Motobecane Interbike 2014
Boris, NightTrain and Sturgis Fat Bikes, Fantom 27.5/29er Titanium and Fantom Cross Titanium
Interbike Sponsored post
Motobecane USA is not at the Interbike show this year, so here is their ‘virtual’ booth for your viewing pleasure.
Presenting an incredible line up of new Motobecane USA bicycles for 2015 and beyond.
We are dominating the Fat Bike market with more models than any other brands.
2015 Motobecane Boris X9 Fat Bike
Motobecane USA is the only brand that has models made of nearly every material available. High Grade steel, Titanium, Aluminum and Carbon.
Amazing handling Fat Bikes, 29ers to 27.5 Titanium models. Advanced Full suspension with up to 6 inches of terrain eating travel.
Gallery: Motobecane Boris, NightTrain and Sturgis Fat Bikes, Fantom 27.5/29er Titanium and Fantom Cross Titanium
Motobecane Interbike 2014 Gallery
of
2015 Motobecane NightTrain Fat Bike
  • Frame: Motobecane Hydroformed Aluminum Alloy 6061 Frame w/Disc Mount, TIG Weld, replaceable rear derailleur hanger, H2O bosses, Tapered Head Tube: ALLOY 1-1/8" / 1.5" (50x44/62x55.95mm), L: 39/45/48/53CM = 110/120/135/150mm, B.B. Shell: Alloy 100mm, Alloy (34.9xt2.25mm) w/FD Bracket,. For 30.9 S/Post, 190mm Thru-Axle Rear. Internal Downtube cable routings.
  • Fork: Kinesis, 26" Fat Bike: CR-MO Steerer tube (1-1/8" TO 1.5" Taper) w/0 Thread. L: 265mm , Blade: Alloy 6061, Thru-Axle:150mm, w/ Post Disc Mount, w/Alloy 7075 QR 15mm, TriFecta Fork brazeons
  • Crankset: SAMOX, 10 Spd, 22x36T, Alloy Sand Black CTL Crank 175mm + 10mm Axle Washers
  • Bottom Bracket: EB-2401 BB-100mm
  • Pedals: n/a
  • Front Derailleur: SRAM FD X7 LDM 2X10 S3 36T STGR Dual Pull
  • Rear Derailleur: SRAM RD X9 Type 2 Long Cage 10pd GRY
  • Shifters: SRAM SL Trigger X7 10Spd BLK
  • Cassette/Freewheel: SRAM CS-PG-1030 11-36
  • Chain: KMC X10SL Super Light Narrow CN 1/2"x11/128"x112L.w/Hollow Pin, Including CL559S NP Reusable Link
  • Hubs: F/Hub(HB) T Novatec Front Disc Hub 32H, 15mmx150mm Thru-Axle. Polished Anod Black, F/Hub Axle Alloy 7075 xM15xP1.5, Black ANOD., R/Hub(FH) T Novatec X12MM, Rear Disc Hub 32H. Thru-Axle:12x190mm, Polished ANOD Black
  • Spokes: 14G Steel Stainless w/Brass Nipple
  • Rims: Weinmann HL80 Alloy Single Wall 26" x 73/80xH24 , 26x3.0-4-1/2 ,32H,W/FV Black ANOD w/o Eyelet, w/o CNC , w/ Big Holes ( 32mm ) / 14Gx64PCS Stainless w/Brass 14mm Nippe (NOTE: Rimstrips will be Black with Extra set of Red in boxes)
  • Tires/Tubes: Vee Rubber 26X4.5 VRB370 Snow Shoe SBK 120TPI Silica Comp. Foldable Light weight
  • Brakes :SRAM Guide RS Hydraulic Disc Brake, 180mm Rotor, Gloss Black
  • Brake Levers: SRAM Guide RS Hydraulic Disc Brake
  • Headset: FSA Orbit 1.5 ZS , For 1-1/8" / 1.5" Fork Stem, Internal Alloy Cups, 1-1/8" ACB Upper, 1.5" ACB Lower,w/Std 12.3mm top cover (H2051B) , W/39.78 Ball Race ( 28.6x44/55.95x39.78mm)
  • Handlebar: Alloy 6061 Rise H/Bar ( 9° ) B/Center: 31.8mm.R/W:20/700mm. S.B BLK
  • Stem: Alloy 6061 "TIOGA-OS" A-Head Stem.EXT:(7°)90/100/110/120MM FOR 39 / 45 / 48 / 53CM ,C/S:31.8x28.6x41mm. S.B.BK
  • Tape/Grip: WTB Dual DNA Compounds, Classic Logo
  • Saddle: WTB Speed V Sport SE Vinyl Top
  • Seat Post: 6061 Alloy Sand Blast BLK S/Post w/ Alloy ED BLK Head, 30.9 X 400mm
  • Seat Post Clamp: 34.9 ALLOY - Bolt
  • List Price: $3699
  • Street Price:: $1199.95
Specs subject to change to meet production logistics or manufacturer upgrades.
Super wide tires “float” over snow and sand. The fastest bikes you’ll ever ride on mud, bogs, deep sand and snow. As a bonus, they’re great convo makers and super smile-generators.
  • Frame: Alloy 6061 Frame, w/Disc Mount Only, TIG Weld, replaceable rear derailleur hanger, H2O bosses
  • Fork: 26" 25.4x28.6x30x250L Straight blade CRMO 1 1/8 w/Disc Mount Only
  • Crankset: SRAM X5 22T Alloy BKx36T Alloy BKx175MM
  • Bottom Bracket: SRAM GXP100 100x1.37
  • Pedals: VP-530 Alloy Black w/CPSC Reflector
  • Front Derailleur: SRAM FD-X7 2x10 High Direct Mount
  • Rear Derailleur: SRAM RD-X9 Gray Cage 10Spd
  • Shifters: SRAM SL-X7 Trigger 20-Sp Black
  • Cassette/Freewheel: SRAM PG-1030 10-Speed 11-36
  • Chain: KMC X-10 Steel NP/NP+CL-566R Link
  • Hubs: Front 14Gx32Hx135mm Alloy Black, w/QR; Rear 14Gx32Hx170mm QL205Y Alloy Black
  • Rims: 26"x32H Weinmann HL-80 Width 80mm w/Big Holes, Alloy Black
  • Tires/Tubes: Vee Rubber 26"x4.0 Mission 120TPI FB F/V
  • Brakes: Avid BB7 Disc Brake w/F:180mm,R:16mm Rotor
  • Brake Levers: Avid FR5 Alloy Black Lever w/Alloy
  • Headset: VP-A42E Black w/M-1D Alloy Black Cap
  • Handlebar: 31.8mm W:700mmx9 Degrees, Alloy Black
  • Stem: Alloy, A-Head 15":80mm 17":80mm 19":90mm 21": 100mmx R:45mmx7 Deg
  • Tape/Grip: 130mm, All Black, Super Light Foam
  • Seat Post: Alloy 31.6mm x 350mm Aluminum
  • Seat Post Clamp: 34.9 Alloy, Q/R
  • List Price: $2499
  • Street Price: $799.95
2015 Motobecane NightTrain Bullet RockShox Bluto Fork Fat Bike
  • Frame: Motobecane Hydroformed Aluminum Alloy 6061 Frame, w/Disc Mount, TIG Weld, replaceable rear derailleur hanger, H2O bosses, Tapered Head Tube: Alloy 1-1/8" / 1.5" (50x44/62x55.95mm), L: 39/45/48/53CM = 110/120/135/150mm, B.B. Shell: Alloy 100mm, Alloy (34.9xt2.25mm) w/FD Bracket,. for 30.9 S/Post, 190mm Thru-Axle Rear. Internal Downtube cable routings.
