magura M15 thru-axle.
    • Versions, colors: Disc only; white
    • Axle to crown length in mm: 530 mm (TS8 R 120 29 ") / 510 mm (TS8 R 100 29") / 490 mm (TS8 R 80 29")
    • Other: Approved for disc brake use up to 210 mm/8.5".
    Magura TS8 R 80 29er
    Magura TS6 120 29er
    • New travels: 80 mm, 100 mm, 120 mm
    • Travel can be changed internally.
    • PM 7" Disc-mount
    • Same structure as TS8 R
    Magura TS6 120 29er
    • PM 7" Disc-mount
    Magura MTS
    310g and 5 year leak proof warranty.
    Magura MT8
    Stronger. Lighter. Ingenious. With the MT8 Magura presents the worldwide most clever disc brake ever with Carbotecture SL Master and Carbolay lever blade, manufactured in our innovative Carboflow process. Available with 203, 180, 160 and 140 mm diameter. Featherlight carbon 2-finger blade with integrated reach adjust. Fitting bolts made of aluminium.
    • Weight: From 279 g/0.61 lbs. onwards incl. 160 mm Storm SL-Rotor.
    • Colors: Brake lever and caliper in a cool black body with red specials.
    • Guarantee: 5-year leakproof warranty after online registration on magura.com.
    • Designed and manufactured in Germany.
    Magura MT8
    Magura MT6
    Open hydraulic disc brake system with completely integrated reservoir. EBT technology for superfast and convenient bleeding. Dual piston fixed caliper with automatic pad wear adjustment in a smart DAD (Double Arch Design) for maximum stiffness. Pad wear thickness can be checked without removal of the pads. The master is made out of our innovative Carbotecture® SL with a incredible light and durable aluminium lever blade. Featuring a cool look, distinctively enhanced durability and optimized friction performance for stunning brake power. Available with 203, 180, 160 and 140 mm diameter. Featherlight aluminium 2-finger blade with integrated reach adjust.
    • Weight: From 310 g/0.61 lbs. onwards incl. 160 mm Storm SL-Rotor.
    • Colors: Brake lever and caliper in a cool black body with silver specials.
    • Designed and manufactured in Germany!
    Magura MT6
    Magura PM7
    Post mount 7-inch.
    Magura Compression Dampers
    DLO (Dynamic Lockout), AS (Albert Select), SL (Superlight).
    Magura M15 Axle with Tool
    Magura Fork Bottom
    Bottom of fork protected rebound adjust rubber fork protector.
    Magura Fork Bottom
    Bottom of fork protected rebound adjust rubber protection caps.
    2012 Magura Interbike Booth
(Visited 7,914 times, 1 visits today)
