MyTinySun Sport2700x – 2012 Mtbr Lights Shootout
Lights Shootout
We didn’t know what to to expect when I opened this package with a funny name, MyTinySun. Was it another rebadged Magicshine knock-off?  Oh how wrong we were.
What we have here is a meticulously engineered light from Germany that is one of the most powerful lights I have ever tested. The MyTinySun Sport2700x is a light that houses three of the most powerful lights, the Cree XM-Ls and it claims an output of 2700 lumens.
So two things that jump out at us immediately are the craftsmanship  and  the brightness of the light. The light head is CNC’d to bring out a ton of cooling fins. Three  XM-Ls running at full tilt need quite a bit of cooling. So of course, we rushed outside to turn it on. The light is dramatic in brightness as it is huge, bright swath of light. It measured 204 Mtbr Lux and that falls right in between the more expensive Lupine Betty 2300 and 2600.
Comparison with the Competition:
Baja Designs Double Stryk $450.00 150 Mtbr Lux
Lupine Betty 2300                 $930.00 197 Mtbr Lux
Tiny Sun Lights Sport2700x $500.00 204 Mtbr Lux
Lupine Betty 2600                  $930.00 217 Mtbr Lux
It is great to have options at the very high end of the market. MyTinySun has a lot of experience developing and selling replacement batteries for other manufacturers like Lupine so they know their engineering and testing.
The light uses a 14.4 V – 5.8 Ah battery as opposed to a 7.2 volt or 11.1 volt that most companies use.  This allows MyTinySun to extract a little more brightness out the CREE lamps.  Also, they  use ‘triple optics’ to produce a beam pattern that is very even. There are no hot spots or bright center spot.  The light is just a bright 20 degree flood.  This light can be complemented by an XM-L based spot helmet light to extend its throw.
Some of the features this light has are:
  • Cables and connectors are industrial quality
  • Waterproof – counter spray, water jet and temporary immersion tests all exceed industry standard: IP67
  • Universal PLUS with light carrier mounting aid for mounting on different tube diameters and configurable cable outlet in three possible directions to prevent cable pivoting and wear.
  • Includes high quality storage and transportation case
  • Extremely bright – up to nom. 2700 Lumens
  • Wide illumination – 20 ° optics
  • Longer burning light – up to 28 (14) hours (2.6 W power, nom 425 lumens) with Li-ion technology
  • Lightweight – lamp head about 110 g, battery unit 460 (240) g
  • High sensitivity – CNC machined and anodized aluminum components
  • Environmentally friendly – EU-style, CE certified, RoHS compliant
It’s a German light so it has to respond to higher testing standards.
Packaging was a little rough at press time with the battery wrapped in velcro and the case it came in was a generic hard case with foam inserts. These were being improved and developed while we were testing.
Specifications:
  • Price: $500
  • Claimed Lumens: 2700 Lumens
  • Light Head Weight: 110 grams
  • Installed Weight: 460 grams
  • Run Time: 2.5 Hours
  • Measured MTBR Lux: 204 Lux
  • Measured Lumens: 1850 Lumens
Mounting:
Mounting is pretty neat with an evolution of the simple rubber loop style. It has a lever that allows you to hook the rubber loop and cinch it down with an alloy lever. Reverse action is performed for removing the light.  So the mount is still lightweight and minimalist but at least the user doesn’t have to fight and grab a tight rubber loop that’s difficult to handle.
Related Links
www.openlightsystems.com
Mtbr Lights Shootout Main Page »
2012 Bike Lights Shootout »
Backyard Beam Pattern Comparisons »
Trail Beam Pattern Comparisons »
Light Meter Measurements »
Mtbr Lights Reviews »
Mtbr Lights Forum »
(Visited 16,464 times, 1 visits today)