  • Fork: Rock Shox Bluto, Steerer tube: Alloy 1-1/8" to 1.5" Taper w/0 Thread Crown: Forged, AL66 TV aluminum ( 116mm for tire clearance ), Stanchion: 32mm, Low friction anodize Fast Black, Blade: Magnesium, post mount, Travel: 120mm,W/15x150 Maxle Lite, Solo Air
  • Pedals: n/a
  • Rear DerailleurL SRAM RD X9 Type 2  Long Cage 10Spd GRY
  • Hubs: F/Hub(HB) T Novatec Front Disc Hub 32H, 15mmx150mm Thru-Axle. Polished ANOD. Black, F/Hub Axle Alloy 7075 xM15xP1.5, Black ANOD., R/Hub(FH) T Novatec X12mm, Rear Disc Hub 32H. Thru-Axle:12x190mm, Polished ANOD. Black. (NOTE: Rimstrips will be Black with Extra set of Red in boxes)
  • Rims: Weinmann HL80 Alloy Single Wall 26" x 73/80xH24 , 26x3.0-4-1/2 ,32H,W/FV Black ANOD.w/o Eyelet, w/o CNC , w/Big Holes ( 32mm ) / 14Gx64PCS Stainless w/Brass 14mm Nipple
  • Brakes: SRAM Guide RS Hydraulic Disc Brake, 180mm Rotor, Gloss Black
  • Headset: FSA Orbit 1.5 ZS , FOR 1-1/8" / 1.5" Fork Stem, Internal Alloy Cups, 1-1/8" ACB Upper, 1.5" ACB Lower,w/Std 12.3mm top cover (H2051B) , W/39.78 BALL RACE ( 28.6x44/55.95x39.78mm)
  • Stem: Alloy 6061 "TIOGA-OS" A-HEAD Stem.EXT:(7°)90/100/110/120MM FOR 39 / 45 / 48 / 53CM ,C/S:31.8x28.6x41mm. S.B.BK
  • Seat Post: 6061 Alloy Sand Blast BLK S/Post w/Alloy ED BLK Head , 30.9 X 400mm
  • Seat Post Clamp: 34.9 Alloy - Bolt
  • List Price: $3999
  • Street Price: $1499.95
2015 Motobecane Sturgis Bullet Fat Bike
Same Top-of-the-line Hydroformed Aluminum frame as the NightTrain Fatbikes.
  • Frame: Motobecane Hydroformed Aluminum Alloy 6061 Frame, w/Disc Mount, TIG Weld, replaceable rear derailleur hanger, H2O bosses, Tapered Head Tube: Alloy 1-1/8" / 1.5" (50x44/62x55.95mm), L: 39/45/48/53CM = 110/120/135/150mm, B.B. Shell: Alloy 100mm, Alloy (34.9xt2.25mm) W/FD Bracket, For 30.9 S/Post, 190mm Thru-Axle Rear. Internal Downtube cable routings.
  • Fork: RockShox Bluto, Steerer tube: Alloy 1-1/8" to 1.5" Taper w/0 Thread Crown: Forged, AL66 TV aluminum ( 116mm for tire clearance ), Stanchion: 32mm, Low friction anodize Fast Black, Blade: Magnesium, post mount, Travel: 120mm,W/15x150 Maxle Lite, Solo Air
  • Pedals: n/a
  • Rear Derailleur:  SRAM RD X7 Type 2 (Clutch) Long Cage 10Spd BLK
  • Shifters: SRAM SL-X5 Trigger BLK
  • Hubs: F/Hub(HB) T Novatec Front Disc Hub 32H, 15mmx150mm Thru-Axle. Polished ANOD. Black, F/Hub Axle Alloy 7075 xM15xP1.5, Black ANOD., R/Hub(FH) T Novatec X12mm, Rear Disc Hub 32H. Thru-Axle:12x190MM, Polished ANOD. Black
  • Rims: Weinmann HL80 Alloy Single Wall 26" x 73/80xH24 , 26x3.0-4-1/2 ,32H,w/FV Black ANOD.w/o Eyelet, w/o CNC , w/ Big Holes ( 32mm ) / 14Gx64PCS Stainless w/Brass 14mm Nipple. (NOTE: Rimstrips will be Black with Extra set of Red in boxes)
  • Tires/Tubes: Vee Rubber 26X4.5 Snow Shoe SBK 72TPI Foldable
  • Brakes: Tektro Draco, Hydraulic Disc Brakes w/180mm Rotor
  • Brake Levers: Tektro Draco, Hydraulic Disc Brakes
  • Seat Post: 6061 Alloy Sand Blast BLK S/Post w/Alloy  ED BLK Head, 30.9 X 400mm
  • List Price: $3299
  • Street Price: $1299.95
2015 Motobecane Sturgis Fat Bike
  • Frame Motobecane Hydroformed Aluminum Alloy 6061 Frame, w/Disc Mount, TIG Weld, replaceable rear derailleur hanger, H2O bosses, Tapered Head Tube: Alloy 1-1/8" / 1.5" (50x44/62x55.95mm), L: 39/45/48/53CM = 110/120/135/150mm, B.B. ShellL: Alloy 100mm, Alloy (34.9xt2.25mm) w/FD Bracket,. For 30.9 S/Post, 190mm Thru-Axle Rear. Internal Downtube cable routings.
  • Fork: Kinesis, 26" Fat Bike: CR-MO Steerer tube (1-1/8" TO 1.5" Taper) w/0 Thread.L: 265mm , BLADE: ALLOY 6061, Thru-Axle:150mm, w/Post Disc Mount, w/Alloy 7075 QR 15mm, TriFecta Fork brazeons
  • Crankset: SAMOX, 10 SPD, 22x36T, Alloy Sand Black CTL Crank 175mm + 10mm Axle Washers
  • Pedals: n/a
  • Cassette/Freewheel: SRAM CS-PG-1030-A1 ( 00.2418.001.030 ) CS-PG-1030 11-36
  • Chain: KMC X10SL Super Light Narrow CN 1/2"x11/128"x112L.W/Hollow Pin, Including CL559S NP Reusable Link
  • Hubs: F/Hub(HB) T Novatec Front Disc Hub 32H, 15mmx150mm Thru-Axle. Polsihed ANOD. Black, F/Hub Axle Alloy 7075 xM15xP1.5, Black ANOD., R/Hub(FH) T Novatec X12MM, Rear Disc Hub 32H. Thru-Axle:12x190mm, Polished ANOD. Black
  • Rims: Weinmann HL80 Alloy Single Wall 26" x 73/80xH24 , 26x3.0-4-1/2 ,32H,W/FV Black ANOD.w/o Eyelet, w/o CNC , w/ Big Holes ( 32mm ) / 14Gx64PCS Stainless w/Brass 14mm Nipple. (NOTE: Rimstrips will be Black with Extra set of Red in boxes)
  • Headset: FSA Orbit 1.5 ZS, 1.5" Fork Stem,, Internal Alloy Cups, 1-1/8" ACB Upper, 1.5" ACB Lower,w/Std 12.3mm top cover (H2051B) , W/39.78 Ball Race ( 28.6x44/55.95x39.78mm)
  • List Price: $2999
  • Street Price: $999.95
Motobecane Boris X7 Fat Bike
Advanced Hydroformed Aluminum with lowered top tubes for trail-ready performance.
