Magura MT6 Brake Review
Brakes
Bottom Line
The Magura MT6 brakes are supremely functional, feature laden and highly engineered, and everything single piece of the brake works in synergy. The lightness is a component of an entire slew of innovative technologies, from the carbon reservoir to the sculptured caliper, and the special alloy bolts. The brakes have a superb tactile feel, which gives rise to an incredible touch, control and communication, and your hands become ‘One’ with the ground/bike interface. The MT6′s offer great modulation, excellent power and heat resistance, and the rotor’s spin drag free through the calipers. The caliper’s design makes them the quietest brake I have ridden, and even getting them extremely hot on long steep downhills never changed their silent characteristic.
They aren’t the most powerful brake on the market, but they more than make up for any deficit, with other remarkable and useful characteristics. They weigh a bit more than the MT8 (only 22 grams), but their alloy lever offers a noticeably firmer feel for a slight increase in control and power. They don’t offer the MT8′s lightweight, bling and looks, but they make up for it with a better price point and lever feel, which are two very beneficial items.
In a nutshell, they are strong, light, quiet, fade free and powerful, modulate well, and have a superb tactile feel from the ergonomic brake lever down into the ground.
Strengths
  • Light
  • Alloy lever is less flexy than MT8′s carbon version
  • Powerful
  • Deadly quiet
  • Excellent tactile feel
  • Great modulation
  • Top loading pads
  • Anti-Features: squeal, heat, drag
Weaknesses
  • Expensive – $269 (though cheaper than the MT8)
  • Clamp barrel nut fragility
  • Slight gabbiness under hard pulls
Overall Rating: 5 Flamin’ Chili Peppers
MSRP: $269
MT6 Specs:
  • Visit the Magura MT8 website at http://www.magura.com/en/products/disc-brakes-2012/prod/mt6-1.html
  • Full carbon master cylinder
  • Carbotecture SL body
  • Alloy lever blade
  • Alloy clamp
  • Alloy fittings
  • Anti-Feature: squeal, heat, drag
  • Feel Safety-Ergonomics
  • EBT (Easy Bleed Technology)
  • EPR (easy pad replacement)
  • Weight From 310 g onwards incl. 160 mm Storm SL-Rotor
  • Colors: Brake lever and caliper in a cool black body with silver special
  • Guarantee: 5-year leakproof warranty after online registration on magura.com
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Justin D says:
    Had the same spongy experience with the mt4′s. All those innovative construction techniques become aggravating when trying to bleed away the SPONGE . Maguras are nice on motorcycles i’d say , but stay away from this whole range , they suck! Shimano xtr’s are on my bike now , wish I had tried them first. Maguras’ carbotechture is a fancy term for plastic, imagine how well that holds up in crashes. Storm sl rotors are nice though. BOOOO MAGURA , BOOOO, back to the drawing board. Use metal next time. Still pissed off with my experience. Run them at your own risk.
    • Brian Mullin says:
      Justin – I never experienced any sponginess, and only had one squishiness session when I got the brake boiling hot? Otherwise, they didn’t give me any issues, and I found the lever feel firm, though it does take them a long throw through the stroke to connect up. It does take a certain technique to bleed them properly, and I only had to do it when the stroke got a bit close to the bars. I have crashed extremely hard with the brakes and they have been tough as nails? Sorry to hear you had issues with them, but I think they are fantastic brakes.
    • Bill Hilow says:
      My Top of the line 2014 Cannondale Trigger Carbon Team 1 came with these Mt6 brakes. I thought it was a joke. They were spongy on delivery. Long lever pull.The levers coming right down and crushing your fingers against the bar. This seemed to improve as the brakes heated but not up to par. I installed new pads and bled bled bled bled bled
      and still not as firm as my SRAM DB5 which are $400 installed! The reservoir bleed screw is soft plastic that strips easily. I think they look trick and have a high wow factor. Other than being really light I don’t think they are worth the price or maintenance headaches. Avoid
    • Bill says:
      I think USA riders have a preference for powerful and more direct feeling brakes. The fact that not only do these lack power they are a not maintenance friendly. It’s one thing to be Joe Euro that has a full truck load of factory sponsored parts and a mechanic and another to be American and self reliant.
      • Bill says:
        I did get them sorted out. They need a special technique of using a thinner than supplied bleed block. You have to bleed them through a few times. there can’t be even a few bubbles. Before buttoning it install the reservoir cap before removing the plunger. Then using a thinner bleed block give the syringe one final blast of juice to set the pads. You should barely be able to slip them onto the discs.
  • dagoat says:
    I have the MT6′s on my 29er RacerX and absolutely love them. Swapped out a sett of early Marta’s for them and I’ll never look back. Strong, light and controllable!
  • Taylor says:
    Can you upgrade to carbon levers on the MT-6? Also the clamp?
      Yes you can. You’ll need a tool to remove the lever blade.
      Per my main man, Jude at Magura responded:
      “Yes you can. I in fact swapped carbon levers to the MT4. No problem.”
      Special tools needed?
      “Not really but the ‘axle’ will need to be pressed out and we have a tool for that. In reality, if you have a drift or deep well socket (about 5 mm) works well.”
