Mark Vanek from Marin Bikes shows us the 2013 Mount Vision XM and Rift Zone 29er. The Mount Vision XM trail bike features Quad 3 suspension system, an Easton cockpit, carbon bar, dropper seatpost, and RockShox Reverb.
The 2013 Rift Zone 29er XC marathon bike, features 100mm travel, updated Enduro brand bearings, SRAM XX/X0 mixed combo, and Easton EA70 XCT tubeless compatible wheelset.
Visit the Marin Interbike Booth on RoadBikeReview here.
×Marin Rift Zone 29er XC Pro
Specifications:- Model Category: Mountain FRS XC/Marathon
- Model Name: Rift Zone 29er XC Pro
- Sizes USA: M L XL XXL
- Model Color: Black Midnight Matte w/Cyan, Silver, and Gray Decals
- Frame: 6061 Alloy 29er Main Frame & Swing Arm, Quad-Link 3.0 100mm Suspension System
- Front Suspension: Fox 32 Float Factory CTD 29er with Kashima Coat and Trail Adjust, 100mm Travel, Tapered Steer Tube and 15QR Through Axle Dropouts with 3 Position Compression Damper Adjustment and Rebound Damping Adjustment
- Rear Suspension: None
- Shift Lever: SRAM X.0, 2x10 Speed Trigger
- Derailleur Front: SRAM X.0 Direct Mount, 2x10 Speed
- Derailleur Rear: Fox Float Factory CTD BV with Kashima Coat and Trail Adjust, 3-Position Compression and Rebound Damping Adjust, 3-Position Trail setting, Air Spring Preload
- Brakes Front: Formula R1 Hydraulic Disc, 7” Rotor
- Brakes Rear: Formula R1 Hydraulic Disc, 6” Rotor
- Brake Levers: Formula R1 with Tool-Free Reach Adjust, Hydraulic
- Pedals: None
- Crankset: SRAM X0, 39/26T
- Bottom Bracket: SRAM Giga X Pipe
- Chain: SRAM PC-1030, 10-Speed
- Cassette: SRAM PG-1070, Power Glide II, 12-36, 10 Speed
- Hub Rear: Easton EA70 XCT
- Hub Front: Easton EA70 XCT
- Tires: Maxxis Ikon, 26” X 2.2” Kevlar Bead
- Rim: Easton EA70 XCT 29er Wheelset
- Saddle: WTB Silverado Team with Nicro Rails
- Seatpost: Easton EC70 Carbon, 400mm
- Stem: Easton EA90, 0 Degree
- Handlebar: Easton EC70 XC Carbon Flat Bar
- Grips: Ergon GA1 EVO
- Headset: FSA Orbit 1.5 ZS, 1 1/8” Top, 1.5” Bottom
- MSRP: $4700
- Pedals: None
- MSRP: $4700
×Marin Team CXR 29er Pro XT
Specifications:- Model Category: Mountain HT
- Model Name: Team CXR 29er Pro XT
- Sizes USA: 15 17 19 20.5 22
- Model Color: Clear Coated Carbon Matte w/Cyan Blue, Gray and White Decals
- Frame: CXR T3 Carbon with Tapered Headtube, Oversized Downtube, Disc Specific
- Front Suspension: Fox 32 Float Factory CTD 29er with Trail Adjust and 100mm Travel, Tapered Steer Tube and 15QR Through Axle Dropouts with 3 Position Compression Damper Adjustment and Rebound Damping Adjustment
- Shift Lever: Shimano XT, 2 Way and Instant Release, 3x10 Speed
- Derailleur Front: Shimano XT, 3x10-Speed
- Derailleur Rear: Shimano XT Shadow Plus
- Pedals: None
- Crankset: Shimano XT, 42/32/24T
- Bottom Bracket: Shimano XT Big Pipe Billet Integrated with Crankset
- Chain: Shimano HG74, 10-Speed
- Cassette: Shimano SLX, 11-36, 10-Speed
- Tires: Continental Race King, 29” x 2.2" with Kevlar Bead
- Rim: Easton EA70 XCT 29er Wheelset, UST Tubeless
- Saddle: WTB Silverado Race
- Headset: FSA Orbit C-40 with cartridge bearings
- MSRP: $4000
×Marin Mount Vision XM8
Specifications:- Model Category: Mountain FRS Trail/Enduro
- Model Name: Mount Vision XM8
- Sizes USA: XS S M L XL
- Frame: 6061 Main Frame & Swing Arm, Quad-Link 3.0 140mm Suspension System with 142 x 12mm Shimano E-Thru Rear Axle
- Front Suspension: Fox 32 Float Performance CTD, 140mm Travel, Tapered Steer Tube and 15QR Through Axle Dropouts with 3 Position Compression Damper Adjustment and Rebound Damping Adjustment
- Rear Suspension: Fox Float Performance CTD BV, 3-Position Compression and Rebound Damping Adjust, Air Spring Preload
- Derailleur Front: Shimano XT, Direct Mount, 3x10-Speed
- Brakes Front: Formula R1-X Hydraulic Disc, 7” Rotor
- Brakes Rear: Formula R1-X Hydraulic Disc, 6” Rotor
- Brake Levers: Formula R1, Hydraulic
- Pedals: None
- Chain: Shimano XT, 10-Speed
- Hub Rear: Easton Vice
- Hub Front: Easton Vice
- Tires: Maxxis Ardent, 26" x 2.25", Folding
- Rim: Easton Vice
- Saddle: WTB VOLT Comp
- Seatpost: X-Fusion HILO 125mm with remote
- Stem: Marin OS Alloy Threadless, 31.8mm Bar Clamp
- Handlebar: Marin 7050 Alloy, OS-31.8mm, 710mm Wide, 25mm Rise
- Headset: FSA Orbit 1.5 ZSE, 1 1/8” Top, 1.5” Bottom
- MSRP: $3500
×Marin Mount Vision XM Pro
With 120mm of travel and a redesigned frame for 2008, the QUAD XC is lighter and sharper handling than the QUAD Trail and QUAD XLT. For those who want to cover any terrain as fast as possible, a QUAD XC model is the way to go.
(Visited 8,084 times, 1 visits today)
I keep wishing they bring back the Quadlink II in some form.
marin; get at me I got THE ideas!