  • Pedals: n/a
  • Headset: FSA Orbit 1.5 ZS , FOR 1-1/8" / 1.5" Fork Stem, Internal Alloy Cups, 1-1/8" ACB Upper, 1.5" ACB Lower,w/Std 12.3mm top cover (H2051B) , W/39.78 Ball Race ( 28.6x44/55.95x39.78mm)
  • List: $2999
  • Frame: ALLOY 6061 Frame, w/Disc Mount, TIG Weld, replaceable rear derailleur hanger, H2O bosses
  • Crankset: Lasco GOX 22/36T Alloy BKx175mm Alloy Black Crank w/o Chaincover
  • Bottom Bracket: Lasco 100x1.37
  • Rear Derailleur: SRAM RD-X7 Silver Cage
  • Shifters: SRAM SL-X5 Trigger 20-SP Black
  • Cassette/Freewheel: SRAM PG-1030 11-36T-10
  • Chain: KMC X-10
  • Hubs: Front 14Gx32Hx135mm alloy Black w/QR / Rear 14Gx32Hx170mm alloy Black
  • Spokes: 4G Steel Stainless w/Brass Nipple
  • Rims: 26"x32H Weinmann HL80  Width 80mm w/Big Holes Alloy Black
  • Tires/Tubes: 26"x4.0 Vee 8 72TPI
  • Brakes: Avid BB5 Disc Brake W/F:180mm,R:160mm Rotor
  • Brake Levers: Tektro ML-520 Alloy Black Lever
  • Handlebar: Kalloy W: 700mmx9 Degrees, Alloy Black
  • Stem: Kalloy AS-007 EXT:80mm(15"~17")/90mm(19")/100mm(21")x7 Degrees, Alloy Black
  • Seat Post: Alloy 350mm, Alloy Black aluminum
  • List Price: $1599
  • Street Price: $699.95
Motobecane Fantom FB4 Comp Fat Bike
  • Frame: Alloy 6061 Frame, w/Disc Mount, TIG Weld, replaceable rear derailleur hanger, H2O bosse
  • Fork: 26" Rigid Fork, Alloy Stem, 1-1/8" Threadless, Alloy Blade 34.9mmx2.0 T Taper 28mmx200L, w/o Pivot, w/Disc Mount Only
  • Crankset: SAMOX 1/2"x11/128"x22T x32T x44T, Alloy Crank 175mm With BCD104 4 Arm, EB2401 BB Set For 9-SP
  • Bottom Bracket: Ball Bearing Cartridge BB
  • Pedals: n/a
  • Front Derailleur: Shimano Front Derailleur, FD-M660-E, SLX, E-Type, Top Swing, Dual-Pull, CS Angle: 66-69, For 44T, KFDM660E6
  • Rear Derailleur: Shimano Rear Derailleur, RD-M390-L, ACERA, SGS 9-Speed
  • Shifters: Shimano SL-M390, ACERA 27 speed trigger shift
  • Cassette/Freewheel: Shimano CS-HG20 9-Speed Brown 11-13-15-17-20-23-26-30-34T
  • Chain: 120 Steel, 1/2"x 11/128"x120L
  • Hubs: Alloy Disc Hub, 14Gx32H, M9x135x145, W/QR in Black, Ball Bearing, Freehub 9/10SP(Alloy Shimano Cassette Body).14/32 M10*135*145mm CR-MO Axle, Finish: Anodized Black Ball Bearing Rim Strip 1 26", Nylon, Width: 95mm, / Rim Strip 1 26", Nylon, Width: 75mm, (NOTE: These are Coming with BLACK headset spacers, clamp, rim strips)
  • Spokes: Stainless Spoke in ED Black, w/12mm Brass Nipple
  • Rims: Rim FRT 1 Alloy Rim, 26"x3.0-4 1/4", 14Gx32H, F/V, w/Big Hole (28mm), Finish: Anodized Black, Rim RR 1 Alloy Rim, 26"x3.0-4 1/4", 14Gx32H, F/V, w/Big Hole (28mm), 11.5mm, Finish: Anodized Black (NOTE: These are Coming with BLACK headset spacers, clamp, rim strips)
  • Tires/Tubes: Vee Rubber 26x4.00, VRB321, Wire Bead BK 72TPI
  • Brakes: Tektro Hydraulic Disc Brake Set,  For Int'l Disc Mount, w/ 180mm Fr/ 160mm Rr Wave Style Rotor
  • Brake Levers: Tektro Hydraulic Disc Brake Set
  • Headset: FSA NO.10 Steel 1-1/8" Semi-Integrated, Caged Bearing
  • Handlebar: Alloy Rise Handlebar, Width: 740mm, Rise: 18mm, Back Swept: 10°, Barbore: 31.8mm
  • Stem: Alloy 6061 3D Forged Stem, DIA: 28.6mm, EXT: 90mm, Barbore: 31.8mm, Angle: 7°, Finish: Black Sand Anodized
  • Saddle: MTB CR-MO Satin Rail
  • Seat Post: Micro Adjust 30.9mm / 350mm aluminum
  • Seat Post Clamp: Alloy Seat Clamp, DIA: 34.9mm
  • List Price: $2099
  • Street Price: $695.95
2015 Motobecane Lurch, Tapered Headtubes 4130 CrMo Frame Disc Brake Fat BIke
  • Frame: Custom Butted, CrMo Frames, w/Disc Mount Only, TIG Weld, Rear horizontal dropouts with hub keepers, H2O bosses, Tapered Headtube = L: 36/41/46/51/56CM = 104/112/122/140/160mm
  • Fork: 26" Fat Bike, Tapered Steerer = CR-MO 1-1/8" to 1.5" Taper w/0 Thread.L: 300mm, Blade: CR-MO Straight, Axle:150mm, w/ Int'l STD Disc Mount+ TriFecta Fork BrazeOns (NOTE: Fits tapered head tube forks. Some Lockout levers may strike downtube if forks are turned too far)
  • Crankset: Forged Aluminum SAMOX, 10 SPD ,22x36T AL 175mm For 120mm Axle + 10mm Axle Washer x 2 PCS
  • Pedals: n/a
  • Front Derailleur: SRAM X7 HDM 2X10 38/36T
  • Rear Derailleur: SRAM X9 Type 2 Long Cage 10Spd GRY
  • Shifters: SRAM SL Trigger X9 Grey
  • Chain: KMC X-10SL Steel NP/NP+CL-566R Link
  • Hubs: Front: Novatec D201SB-QR Alloy Front Disc Hub 32H,OLD: 9mm x 150mm For Fat Bike, 2 Precision Bearings, w/QR , Polish ANOD. Black W/Novatec logo Front Hub easily converts to 15mm Thru-axle. No conversion kit needed. Rear: Novatec D202SB-QR Alloy Rear Disc Hub32H.OLD: 10mm x190MM , 4 Precision Bearings, for Fat Bike, w/QR, Polish ANOD. Black  w/Novatec logo
  • Rims: Weinmann HL80 Alloy S/Wall 26" x 73/80xH24 , 26x3.0-4-1/2 ,32H,W/FV Black ANOD.w/o Eyelet, w/o CNC , w/Big Holes ( 32mm )
  • Brakes: Avid DB BB7 BKA 20I, Mechanical Disc Brake for Int'l STD Disc Mount, 180mm Rotor Front / 160mm Rear
  • Headset: FSA NO. 57 , Orbit 1.5 ZS ,FOR 1-1/8" / 1.5" Fork Stem Internal Alloy Cups, 1-1/8" ACB Upper, 1.5" ACB Lower w/Std 15mm top cover (H2051B) ( 28.6x44/55.95x39.8mm) (H:19.8 mm )
  • Handlebar: ( C:31.8mm ), Alloy 6061 RISE H/BAR ( 9° ) B/Center: 31.8mm.R/W:0/700mm. S.B BLK
  • Stem: ( C:31.8mm ) Alloy 6061 Threadless A-Head Stem.EXT:(7°)80/90/100/110/120MM FOR 36/41/46/51/56CM ,C/S:31.8x28.6x41mm.
