by Rob Sutton from Mountain Biking by 198
http://www.mtbtrailreview.com
The second ride on the Ardents changed my opinion on their performance due to a critical change in air pressure. I lowered the front another couple psi to the 26 lbs. range and the tire performed so well that I had to re-write this review.
I took the Ardents up to Pinhoti 2, 3 and 4 up in the north Georgia mountains over the weekend to get some long mile testing in. The Pinhoti’s are known for providing some of the best single track that Georgia can provide. Great tight, twisty downhills with long steep climbs get your heart rate peaked no matter which way you are headed.
To get full use out of these new tires from Maxxis, I mounted them up to the Flow rims on the Moots Mooto-X 29er 1×9 previously reviewed on this site. Luckily, a birthday ride for a fellow riding friend provided the perfect excuse to get up there and really throw the tires around.
MOUNTING
These tires went on very easily, almost too easily. Using my floor pump, I was not able to air up the tires tubeless, so I threw in some light 26″ tubes. Everything air up perfectly and the bead popped into the rim. I left the tires at 40 psi over night and then lowered them down to 28 psi for the ride. For the next ride, I am going to release one of the beads and attempt the tubeless route again.
THE RIDE
The first thing I noticed with these tires is that they roll incredibly fast. The center tread has very little rolling resistance which makes pedaling very efficient on climbs and flats. During the climbs, there were a few instances that the tires lost traction, but these were in very steep sections. This bike is also set up 1×9, so I don’t think the tires would have lost it in a granny ring situation climbing correctly. When the trail started pointing down, the tires did not disappoint. On the straights, the tires felt great. The low rolling resistance and consistent center tread made for a fast tire in the flats and straight downhills. When the trail got really twisty, they started to lose traction and pretty easily. I was struggling to keep them on the trail at speed. After letting some air out from the 28 psi baseline, the traction got a little better, but not much. The tires were actually making me nervous about going off of these tight trails. Now, the trail was dry and there was a lot of lose dirt and leaves that makes any tire a bear to handle, so this had an effect on the tires handling. At this point, I lowered the pressure some more down into the 26 psi range and the front tire came alive. The traction in the turns increased 10 times over and it was no holding incredibly well in the loose turns. At this psi, I would normally be worried about pinch flats, but even through rock gardens and jumps…I had zero issues with pressure loss or flats.
HOW IT STACKS UP TO THE COMPETITION
These are the other tires that I have ridden on 29er’s.
- Specialized Resolution 2.3
- WTB Stout 2.3
- Kenda Nevegal 2.2
The Ardent tread pattern has huge potential. After I lowered the front pressure, these tires are at least on par and in certain situations better than their competition. In the future, I would like to see a 2.4 version with the specs below for a true AM 29er tire that can really do anything.
My 2.4 Ardent 29er Proposal
- More Tread – The tread height is pretty low for an all mountain tire. Add a little bit of height and they should be set.
- Tread – Widen the tread blocks. This added with the increased height should square the tire off a little bit more and really let the side and transitional knobs do their job. It will also bring the transitional knobs closer to the side and center tread which will increase the grip.
- Volume – Increased volume will help even more in rock gardens and jump situations.
CONCLUSIONS
Maxxis has a real winner with the Ardent tread pattern. It is a fast rolling tire that also grips incredibly well in the turns. For the average 29er rider, these are going to be the perfect tire for everyday riding. Even pushed to the limit, these tires perform incredibly well for a 2.25. I would like to see a 2.4 offering out of Maxxis to fulfill my want/need for a big 29er tire, but in the meantime, this 2.25 Ardent has turned into my favorite 29er tire so far.
This article originally posted on the blog site: Mountain Biking by 198 ( http://www.mtbtrailreview.com/blog/maxxis-ardent-29er-tested/featured/ ).
by Robb Sutton from Mountain Biking by 198
Nice write up, looking forward to this tire hitting the mainstream…
It looks like that tire has some pretty big gaps between the knobs….something I don’t really like since it makes them more prone to flats where I ride. If the knob were a little bigger/taller like you suggest, it probably would be a better mud tire.
Do you have any true #’s on the tire? Mass, width, height??
Too bad Maxxis has been so slow on the 29er tires.
You can find the sizes on my site here. (digital calipers)
http://www.mtbtrailreview.com/blog/maxxis-29er-ardents-mounted/parts/
The only issue I have with both the Ardent and the Advantage is that the sidewalls are a bit thin and you get sidewall tears frequently when running tubeless in rocky terrain, especially sharp rocks. Maxxis has said that they are going to be making the sidewalls a bit beefier, I contacted them and waiting on the results of that question.
