New Cane Creek C-Quent features fewer tuning options
Optimal set-up for bike determined and set at factory so you dont have to
Components News
The C-Quent has all of the same capability as the other Cane Creek Double Barrel shocks, but instead will come pre-set with a custom tune.
The C-Quent has all of the same capability as the other Cane Creek Double Barrel shocks, but instead will come pre-set with a custom tune (click to enlarge).
Cane Creek suspension components have garnered a faithful following in the after-market arena. But most of those buyers tend to be a little more suspension set-up savvy than your average weekend warrior. Now the North Carolina-based company has a product for the non-tweaker-types.
The new C-Quent is Cane Creek’s first Double Barrel shock built for the rider who prefers fewer tuning options and a tool-free interface. Initially, the new shock will only be available through bike manufacturers. Cane Creek will work closely with their OEM partners to determine a custom build and tune that provides optimum suspension performance for that particular bike model. The development team analyzes frame kinematics and utilizes field-testing to produce precise settings that meet the performance goals and desired feel for the bike. Once this base tune is determined, the C-Quent is assembled with high speed compression, high speed rebound, and low speed compression fixed at the factory
Cane Creek C-Quent
For minor adjustments, the C-Quent has a low speed rebound (LSR) adjuster and a climb switch. This will include well-defined clicks of LSR to provide meaningful adjustment without risk of going too far.
“Twin-tube technology in the DB damper affords the sophisticated tuner a broad spectrum of adjustment,” said director of engineering, Jim Morrison. “But for the many riders who don’t live and breathe force vs. velocity curves, the base tune settings their shock arrives with feel really good and the adjusters may go un-turned.”
The damping mechanism on the C-Quent is a hybrid between twin-tube technology and a mono-tube design that retains the benefits of twin-tube: less cavitation, more control, and damping consistency. Like all Double Barrel shocks, the C-Quent houses all of its low-speed damping circuitry in the valve body, allowing for the climb switch to address both compression and rebound when engaged.
Cane Creek C-Quent
Unlike other Cane Creek shocks, however, C-Quent controls the high-speed damping circuits via shim-stacks on the main piston. The extreme tune-ability of the DB is retained at the factory, giving rise to a lighter-weight Double Barrel with consistent damping levels, claims Cane Creek.
“We take the DB’s adjustment range and distill it down so the bicycle performs exactly the way the frame engineers and product managers intended,” added Morrison. “By doing so we help the designer realize their vision of the perfect ride and the C-Quent conveys that vision more directly to the rider than a shock with limitless adjustability.”
For more information and a list of OEM partners, please visit www.canecreek.com.
About the author: Jason Sumner
An avid cyclist, Jason Sumner has been writing about two-wheeled pursuits of all kinds since 1999. He’s covered the Tour de France, the Olympics, and dozens of other international cycling events. He also likes to throw himself into the fray, penning first-person accounts of cycling adventures all over the globe. Sumner, who joined the Mtbr staff in 2013, has also done extensive gear testing and is the author of the cycling guide book "75 Classic Rides: Colorado." When not writing or riding, the native Coloradoan can be found enjoying life with his wife Lisa and daughter Cora in and around their home in the MTB Mecca of Crested Butte.