  • Saddle: WTB Volt Sport
  • Seat Post: 6061 Alloy Sand Blast BLK S/Post w/Alloy ED BLK Head , 27.2 X 400mm
  • Seat Post Clamp: ( 29.8 x28.4 ) Alloy Sand BLK S/Clamp w/QR
  • List Price: $2599
  • Street Price: $899.95
2015 Motobecane Fantom Team 27.5/650B Titanium 27.5
This Titanium 27.5 / 650B is equipped with the top-shelf, ten-speed, hollow aluminum Shimano Deore XTR crank. Includes a super fast rolling, Sealed External BB System. Check out the FSA cartridge headset, sweet shifting 2015 Shimano 3 x 10 speed drivetrain with even lighter, precision bearing Vuelta XRP 27.5 / 650B edition SL Disc hubs and the hot new Shimano Deore XT Hydraulic Disc braking system. This bike has world dominating parts, without any doubt.
  • Frame: Titanium 3AL/2.5V Butted and Geometric Multishaped tubes, Tapered Head Tube Zero Stack, SForm Downtube, H2O Bosses (15" size has 1xH2O Bosses), S-Bend seatstays (Room for 2.35" tires) ZeroStack tapered head tube 1.125"-1.5" L: 38/43/48/53CM=102.5/102.5/127/140mm
  • Fork: RockShox Reba-RL 27.5", Alloy 1-1/8" to 1.5" Taper w/0 Thread Crown:Forged, hollow AL66 TV aluminum, Stanchion: 32mm, 7000 series straight wall aluminum, low friction anodized with sag gradients, Blade: Magnesium, post mount disc brake, Travel: 100mm, Bossless,W/15x100 Maxle Lite,W/External rebound, low speed compression to 'Lock'
  • Crankset: Shimano XTR, FC-M980, Hollowtech 2, for rear 10-Speed, 175mm, 42X32X24T, w/BB Parts (SM-BB93)
  • Bottom Bracket: Shimano SM-BB93
  • Pedals: n/a (requires 9/16 axle)
  • Front Derailleur: Shimano Front Derailleur, FD-M981, XTR Down-Swing Dual-Pull Band Type (W/31.8mm adapter)
  • Rear Derailleur: Shimano Rear Derailleur, RD-M981, XTR SGS 10-Speed Top-Normal Shadow Design
  • Shifters: Shimano SL-M980 XTR 2/3x10-Speed (30 gears total)
  • Cassette/Freewheel: Shimano Cassette Sprocket, CS-M771-10,DEORE XT, 10-SPEED 11-13-15-17-19-21-24-28-32-36T
  • Chain: KMC X10SL, Silver, 10 Speed
  • Hubs: Black Anodized Vuelta XRP 27.5 / 650B SL Edition, Precison Bearing with QR
  • Spokes: Stainless steel black finish with alloy nipples
  • Rims: Vuleta XRP 27.5 / 650B SuperLite Disc, doublewall aluminum/eyelets
  • Tires: WTB Wolverine 2.2 650B RACE , 27.5x2.2" ( 54/52 ) DNA Compound, 60tpi Casing, Aramid Bead, presta valve tubes (Room for 2.35" tires)
  • Brakes: Shimano Disc Brake Set, Deore XT BL-M785 Shimano Rotor for Disc Brake, SM-RT86, S 160MM 6-Bolt Type
  • Brake Levers: Shimano Deore XT hydraulic
  • Headset: FSA Sealed 1-1/8 ACB Top, 1.5" ACB Btm (for 46/56mm Head Tubes ) W/Top Cap w/15 mm Cone Spacer / Standard 15mm top cover
  • Handlebar: Ritchey Mtn Rizer, Alloy ( 2014 ) Riser H/Bar, B/Center: 31.8mm.R/W:20/710mm
  • Stem: Ritchey Stem 4-Axis 44 84/6D-28.6 ( Bar Center: 31.8mm ) Alloy "TIOGA-OS" A-Head Stem.EXT:(6°)100/110/120/130mm for 38/43/48/53,C/S:31.8x28.6x42mm. BB BLK
  • Tape/Grip: Ritchey MTN WCS Neoprene Foam GRIP , L:130mm
  • Saddle: Ritchey Streem V2 Black Saddle, PU Leather,Nylon + CF Shell,Hollow Cr-Mo Rail
  • Seat Post: Ritchey 2B Alloy ( 2014 ) 3D Forged, BB BLK S/Post w/Alloy BB BLK Head 27.2x400mm
  • Seat Post Clamp: Super Light Polished Aluminum
  • List Price: $5100
  • Street Price: $2,399.95
2015 Motobecane Fantom 27.5/650B 6BY6 PRO
Imagine the trails you will crush with 150mm up front and up to 6 inches of travel in the rear. No corners are cut, the FANTOM 6BY6 FS has top-of-the-line Full Race specs. A 150mm Rockshox Revelation RCT3 27.5/650B fork with up to SIX inches of travel in the rear, the NEWEST Rockshox MONARCH Air rear shock with Rapid Recovery Rebound Technology.
  • Frame: 27.5" Susp. MTB Alloy (6061) Wheel Travel: 150mm. ( Knuckle Box made by CNC ) Hydroformed Butted and Geometric Multishaped Aluminum tubes,1 set H2O Bosses (Small has no bosses), Four Bar Rocker Arm. Gusseted SL 6061 Aluminum (Disc Brake Equipped) Super Smooth Sealed Cartridge Bearings at critical pivots, replaceable rear derailleur hanger (Customers are reporting there is Room for 2.35" tires) Head Tube: Alloy 1-1/8" / 1.5" ( 50x44/62x55.95mm ) ,L: 42/47/52CM=110/120/120mm
  • Fork/Rear Shock: Fork: RockShox Revelation-RCT3-A3 , 27.5" Taper-15mm Thru-Axle , Steerer: Alloy 1-1/8" to 1.5" Taper , L:300mm ,W/O Thread Crown: Forged, hollow 6066 aluminum w/custom heat treatment, Stanchion: 32 mm Low Friction Anodized - Black, Blad: Magnesium, post disc mount W/15x100 Maxle Lite, Travel: 150mm, Bossless, External rebound, low speed compression, 3 position compression (open/platform/lock) Rear: RockShox " Monarch R " ( 00.4118.048.055 ) RS MNR R 200X51mm, Air Rear Shock, Black, Eye to Eye: 200mm W/External rebound
  • Crankset: Shimano Front, FC-M785-L, Deore XT, Hollowtech 2, for Rear 10-Speed, 175mm 38X24T, W/BB Parts, Black
  • Bottom Bracket: FSA BB-7100-73
  • Pedals: Gravity Alloy Barrel Polished Body w/ED BLK Alloy Cage W/9/16" CNC Machine  CR-MO Axle W/BS REFL.W/TPE Non-Slip Insert W/VP-C01 , W/" Gravity " Laser Logo
  • Front Derailleur: Shimano Front Derailleur, FD-M676D, SLX, Double, Down-Swing, Dual-Pull, Direct Mount Type, CS-Angle: 66-69, FOR 38/44T
  • Rear Derailleur: Shimano Rear Derailleur, RD-M786, Deore XT SGS 10-Speed Top-Normal Shadow Plus Clutch Design, Direct Attachment, Black
  • Shifters: Shimano Shift Lever, SL-M670, SLX w/ Optical Gear Display
