Markus Stöckl hits 104mph on standard mountain bike
Austrian pilots Mondraker downhill bike to record setting speed in Chile
Video
Markus ‘Max’ Stöckl Hits 104mph on Mountain Bike
Stöckl’s specially designed, figure-hugging suit effectively had rudders attached to his legs under the skin-tight material.
For two years, Markus ‘Max’ Stöckl laid out a plan to put himself in the record books. And in just 11 seconds and at a speed of 167.6kph (104mp) with a standard mountain bike, whose components you could buy yourself, he reached that speed hurtling down a mountain with no name in Chile’s Atacama Desert. Press play to see for yourself.
Stöckl has a penchant for the record books. Brought up in Austria’s Tyrol mountains, his thirst for speed was established at a young age, his place in the speed annuals first cemented in 1999. In the interim, he set records at the French ski resort of Les Arcs and on a volcano in Nicaragua among others. For his latest attempt on December 13, sealed following eight practice runs, took place in the barren Chilean desert with barely anything in sight from where he set off at around 13,000 feet.
Put your hand out the window while driving on the highway and you get a small sense of the forces at work on Stöckl’s body.
With the gravel slope of 45 degrees deemed the perfect angle for his record, the 43-year-old’s pulse hit 170 beats per minute, the wind whistling past his ears on a 1,200-metre descent. Here’s a bird’s eye view of the record-setting descent. Check out that dust trail!
Speaking emotionally moments after the finish and his latest record, he said: “I’m back on the mountain without a name in the middle of the desert,” said Stöckl. “It’s tricky because it’s all rocky and loose at the start. It was such a long time and standing up there was like we already cried at the start. It was great fun.”
This Mondraker Summam Carbon has gone faster than most mountain bikes get going on the roof of a car.
But for Stöckl, as thrilling as the successful record attempt was, it was just as much about the two years in its making. “The whole project is an adventure,” he said. “This is the top bit of it but also travelling here with all the stuff and making our way through the middle of the desert.”
Stöckl’s carbon fiber helmet, outfit and bike were all tested in a wind tunnel to find the best design and seating position for his latest record attempt.
His journey to 100kph and then 120, he insisted, was straight forward but, as the descent ran out, the increased speed was harder to come by. “It’s hard to reach top speed,” he explained. “After 160, each kilometer is a huge effort. If you want to reach a certain goal then you have to put it all in.”
Here’s what the descent looked like from Stöckl’s perspective.
Stöckl was a sight to behold on the bike. In a specially designed, figure-hugging suit, he effectively had rudders attached to his legs under the material and a helmet in two parts, the first a normal helmet, the second aerodynamically designed to ensure the less air resistance possible, the logic being the less air resistance, the quicker he could go. A carbon fiber helmet, outfit and bike were all tested in a wind tunnel to find the best design and seating position for his latest record attempt.
The now 43-year-old has been setting speed records since the late 1990s.
But perhaps the most notable part of the record attempt is that the bike is one that any consumer could put together… albeit with some effort and expertise. “It’s a standard mountain bike so there’s no part on the bike that you cannot buy,” he added. “Sure, it’s a high-end bike with the best parts of it but you can buy any part, nothing has been specially made.”
Max speed: 104mph
The preparation to get there included testing runs on all manner of surfaces from the snow of home to the Chilean mountains, including his fair share of falls. Whether this latest record has quenched his thirst for the record books remains to be seen. Lying on the ground fresh after the attempt, he spoke of a desire to return home to his family.
The starting point was at about 13,000 feet.
“It’s important that it feels like an adventure,” he said. “We are travelling to another continent, heading into the desert for countless hours, sleeping in tents under the mountain with a good bunch of guys. It all makes for so much excitement. You never know what is going to happen from a start point before you try it.”
The footage, firing out a cloud of dust visible from some distance, suggests the record itself was fairly straightforward but Stöckl admits to being perpetually on the precipice of just one wrong move, his only protection being a built-in airbag to his riding outfit.
“When above 160kph, every extra kilometer per hour requires an enormous effort,” he said. “If you want to get an idea of the air resistance, you only have to stick your hand out of the car window when you’re driving at 150 or 160 kph. This force has an impact on the bike and the entire body. Even though I’m no weakling, physically it is something that I have to contend with too.”
Check out more mountain bike video action on Mtbr.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
