New crop of Topeak tools offer innovative convenience
Tubeless inflator, hidden hand pump, and two cool torque wrenches
Gear Sea Otter Classic
2016 Sea Otter Classic
The bike industry is in a period of rapid innovation — and it’s not limited to just bikes. Companies such as Topeak are getting creative with tool design, coming up with new and unique takes on old standards such as the hand pump, multi-tool, and floor pump (though Bontrager gets credit for breaking the mold on the later). We took a quick spin through the Topeak tent during the Sea Otter Classic. Here are four of the company’s coolest bike tools.
Topeak Ninja P Hand Pump
Ninja P Hand Pump
At first glance this 90-gram aluminum inflator looks like a standard hand pump. But thanks to a special expandable rubber mounting ring, you can stash it inside your seatpost, opening up valuable jersey or saddle bag space. The pump fits inside 27.2mm, 30.9mm and 31.6mm posts, and also comes with position indicators, so you’ll be able to restore proper saddle height after you’ve fixed your flat. Price: $30
Topeak Nano Torquebar Torque Wrench
A good torque wrench can save you countless headaches, not to mention money, lest you over tighten (and crack) your carbon handlebars or other piece of high-zoot composite componentry. Topeak’s light and slim Nano Torquebar comes in 4Nm, 5Nm, and 6Nm versions, and each set includes 5 tool bits: 3/4/5mm hex keys, and T20 and T25 torx. Two of those bits can fit inside the wrench’s handle, making this both a great home shop and on-bike option. Claimed weight is 62 grams with two bits inside. Price: $40.
Topeak Nano Torque Box
Nano Torque Box
For the ultimate in torque wrench portability, you’ll be hard pressed to beat Topeak’s Nano Torque Box, a pocket-sized kit that works with any 5mm Allen wrench, multi-tool or otherwise. Boxes are available with a 4Nm, 5Nm, or 6Nm pre-set, plus the five most commonly needed tool bits: 3/4/5mm hex keys, and T20 and T25 torx. Simply drop the right bit into the pre-set, then mount on your 5mm, and you’re cranking with caution. Claimed weight is 75 grams. Price: $30.
Topeak Joe Blow Booster Floor Pump
Bontrager was first to market with its Flash Charger pump. Now Topeak is in the game with the Joe Blow Booster, a floor pump designed specifically for inflating troublesome tubeless tires. The Topeak air blaster has an aluminum chamber that stores air up to 160psi. After connecting the hose to your wheel’s valve, it takes about 40 pumps to reach full “charge.” Then simply flip the switch to “Inflate” and all that air comes blasting out, pushing your tire bead into place. From there you can fine-tune pressure by using the pump in standard mode. An easy-to-read top-mounted gauge helps you nail the perfect psi.
We have one of these in for test and have been impressed so far. It doesn’t always work on the first try, but the Joe Blow Booster is far more effective than the pump-as-fast-as-you-can-until-your-arms-explode technique, and far quieter and lighter than your average air compressor. We also appreciate the wide, stable base, and long hose length. Price: $160.
For more information visit www.topeak.com.
This article is part of Mtbr’s coverage of the 2016 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
About the author: Jason Sumner
An avid cyclist, Jason Sumner has been writing about two-wheeled pursuits of all kinds since 1999. He’s covered the Olympics, Tour de France, MTB world champs, and dozens of other international cycling events. He also likes to throw himself into the fray, penning first-person accounts of cycling adventures all over the globe. Sumner, who joined the Mtbr staff in 2013, has also done extensive gear testing and is the author of the cycling guide book "75 Classic Rides: Colorado." When not writing or riding, the native Coloradoan can be found enjoying life with his wife Lisa and kids Cora and Tommy in and around their home in the MTB Mecca of Crested Butte.