  • Cassette/Freewheel: Shimano Cassette Sprocket, CS-HG81-10, SLX 10-SPD 11-13-15-17-19-21-24-28-32-36T
  • Chain: KMC X10SL Super Light Narrow CN 1/2"x11/128"x110L.w/Hollow Pin, Including CL559R NP Reusable Link , NP/NP
  • Hubs: FR: Vuelta Alloy Front Disc Hub 28H,OLD: 100mm , 2x2 Bearing W/15mm thru hole w/o 15mm thru axle (INCL. IN " M-13-Pro 275-F15RQR " 15mm thru axle wheelset) RR: Vuelta Alloy Rear Disc Hub 32H. OLD: 135mm, 2x2 Bearings w/Alloy BLK QR (INCL. IN "M-13-Pro 275-F15RQR " 15mm Thru Axle Wheelset), Compatible with Shimano 10-Spd
  • Spokes : Vuelta F/R:28/32PCS ( 3 CROSS ) 2.8 AERO , OXD BLK / 1 Red (Per Wheel ) Spokes w/Brass Nipples (INCL. IN " M-13-Pro 275-F15RQR " 15mm Thru Axle Wheelset)
  • Rims: Vuelta 27.5" Alloy BLK for Disc Only Rim, F/R:28/32H W/FV W/Eyelet (INCL. IN " M-13-Pro 275-F15RQR " 15mm Thru Axle Wheelset)
  • Brakes: Shimano Disc-Brake Assembled Set, SLX BL-M675-B(L), BR-M675(F) For Post Mount Fork, Resin Pad / Shimano Rotor for Disc-Brake, SM-RT66, FR: 180mm / RR: 160mm 6-Bolt Type, Bulk
  • Brake Levers: Shimano Disc-Brake Assembled Set, BL-M395
  • Handlebar: Ritchey MTN Comp Rizer (Low Rize) ( C:31.8mm ), Alloy 6061 Rise H/Bar (Upsweep 17°, Bend 9° ) B/Center: 31.8mm.R/W:20/710mm.BB BLK w/Print Logo
  • Stem: Ritchey Stem Comp 4-Axis 84/6D-31.8 ( C:31.8mm ) Alloy "TIOGA-OS" A-Head Stem EXT:(6°)100/110/120mm for 42/47/52CM,C/S:31.8x28.6x42mm. BB BLK w/Color Logo
  • Tape/Grip: WTB DC Trail Grip(W175-0012) Dual DNA Compounds, Classic Logo Pattern, full length with open ends and black w/o WTB, BLK on Grey
  • Seat Post: Ritchey Comp 2B 350/400 OS Alloy BB Black S/Post W/Alloy BLK Head 31.6x400mm, w/Print Logo
  • Sizes: Small/42cm, Medium/47cm, Large/52cm
  • List Price: $3999
  • Street Price: $1,799.95
2015 Motobecane Fantom 27.5/650B 6BY6 COMP
Imagine the trails you will crush with 150mm up front and up to 6 inches of travel in the rear. No corners are cut, the FANTOM 6BY6 FS has top-of-the-line Full Race specs. A 150mm Rockshox Sektor 27.5/650B fork with up to SIX inches of travel in the rear, the NEWEST Rockshox MONARCH Air rear shock with Rapid Recovery Rebound Technology.
  • Frame: 27.5" Susp. MTB Alloy (6061) Wheel Travel: 150mm. ( Knuckle Box made by CNC ) Hydroformed Butted and Geometric Multishaped Aluminum tubes,1 set H2O Bosses (Small has no bosses), Four Bar Rocker Arm. Gusseted SL 6061 Aluminum (Disc Brake Equipped) Super Smooth Sealed Cartridge Bearings at critical pivots, replaceable rear derailleur hanger (Customers are reporting there is Room for 2.35" tires) Head Tube: Alloy 1-1/8" / 1.5" ( 50x44/62x55.95mm ),L: 42/47/52CM=110/120/120mm
  • Fork/Rear Shock: Fork: RockShox Sektor Gold 150mm, 27.5" Taper-15mm Thru Axle 1-1/8" to 1.5" Taper , L:300mm, w/o thread Crown: Forged, hollow 6066 aluminum, Stanchion: 32mm straight wall aluminum, Low friction anodized, Blade: Magnesium, post disc mount W/15mm Maxle , Travel: 150mm, Bossless, External rebound, TurnKey lockout / Rear: RockShox " Monarch R " ( 00.4118.048.055 ) RS MNR R 200X51mm, AIR Rear Shock, Black, Eye to Eye: 200mm W/External rebound
  • Crankset: Shimano Front, FC-M615-L, DEORE 175mm 2-PCS FC, 38X24T w/o CG, Chaincase not compatible, w/BB Adapter, Black, Bulk
  • Pedals: Gravity Alloy Barrel Polished Body w/ED BLK Alloy Cage W/9/16" CNC Machine CR-MO Axle w/BS REFL.W/TPE Non Slip InsertW/VP-C01 , W/" Gravity " Laser Logo
  • Front Derailleur: Shimano Front Derailleur, FD-M616-D, Deore, Down-Swing, Dual-Pull, Direct Mount Type, CS-Angle: 66-69, for 38/44T(Double), Black
  • Rear Derailleur: Shimano Rear Derailleur, RD-M615, Deore, SGS 10-Speed, Top-Normal Shadow Plus Clutch Design, Direct Attachment, Black (Direct mount compatible), Black
  • Shifters: Shimano Shift Lever, SL-M610, Deore w/Optical Gear Display, Black
  • Cassette/Freewheel: Shimano Cassette Sprocket, CS-HG62-10, 10-SPEED 11-13-15-17-19-21-24-28-32-36T
  • Hubs: FR: Vuelta Alloy Front Disc Hub 28H,OLD: 100mm , 2x2 Bearing W/15mm thru Hole w/o 15mm thru axle (INCL. IN " M-13-Pro 275-F15RQR " 15mm thru axle wheelset) RR: Vuelta Alloy Rear Disc Hub 32H. OLD: 135mm, 2x2 Bearings w/Alloy BLK QR (INCL. IN "M-13-Pro 275-F15RQR " 15mm Thru Axle Wheelset), Compatible with Shimano 10-Spd
  • Spokes: Vuelta F/R:28/32PCS ( 3 Cross ) 2.8 Aero, OXD BLK / 1 Red (Per Wheel ) Spokes w/Brass Nipples (INCL. IN " M-13-Pro 275-F15RQR " 15mm Thru Axle Wheelset)
  • Brakes: Shimano Disc-Brake Assembled Set, SLX BL--M395, Black Shimano Rotor for Dic-Brake, SM-RT56 M Front: 180 / Rear: 160MM, 6-Bolt Type, for Resin Pad Only, Bulk
  • Brake Levers: himano Disc-Brake Assembled Set, BL-M395
  • Handlebar Ritchey MTN Comp Rizer (Low Rize) ( C:31.8mm ), Alloy 6061 Rise H/Bar (Upsweep 17°, Bend 9° ) B/Center: 31.8mm.R/W:20/710mm.BB BLK w/Print Logo
  • List Price: $3299
  • Street Price: $1,499.95
Motobecane Le Champion CF Team
The NEW Le Champion CF Team - You will be smiling in comfort as you drop other riders on hills and headwinds with the extra lower gears you have on your 22 Speed Shimano Dura Ace full carbon aero road bike. The beautiful carbon fiber frame is made with great care from high modulus carbon fiber. Fully engineered for a resilient ride and even more comfort comes from the Kinesis Carbon Fiber fork with advanced Tapered Steerers for precision handling.
