Nox Composites Interbike 2016
Taking function over form approach to product design
Interbike Sponsored post Wheels
Nox Composites
Nox Composites was founded in 2012 by two engineers and former bike racers in Knoxville, TN. From humble roots, they have grown the company using a grassroots approach, relying primarily on word of mouth, solid product reputation and exceptional customer support. Nox has been innovators since the beginning, bringing game changing ideas to market such as wider rims, asymmetric offset rims, and hookless beads that are now nearly standard in the industry. Nox takes a “function over form” approach to product design, a unique position in an industry which is too often driven by fads and loud colors. Proven at the highest levels of racing, their products have a near cult following and fill a needed niche of high-quality carbon rims at a more obtainable price point. Nox is currently offering eight mountain rims ranging from 23mm to 36mm internal widths, two cyclocross rims, and is developing a full line of aerodynamic road rims for release in spring 2017. Nox also runs a wheel shop out of their Knoxville office, hand building quick-turn custom wheels using top shelf components.
Gallery: Nox Composites Skyline, Teocalli, Farlow, Kitsuma and More
Nox Composites Interbike 2016 Gallery
of
Nox Skyline 29 & 27.5
The Skyline rim is a no-holds barred rim aimed at giving racers and “weight conscious” riders the ultimate weapon – a light yet stiff set of wheels with mind blowing acceleration. With an internal width of 23mm, the Skyline matches well with tires in the 2.0-2.25 sizes.
  • Skyline 29 inch weight of 345 grams (per rim) .
  • Skyline 27.5 inch weight of 335 grams (per rim).
  • 23mm internal width, 29mm external hookless bead construction.
  • Disc specific 2.6mm asymmetric spoke offset to increase lateral stiffness by improving net bracing angles. Nox invented the process of building strong asymmetric offset mountain rims and they continue to do it better than anyone else.
  • Patent-pending rim construction techniques including UniWeave and the Anti-Burp Bump.
  • The Skyline is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
$479.00 USD per rim, Custom hand-built wheelsets starting at $1358
Nox Skyline Rim Bead
Nox Teocalli 29 & 27.5
The Teocalli is Nox’s most popular rim and for good reason; the 26mm internal width is a perfect match for the tires most common the trail. The Teocalli is proven to be incredibly durable and exceptionally stiff while being as light as most race-day only alloy rims. The Teocalli was designed to interface with tires ranging from 2.1-2.35”. It’s at home on a wide range of bikes from hardtails up to 5” travel bikes.
  • Teocalli 29 inch weight of 385 grams (per rim) .
  • Teocalli 27.5 inch weight of 350 grams (per rim).
  • 26mm internal width, 32mm external hookless bead construction.
  • The Teocalli is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
Nox Teocalli Rim Bead
Nox Farlow 29 & 27.5
The Farlow was designed to provide the advantages of extra-wide mountain rims: lower rolling resistance, increased traction and improved sidewall support, all while keeping weight in check at a respectable 420-430g. The Farlow has proven its durability with success on the World Cup Enduro circuit. As one of the first hookless rims on the market, the Farlow was perfected on the double-black Devil’s Racetrack in Nox’s hometown of Knoxville, TN. With an internal rim width of 29mm, the Farlow works great with tires ranging from 2.3-2.5. The Farlow is at home on 4”-6” travel bikes and is an extremely flexible rim, capable of daily XC/trail rides with weekend trips to the bike park.
  • Farlow 29 inch weight of 430 grams (per rim).
  • Farlow 27.5 inch weight of 420 grams (per rim).
  • 29mm internal width, 35mm external hookless bead construction.
  • Available with a DH-layup adding additional internal support (50g).
  • The Farlow is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
Nox Kitsuma 29 & 27.5
The Kitsuma is a super-wide rim built for riders pushing the limit on the way down. If you can dish it, this rim can take it. Combined with a good set of tires, there’s not much you can’t ride at stupid-speeds with these rims. Developed and tested on the world-class downhill of Windrock Park in Oliver Springs, TN, the Kitsuma all about maximizing traction and wheel stiffness. At 36mm wide (internal) it works best with tires 2.4-3.0 inches wide.
  • Kitsuma 29 inch weight of 475 grams (per rim).
  • Kitsuma 27.5 inch weight of 460 grams (per rim).
  • 36mm internal width, 42mm external hookless bead construction.
  • Deep 30mm construction for maximum lateral stiffness.
  • Available with a DH-layup which adds internal support (50g).
  • The Kitsuma is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
$499.00 USD per rim, Custom hand-built wheelsets starting at $1398
Nox Citico 29/700c
The Citico is the ultimate adventure rim for gravel grinders and CX racers looking for the best strength to weight ratio on the market. The Citico is fast on the road, wide for better traction and lower Crr, strong enough for spontaneous single track exploration and right at home on a CX race course. A 23mm hook to hook width works great with 28mm-44mm tires. This rim has a bead hook to ensure compatibility with a wide range of tubeless and non-tubeless ready tires up to 80psi.
  • Citico 700c/29 clincher weight of 380 grams (per rim).
  • 23mm internal width, 31mm external with bead hook and support up to 80psi.
  • Quick taper shape reduces rock strikes on gravel and CX courses.
  • The Citico is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
Nox Zolder Tubular 700c
The Zolder tubular is the industry’s first asymmetric disc-specific tubular composite rim. Designed for CX or Disc-road racing, the asymmetric offset improves the bracing angles of the wheel to improve net lateral stiffness and overall wheel durability. Nox developed a 23mm wide C-shaped gluing surface that contours perfectly to the most common 30mm-38mm tires. This shape saves significant effort during the installation process and provides a secure bond.
  • Zolder 700c tubular weight of 315 grams (per rim)
  • 23mm gluing surface, 26mm at widest point
  • 23mm C-shaped gluing surface designed around cyclocross tubulars
  • Patent-pending rim construction techniques including UniWeave.
  • The Zolder is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
Nox Falkor 36D
The Falkor 36D is an aerodynamic rim designed for disc brake equipped road bikes. Designed using Computation Fluid Dynamics (CFD) software, the Falkor 36D is optimized for 10deg wind yaw angles and is the first asymmetric aerodynamic composite rim on the market. The Falkor 36D is relatively wide (27.5mm) to lower rolling resistance, reduce pinch flats and provide a smooth, low-drag transition at the tire to rim interface when used with the 25-28mm tires most common on the road today. The Falkor 36D is proven at the highest level of racing, while being diverse enough to tackle a spontaneous gravel adventure.
  • Falkor 36D 700c clincher weight of 415 grams (per rim).
  • 36mm deep.
  • 27.5mm width (20mm hook to hook inside).
  • Tubeless compatible with most tubeless-specific road tires on the market.
  • Disc specific 2.0mm asymmetric spoke offset to increase lateral stiffness by improving net bracing angles. Nox invented the process of building strong asymmetric offset mountain rims and they continue to do it better than anyone else.
  • Patent-pending rim construction techniques including UniWeave and Anti-Burp Bump
  • The Falkor 36D is built with a proprietary blend of temperature controlled, short-cycle ultra-high and high modulus fiber.
Nox Decal Color Sheet
Decal color options.
Nox Composites
Tennessee - Baker Creek Preserve.
Wordpress Comments:
