News out of the Niner camp today. The Colorado-based bike maker has re-released its original steel classic, the SIR 9, in a redesigned, ready for anything form.
Built from Reynolds 853 steel, Niner says the hardtail SIR 9 is balanced, playful, and confidence inspiring. The bike uses the same trail geometry that was developed for the RIP 9 and JET 9 trail bikes. It also has boost hub spacing for 27.5+ and 29er wheels. And it boasts a whopping 18 mounting options for bottles, bags, racks, and fenders. Let the bike packing adventures begin.
For more info head to www.ninerbikes.com. Here's a rundown of key features, plus a list of build options, and lots of photos.
Key Features
Key Tech Specs
Key Features
- Redesigned bottom bracket/chainstay junction increases stiffness
- PF 30 BB allows you to run a standard BB or, eccentric BB for singlespeed
- Nearly unified yoke which allows for longer and stronger welds to the bottom bracket
- Hidden plate in yoke adds to the stiffness
- Tapered head tube allows riders to keep up with fork technology
- Reynolds 853 steel provides the supple, comfortable ride
- Compatible with 29x2.4 Or 27.5X3.0 tires
- Integrated bag mounts inside front triangle
- Bento box mounts on top tube offer additional storage options
- Compatible with 1x (max ring 36t) and 2x (26/36 or bigger) drivetrain systems
Key Tech Specs
- 73mm PF30 BB shell (adaptors required for BSA type BBs)
- Compatible with Biocentric 30 for singlespeed use
- 30.9 seat post
- 31.8 seat collar
- 34.9 front derailleur clamp
- 1.125" X 1.5" Tapered zero stack head tube, 44mm upper, 56mm lower, cane creek description: ZS44/28.6 ZS56/40
- 34.9 Side swing, front pull front derailleur
- Post mount disc brake - 180mm max rotor size
- All sizes have 2 inner triangle bottle mounts, 1 mount under down tube
- Can fit up to a 29x2.4 or 27.5x3.0 tire (tire sizes vary by brand, some tires may not fit)
- Compatible with standard 1x (36t max), 2x and 3x systems