  • Frame: AP2X Total Frame Design, Aero Section Downtube, New Semi-Compact Geometry, High Modulus Carbon Fiber Frame with replaceable derailleur hanger and 2xH2O brazeons Carbon Tapered Headtube Upper 1-1/8" / Lower 1.5" (46x42/56x52.1mm) 125/130/140/150/170/190/210/230mm
  • Fork: Aero Carbon Pro High Modulus 700C Carbon ( 12K Weave ) Fork, Stem: Alloy ( 1-1/8" TO 1.5" Taper ) 215/220/230/240/260/280/300/320mm, Crown: 56mm, Alloy Crown and Dropout, Bonded Carbon Blad, Offset:45mm
  • Headset: FSA NO.42/ACB Sealed 1-1/8 ACB Top, 1.5" ACB Btm (for 46/56mm Head Tubes ) W/TOP CAP W/15 mm Cone Spacer Sealed Bearing Threadless (1-1/8" Taper 1.5")
  • Derailleurs: Shimano Dura Ace 9000 11 Speed (22 Spd total) front and rear
  • Shifters: Shimano Dura Ace 9000 11 Speed STI (22 Speed total)
  • Brakes: Shimano Dura Ace 9000 aluminum calipers
  • Hubs: Mavic Ksyrium Equipe S sealed QRM bearings
  • Rims: Mavic Ksyrium Equipe S, Aero bladed spokes, UB Control Machined Sidewalls
  • Crank: FC-9000, Dura Ace Double Hollowtech 2, for rear 11- Speed, 50X34T W/BB(BSA), Crank 165/170/172.5/175mm
  • Bottom Bracket: Shimano Bottom Bracket, SM-BB9000, Dura-Ace
  • Cassette: Shimano 11-SPD KCS900011128 Cassette, CS-9000, Dura-Ace, 11-Speed, 11-12-13-14-15-17-19-21-23-25-28
  • Chain: Shimano CN-9000, Dura Ace, for 11-Speed, 108 Links
  • Saddle: Ritchey Pro Streem V2 Black Saddle, Superlight Faom,Nylon + CF Shell, Cr-Mo Rail
  • Seatpost: Ritchey Pro Carbon 2B, Carbon 3K-Weave S/Post w/Alloy B.B. BLK Head, 31.6 x 350mm
  • Handlebars/Stem: Ritchey Road Pro Biomax Bar (C:31.8) ALLOY(7075) / ( 7050 ) w/Tunnel Built in Type B/Cener: 31.8mm 380/400/420/440mm,D/R:130/75mm , BB BLK / Ritchey Stem Pro 4-AXIS 44 84/6D(C:31.8)-28.6 Alloy (6061) TIOGA-OS, Stem.EXT:(-6°)90/100/110mm C/S:31.8/28.6x42mm, BB BLK
  • Tires: Mavic Yksion Comp 23 700x23C / presta valve tubes
  • List Price: $5995
  • Street Price: $2999.95
2015 Motobecane Le Champion SL Titanium
Power-Tapered Titanium head tubes and Tapered Steerer Carbon Fiber forks for surgically precise handling with plush vibration dampening High Modulus 3K Carbon legs. Features: Geometrically enhanced, butted 3/2.5 Titanium tubing. Engineered for optimum ride quality and power transference.
  • Frame: Tapered Head Tube, Geometrically enhanced, butted 3/2.5 Titanium with replaceable derailleur hanger, 2x H2O bosses (2015 has new Ultegra 22 Speed+ NEW frame)
  • Fork: AeroCarbon SL High Modulus Monocoque 3K Carbon Fiber with Carbon Steerer (1-1/8" TAPER 1.5" ) L:48/51/53/56/59CM = 206/226/246/261/281mm. CROWN:56mm, W/45mm OFFSET
  • Headset: FSA NO.42/ACB Sealed 1-1/8 ACB Top, 1.5" ACB Btm (for 46/56mm Head Tubes ) W/TOP CAP W/15 mm Cone Spacer Sealed Bearing Threadless (1-1/8" TAPER 1.5")
  • Derailleurs: Shimano Ultegra 6800 11 Speed (22 Spd total) front and rear
  • Shifters/Levers: Shimano Ultegra 6800 11 Speed STI (22 Speed total)
  • Brakes: Shimano Ultegra 6800 aluminum calipers
  • Crank/BottomBracket: Shimano Ultegra DOUBLE HOLLOWTECH 2, FOR REAR 11- SPEED, 50X34T / integrated with Shimano BB6800 External Bearing Bottom Bracket 170/172.5/175MM FOR 48-51/53-56/59CM
  • Cassette/Chain: Shimano 22 Speed CS-6800, ULTEGRA, 11-S, 11-12-13-14-16-18-20-22-25-28-32T, Shimano CN-6800, ULTEGRA, FOR 11-SPEED, 108 LINKS
  • Saddle: Ritchey Comp Streem V2 Black Saddle, Superlight Foam, Nylon + CF Shell, Cr-Mo Rail
  • Seatpost: Ritchey Comp 2B 350 , ALLOY 2015 T-6 3-D forged , BB BLACK, 27.2 x 350MM
  • Stem: Ritchey COMP 4-AXIS 44 84/6D (C:31.8)-28.6 ALLOY(6061) TIOGA-OS, Stem.XT:(-6°)90/100/110mm FOR 48/51-53/56-59CM, 31.8mm OS clamp
  • Handlebars: Ritchey Road Comp Biomax Bar Alloy w/Tunnel Built in Type B/Center: 31.8mm 400/420/440mm FOR 48/51-53/56-59cm,D/R:130/75mm 31.8mm OS
  • Pedals: FREE Shimano PD-R550, SPD-SL Road Clipless Pedals included
  • Tires: Mavic Yksion Comp 23 700x23c, Presta valve tubes
  • Color: Brushed Titanium
  • List Price: $5100
  • Street Price: $2,199.99
2015 Motobecane Gigi TEAM Women's Carbon
The Gigi TEAM is top of the womens line and one of the best carbon women specific bicycles we have ever seen Every detail designed by Motobecane's women's cycling team to meet the special needs of ladies. Every Gigi TEAM is hand-built from specially shaped carbon with Motobecane's legendary quality and attention to detail. Equipped with advanced carbon frame and fork, this is the ultimate women-specific bike from Motobecane rides extra smoothly. You will be smiling in comfort as you drop other riders on hills and headwinds with the extra lower gears you have on your Shimano Ultegra, full carbon road bike. The beautiful carbon fiber frame is made with great care. Fully engineered for a resilient ride and even more comfort comes from the Kinesis Carbon Fiber fork and advanced Tapered Steerer for precision handling.
