Marzocchi 55 RC3 Ti Review
Forks Pro Reviews
rc3_final
Bottom Line
The Marzocchi 55 RC3 Titanium exemplifies the buttery smooth plushness of a coil, ahhh! I have ridden many air forks, and although they offer a much larger degree of tunability and travel adjustment, they just do not match the pure linear feel of a coil. Once you lived with a coil, it is certainly hard to go back. The 55 RC3 Ti is a sweet fork, and offers many features, such as the open bath RC3 cartridge damper, the titanium coils, the Nickel stanchions, subtle tuning adjustments, the MDU bottom bumpers, and the QR20 thru axle. The adjustment dials are hard on the hands, and difficult to move (2011 have different dials), but aren’t really needed with a coil.
The Marzocchi 55 RC3 Titanium has been durable and tough with the abuses, I have tossed it at, and it sure is quiet. “Nothing rides quite like a coil”.
Strengths
- Coil Preload
- RC3 cartridge
- Titanium Spring
- Nickel Coated Stanchions
- QR20 quick release axle
- Linear and buttery smooth coil!
Weaknesses
- Adjuster dials: tough on hands & hard to move
- Heavy
- Ramp up steeply on big hits
MSRP: $1029
Overall Rating: 4 Flamin’ Chili Peppers
Marzocchi Specs:
55 RC3 Titanium 1,5″ / 2010
55 RC3 Titanium / 2010
Tech specifications
- 160mm Travel
- Coil Preload
- RC3 (Air Preload, Hi/Lo Compression, Rebound)
- Titanium Spring
- 1,5″ Alloy Steer Tube and Crown
- 35mm Nickel Coated Alloy Tapered Stanchions
- New fitted and slotted bushing
- 6” Post Mount (Max Disc 8”)
- 20mm quick release axle
Stroke: 160mm
Fork length: 548 mm
Steer tube-wheel offset 44mm
Weight: 2438 g
Marzocchi 55 RC3 Ti url
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Westman says:
    Most zocchi open bath forks have always come with too much oil in them. If some was removed then full travel was achievable.
    Oh, also, why do you say it has High- and Low-speed compression if it only has one dial? If that is true then it only has a compression adjustment. (which in turn affects both at the same time, but they are not independently adjustable!)
  • Craigstr says:
    Wait till it starts creaking and leaking oil, then how much will you like it? The recent Marzocchi forks have horrible reliability.
    • Dan says:
      Only the 08/09 models, when they got bought out by Tenneco, and moved manufacturing to Taiwan. Marzocchi were back to form by 2010.
  • Smash says:
    Why is that adjustments are really needed with a coil-sprung fork exactly?
    “The Marzocchi 55 RC3 Titanium has been durable and tough with the abuses, I have tossed it at, and it sure is quiet. ” What?
  • Brian Mullin says:
    Westman: If I get a chance, I will try checking the oil level, thks for the info. Yes it is a compression adjustment, but as far as I know it affects both the high speed and low speed circuits.
    Craigstr: Ask me in six months to a year on the long term reliability, so far it has been fine, and I can only judge my findings.
    Smash: Adjustments allow some subtle fine tuning, and it does cause a change, but I agree they are really needed. Not sure of your question on the last statement, but in regard to it being quiet, most forks make all sort of noises depending on the bump size, and the RC3 Ti was absolutely deadly silent?
  • Craigstr says:
    Mine lasted about 6 months then all the gremlins started coming out.
  • warp says:
    I didn’t know the new Zoke’s have the air preload on the damper side. Which is kinda dumb if you don’t have different spring weights offered for lighter and heavier riders. Point is, the damper side has the smaller of the air chambers in a Zoke and putting any air pressure in there will ramp up heavily by the end of the stroke. Why not do it like the older Z1′s with air valves on both?? That allows you to fine tune the fork AND fine tune for big hits. Yeah, it adds a little complication but it very well pays off.
  • mark merano says:
    Zoke sucks now. Sorry, but they’ve ripped me off and lots of others and it should not be an easy road back for them. At least when Rock Shox made their comeback, SRAM was offering them (and still does) for bargains to win over customers.
  • Ecogeek says:
    I agree with the others on reliability. Marzocchi are totally unreliable waste of time imo too.
    Would not advise anybody and I mean anybody to take a risk on any model for any price. I only used Marz for 10 years then got three bad 55s in a row last year. That’s it. Went to Rockshox who thanks to SRAM are now much much better.
    Lyrik blows the 55 away completely. Esp the 2-step. Dual compression independantly adjustable too. And if the 55 ramps anyway then the Lyrik air would really slay it.
    Until we start seeing Zoke forks with decent scores in the MTBR user reviews for a couple of years, they cannot be recommended. Just a headache and a false economy at any price. None should come from the factory with any issue. Travel range. Leaks. Spiking. Nothing. Knobs that don’t turn… But they all seem to have something not right from the start and a lot more soon enough. The 55 is particularly nasty imo and you’ll prob see catastrophic bushing play soon.
  • mo says:
    I have ridden fox and rock shox alot in a very abusive environment the only fork that does not leak oil is zocchi. The are a very reliable fork and if yours breaks in 6 months you still have 2 and half years to warranty it. the 2010 bushing system in the marzocchis is very similar to the 2005 marzocchis. The 55 is way lighter then any other trail fork. they also have been doing amazing deals for people in the industry. Go try a new marzocchi before you dismiss them.
  • humdinger says:
    Lyrik slays the 55???? Are you crazy? The Lyrik is a great fork, but ONLY the coil UT. Ecogeek, sorry you lost any credibility by saying the 2-step’s a great fork. The Lyrik 2-step is THE MOST reliably unreliable fork on the market, bar none. You evidently owned the 2009 55s which were indeed a heap of poo, fair comment, but they are fundementally completely different to the 2010/2011 models.
    Mo is on the money, this new 55 is absolutely superb. I have owned the Lyrik Coil, 2011 Float 36 Kashima, and numerous others, and this new Zocchi 55 rc3 Ti rules out top by a significant margin.
    Fair enough, Zocchi have had serious issues in recent years and lost a lot of loyalty, rightly so. But with the 3 year warranty and the fact the buttery Zocchi performance is back from the good old days means forget the last few years and start enjoying the mighty bomber again.
  • kovalDESIGN says:
    I did not try the new RC3 Ti but for the money I would choose the Lyrik/Fox 36 over the Marzocchi anytime.
    I tried however the first bunch of the 55′s released in 2008 – these were a big disappointment moving from the superb Z1 Light RC2.
    55′s adjustment knobs finish was really poor and they were falling off in your fingers – I sold my 55 ATA2 and ETA before they broke and for some extra cash I moved over to FOX 36.
    humdinger: if you say the RC3 Ti rules then I hope it does, it’s top of the shelf forks eventually.
    I only wish the cheaper 55′s (R, RV, TST, ATA) have the same reliability.
  • steadite says:
    how can someone who’s “never ridden a coil fork before” write a “pro review” on a coil fork??
