milKit Booster tire inflator — and water bottle
Small in size, simple to use, and you can drink out of it
Gear Sea Otter Classic
milKit Booster System
milKit co-founder Pius Kobler shows how easy it is to inflate a tubeless tire using their Booster system.
Swiss company milKit came on the scene a few years ago with their innovative approach to tubeless tire valve systems. Now they are back with their new milKit Booster. The Booster is a new spin on the tubeless tire canister idea that also doubles as a water bottle when not needed to inflate tires. It’s even sized to fit in a standard water bottle cage in the 20oz version. This can be helpful when having trouble seating a stubborn tubeless tire bead while out on the trail or for anyone who doesn’t have an air compressor in their garage.
The milKit Booster can be used as a water bottle, but in times of need it will double as a tubeless tire inflator. Photo courtesy of milKit
The milKit Booster is simple to use. Combined with milKit’s well-designed valves and fittings, an aluminum bottle makes the basis of the Booster system, which works in three simple steps:
1. Inflate the booster with your tire pump
2. Remove the valve core from your tubeless valves (optional)
3. Push the Booster onto the valve stem and inflate the tire
Booster Use Diagram
The milKit Booster is quite easy to use at home or on the trail. Photo courtesy of milKit
Because there are no hoses or additional valves to reduce air flow, seating a tubeless tire with the milKit Booster should be fast and efficient. The milKit Booster comes in two sizes: 1L (34oz) $50 and 0.60L (20oz) $48. It weighs 138g for the 20z Booster.
For more information, visit milkit.bike. This article is part of Mtbr’s coverage of the 2018 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
About the author: Justin Wages
As a stage 4 colon cancer survivor, Justin Wages got into the cycling world in an effort to increase his endurance after losing his left lung. As a California native and growing up with a skateboard and snowboard beneath his feet it wasn’t long before the thrill of mountain biking gripped him. Justin’s day job as a Land & Recreation Manager helps him understand the balance between conservation and trail use. He also works with his fiancé, Jeni, to bring more women into the mountain bike world with certified skills clinics and education. “My goal is to get more people on trails for health and enjoyment,” he says. “I want to help them overcome their mental or physical limitations and be the best person they can be, while expanding their appreciation for our natural world.”