  • Frame: New Semi-Compact Geometry, High Modulus CarbonFiber Frame with replaceable derailleur hanger and 2xH2O brazeons HT lengths 47/50/52/54/56/58/60/62/64CM = 115/130/140/150/170/190/210/230/250mm Carbon Fiber Stays with forged road dropout and replaceable derailleur hanger
  • Fork: Aero Kinesis Pro High Modulus 700C Carbon ( UD Weave ) Steerer: ALLOY ( 1-1/8" to 1.5" Taper ) L: 50/52/54/56/58/60CM = 196/206/221/231/246/266. Crown: 56mm, Alloy Crown and Dropout Bonded Carbon Straight Blad, Offset: 45mm
  • Crankset: FSA Gossamer Compact Updated 50x34T,AL HG C-Ring ,W/ Alloy BLK ANOD. Crank 165/170/172.5/175mm for 47-50/52/54-56/58-60CM
  • Bottom Bracket: FSA BB-6000 MEGA EXO BB
  • Pedals: FREE Clipless Road Pedals: WELLGO RC-713 ALLOY POWDER COAT BLK ROAD PEDAL W/9/16" CNC CRMO Axle
  • Front Derailleur: Shimano, FD-6800 Ultegra for Front Double & Rear 11-Speed Band Type (34.9MM)
  • Rear Derailleur: Shimano, RD-6800, Ultegra GS 11-Speed Direct Attachment, Compatible with low gear 28-32T for double
  • Shifters: Shimano Shift/Brake Lever, ST-6800, Ultegra
  • Cassette: Shimano CS-6800, Ultegra, 11-S, 11-12-13-14-16-18-20-22-25-28-32T
  • Chain: Shimano CHAIN, CN-6800, Ultegra, for 11-speed, 108 Links, w/end pin
  • Front Hub: Mavic Aksium Alloy Road Front Black hub 20H
  • Rear Hub: Mavic Aksium Alloy Road Rear Black hub BLACK HUB 20H:130mm
  • Spokes: F/R:20/24PCS, RADIAL / 2 CROSS, STAINLESS OXD BLK 14G(2.0mm) SPOKE W/14mm BRASS NIPPLE
  • Rims: Mavic Aksium S, 700C Alloy Black ANOD. D/W W/UB Control W/Single Eyelet W/FV Supplied with Traditional Aluminum Quick Release
  • Tires: Mavic Aksium 25 Black W/White Logo
  • Brake Set: Tektro R540 Black w/P420 Alloy Cartridge Shoe Reach: 49mm
  • Brake Levers: Shimano Integrated with ST-6800
  • Headset: FSA NO.42/ACB-A Sealed 1-1/8 ACB Top, 1.5" ACB Btm (for 46/56mm Head Tubes ) W/TOP CAP W/15 mm Cone Spacer / Standard 15mm top cover (H2166B) ( 28.6x42/52.1x39.78mm) (H:16.3 mm ), BLK
  • Handlebar: Ritchey Biomax OE Road Bar (C:31.8) ALLOY(6061) D.B. Butted w/Tunnel BUilt in type B/Center: 31.8mm 400/420/440mm For 47-52/54-56/58-60cm,D/R:130/82mm,BB BLK
  • Stem: Ritchey Stem Comp 4 Axis 84/6D(C:31.8)-28.6 Alloy (6061) TIOGA-OS,Stem.EXT: (-6°) 90/100/110mm FOR 47-52/54-56/58-60cm, C/S:31.8/28.6x42mm, BB BLK
  • Tape/Grip: Motobecane custom gel cork wrap
  • Saddle: Motobecane Ultra-Womens Comfort
  • Seat Post: Ritchey 2 BOLT, 6061 ALLOY BB BLK S/POST W/BB BLK HEAD , 31.6 X 350mm
  • Seat Clamp: Motobecane Ultralite alloy
  • Sizes: All have 700c wheels
  • List Price: $2999
  • Street Price: $1599.95
Motobecane Fantom Cross Pro DISC
Cyclocross is Sunday morning bike-race madness. It's all the fun you can stand. Lap after lap around a dirt course you can't entirely ride; You've got to run some of it with your bike on your shoulder. That is what makes the SRAM Rival equipped Fantom Cross Pro such a versatile bike - it has to be fast, durable, light and capable in nearly all conditions and THAT makes it the perfect bike for everyday, fast, durable riding in most any condition. The 20 speed SRAM Rival equipped Fantom Cross Pro is the ULTIMATE all purpose Motobecane bike for 2014. The frame is the NEWEST Butted Aluminum alloy with Butted down tube, Integrated HeadTube, water bottle mounts.
  • Main Frame: Vari-Butted Aluminum Geometrically Enhanced tubing, Integrated HeadTube, 2xH2O bottle mounts (brazeons)
  • Headtube L: 49/52/54/56/58/61CM=95/105/115/115/135/165mm
  • Rear Triangle: Disc Brake Ready, Vari-Butted Aluminum Geometrically Enhanced tubing with S-bend seatstays, replaceable derailleur hanger, Fender mounts, Rear Rack Braze-Ons (Disc Brake Mounts, 130mm rear spacing)
  • Fork: Motobecane Alloy Crown Carbon (3K Weave) Blade 700C Tioga-OS Clyclecross Fk Stem: Alloy (1-1/8")W/0 Thread L:49/52/54/56/58/61CM=175/185195/195/215/245mm. Crown: 45mm, Blade: Carbon Muscle Shape Design w/Int'l STD Disc Mount w/45mm Offset w/Forged Dropouts
  • Crankset: FSA for Rear 10 Speed, Gossamer Cross Updated 46x36T,AL(BK )/AL(BK), HG C-Ring, Alloy Black ANOD. Crank 170/172.5/175MM FOR 49-52/54-56/58-61cm, W/ BB-6000 (CN LINE: 43.5mm )
  • Bottom Bracket: FSA BB6000 MegaEXO External cartridge bearing
  • Pedals: None
  • Front Derailleur: SRAM Rival FD, CLAMP Ø31.8
  • Rear Derailleur: SRAM Rival MAX 11-32CS DERAILLEUR
  • Shifters: SRAM SL RIVAL, 10-speed (20 gears total)
  • Cassette/Freewheel: SRAM CS PG-1070 11-12-13-15-17-19-22-25-28-32t
  • Chain: KMC X10SL Super Light Narrow CN 1/2"x11/128"x110L.W/Hollow Pin
  • Front Hub: Vuelta Alloy Disc Hub 28H, 2x2 Bearing W/Alloy BLK QR
  • Rear Hub: Vuelta Alloy Disc Hub 32H 130mm, 2x2 Bearing W/Alloy BLK QR
  • Spokes: Vuelta F/R:28/32PCS, 3 CROSS/3 CROSS, 2.8AERO OXD BLK / 1 RED ( PER WHEEL ) SPOKE W/BRASS NIPPLES
  • Rims: Vuelta Pro 700C Alloy BLK W/CNC,F/R:28/32H Aluminum
  • Tires: Continental Cyclocross Race (C281) Wire, 700x35C ( 35-622 ) 84TPI
  • Brake Set: Avid BB7R, Mechanical Disc Brake, w/INT'L STD Mount, Rotor G2CS 160mm
  • Brake Levers: SRAM Rival Brake/Shift 10 speed (20 gears total), Carbon-Composite Levers and Tektro RL721 Cross Top Levers (brake from the tops of the bars)
  • Headset: FSA Orbit IS IS2 1-1/8" Integrated OS 36/45 ACB FOR 45mm OD Headtube, Alloy
  • Handlebar: Custom Alloy 6061 D.B. w/Tunnel Built in Type B/Center: 31.8mm 400/420/440mm FOR 49-52/54-56/58-61cm,D/R:131/71, Gloss Black
  • Stem: Custom Forged Aluminum Threadless 7075 3D Forged A-HEAD Stem, Barbore: 31.8 .EXT:(-5°)90/100/110mm FOR 49-52/54-56/58-61cm,C/S:31.8/28.6x38mm, Powder White
  • Tape/Grip: Custom cork wrap
  • Saddle: Velo UltraLite Racing with Cro-Moly rails
  • Seat Post: Custom Race Aluminum, Gloss White post, Gloss Black Single-Bolt Clamp, 27.2x300mm
  • Seat Clamp: Ultralite alloy, 31.8mm, Lazer etched
  • Sizes: 49cm, 52cm, 54cm, 56cm, 58cm, 61cm, 64cm
  • Colors: Gloss White or Gloss Black
  • List Price: $2195
  • Street Price: $1099
Motobecane Fantom Cross PRO Disc Brake Titanium Cyclocross
Cyclocross is Sunday morning bike-race madness. It's all the fun you can stand. Lap after lap around a dirt course you can't entirely ride; You've got to run some of it with your bike on your shoulder. That is what makes the Fantom Cross PRO Titanium such a versatile bike - it has to be fast, durable, light and capable in nearly all conditions and THAT makes it the perfect bike for everyday, fast, durable riding in most any condition. The 22 Speed SRAM Rival equipped Fantom Cross PRO Titanium is the ULTIMATE all purpose Motobecane bike for 2015. The frame is Geometrically enhanced 3/2.5 Titanium with Vari-butted tubing, Integrated Head Tube, Double water bottle mounts, frame is Disc Brake Compatible.
  • Main Frame: Vari-Butted Titanium 3/2.5 Geometrically Enhanced tubing, Integrated HeadTube, 2xH2O bottle mounts (brazeons), Shoulder friendly top tube with underside flat section
  • Rear Triangle: Vari-Butted Titanium 3/2.5 Geometrically Enhanced tubing with S-bend seatstays, replaceable derailleur hanger, Fender mounts, Rear Rack Braze-Ons (IS Disc brake tabs, 130mm rear spacing)
  • Crankset: FSA Gossamer Cross Updated MEGAEXO, 46x36T, AL /AL, HG C-Ring ,W/Alloy BLK ANOD. Crank 170/172.5/175mm FOR 49-52/54-56/58-61CM
  • Bottom Bracket: FSA BB-6200 MEGA EXO BB Sealed Bearing cartridge
  • Pedals: Shimano, PD-R550, SPD-SL, w/Reflector
  • Front Derailleur: SRAM FD RIVAL 22, 31.8MM YAW W/ CHAIN SPOTTER
  • Rear Derailleur: SRAM RD RIVAL 22, MAX 11-32CS
  • Shifters SRAM: Rival SL 22, 11-speed (22 gears total)
  • Cassette/Freewheel: SRAM CS PG 1130 11-32
  • Chain: SRAM CN PC1130 W/ PWR.LCK 11S
  • Front Hub: Disc-Ready, Vuelta PRO, Black, 28H sealed precision bearing with QR
  • Rear Hub: Disc-Ready, Vuelta PRO, Black, 32H sealed precision bearing, with QR, 130mm spacing
  • Spokes: Black Stainless, Butted
  • Rims: Vuelta Pro 700C H:30.0 Alloy Matte BLK w/CNC, w/o Eyelet , F/R:28/32H,W/FV
  • Tires: Continental Cyclocross Race (C281) Fold , 700x35C ( 35-622 ) 180TPI
  • Brake Set: Avid BB7R, Mechanical Disc Brake, w/Int'l STD Mount, Rotor G2CS 160mm
  • Brake Levers: SRAM SL Rival Brake/Shift STI 11 Speed (22 gears total) AND Tektro RL570 Cross Top Levers (brake from the tops of the bars)
  • Headset: FSA Orbit IS IS2 1-1/8" INTEGRATED OS 36/45 ACB FOR 45mm OD Headtube, Alloy H/P W/6.5mm Custom Cone Spacer Option1.125" Threadless w/ Sealed Bearing
  • Handlebar: Ritchey Biomax Road Bar (C:31.8) ALLOY(7075)  w/Tunnel Built in Type B/Center: 31.8mm 400/420mm For 49-54/56-61cm,D/R:130/82mm,BB BLK (NOTE: Some Ritchey Bar/Stem/Seatpost Graphics will update to new 2015)
  • Stem: Ritchey 4-Axis 44 84/6D(C:31.8)-28.6 Alloy (6061) Tioga-OS, Stem.EXT:(-6°)90/100/110mm FOR 49-52/54-56/58-61CM,C/S:31.8/28.6x42mm ,BB BLK (NOTE: Some Ritchey Bar/Stem/Seatpost Graphics will update to new 2015)
  • Saddle: Ritchey Streem Black, PU Leather, Nylon + CF Shell,Hollow Cr-Mo Rail
  • Seat Post: Ritchey 2B, Alloy 3D Forged BB BLK , 27.2 X 400mm (NOTE: Some Ritchey Bar/Stem/Seatpost Graphics will update to new 2015)
  • Colors: Brushed Titanium
  • List Price: $4495
  • Street Price: $1,699.95
2015 Motobecane Fantom Cross Team Titanium
Cyclocross is Sunday morning bike-race madness. It's all the fun you can stand. Lap after lap around a dirt course you can't entirely ride; You've got to run some of it with your bike on your shoulder. That is what makes the Fantom Cross Team Titanium such a versatile bike - it has to be fast, durable, light and capable in nearly all conditions and THAT makes it the perfect bike for everyday, fast, durable riding in most any condition. The 22 Speed Shimano Ultegra equipped Fantom Cross Team Titanium is the ULTIMATE all purpose Motobecane bike for 2015 the newest Ultegra 6800 Shifters+Derailleurs) The frame is Geometrically enhanced 3/2.5 Titanium with Vari-butted tubing, Integrated Head Tube, Double water bottle mounts, frame is Disc Brake Compatible.
  • Fork: Motobecane Alloy Crown Carbon ( 3K Weave) Blad 700C Tioga-OS Cyclecross FK Stem: Alloy (1-1/8") w/o Thread L:49/52/54/56/58/61CM=177/187/197/197/217/247mm. Crown:45mm, Blade: Carbon Muscle Shape Design w/Disc Mount. w/45mm Offset. w/Forged Dropouts
  • Crankset: Shimano, FC-6800, Ultegra Double Hollowtech 2, 11-Speed, 46X36T W/BB(BSA), Crank 170/172.5/175mm FOR 49-52/54-56/58-61CM
  • Bottom Bracket: Shimano Ultegra External Outboard 68mm
  • Pedals: Shimano Pedal, PD-R550, SPD-SL, W/(SM-SH11)
  • Front Derailleur: Shimano, FD-6800 Ultegra for Fornt Double and Rear 11-Speed Band Type (31.8MM)
  • Rear Derailleur: Shimano, RD-6800, Ultegra GS 11-Speed Direct Attachment, Compatible with Low Gear 28-32T for Double
  • Shifters: Shimano Ultegra 6800 11-speed (22 gears total)
  • Cassette/Freewheel: Shimano, CS-6800, Ultegra, 11-S, 11-12-13-14-16-18-20-22-25-28-32T
  • Chain: Shimano CN-6800, Ultegra, For 11-Speed, 110 Links
  • Front Hub: Disc Ready, Vuelta Team SL for Cross, Black, 28H sealed precision bearing with Vuelta QR
  • Rear Hub: Disc Ready, Vuelta Team SL for Cross, Black, 28H sealed precision bearing, with Vuelta QR, 130mm
  • Rims: Vuelta Team SL 700C Alloy BLK W/O CNC, H:27mm, F/R:28/28H,W/FV Team SL.S Road Disc Wheelset
  • Tires: Continental Cyclocross Race (C281) Fold , 700x35C ( 35-622 ) 180TPI 700x28/32C INNER TUBES ( 0.73mm). W/FV 48mm
  • Brake Levers: Shimano Ultegra 6800 Brake/Shift STI 11 speed (22 gears total) AND Tektro RL570 Cross Top Levers (brake from the tops of the bars)
  • Headset Shimano Ultegra Orbit IS2 Integrated, 1.125" Threadless w/ Sealed Bearing INTEGRATED OS 36/45 Angular Contact Bearing FOR 45mm OD Headtube
  • Handlebar: Ritchey Biomax Road Bar (C:31.8) Alloy (7075) w/Tunnel Built in Type B/Center: 31.8mm 400/420mm for 49-54/56-61cm,D/R:130/82mm, BB BLK (NOTE: Some Ritchey Bar/Stem/Seatpost Graphics will update to new 2015)
  • Stem: Ritchey Stem 4-Axis 44 84/6D(C:31.8)-28.6 Alloy (6061) Tioga-OS, Stem.EXT:(-6°)90/100/110mm for 49-52/54-56/58-61CM, C/S:31.8/28.6x42mm, BB BLK (NOTE: Some Ritchey Bar/Stem/Seatpost Graphics will update to new 2015)
  • Tape/Grip: Motobecane Custom cork wrap with Gel
  • Saddle: Ritchey Streem V3 Black, PU Leather, Nylon + CF Shell,Hollow Cr-Mo Rail
  • Seat Post: Ritchey 2B, 2015 Alloy 3D Forged BB BLK , 27.2 X 300mm (NOTE: Some Ritchey Bar/Stem/Seatpost Graphics will update to new 2015)
  • List Price: $4995
  • Street Price: $1999.99
