When I last talked to Calvin from Park Tool (at the recent QBP SaddleDrive event) he gave me a hint as to what new products they would be showing at Interbike. He said the new product would be, “Made for you if you have a bad back or a really heavy bike.” My guess at the time was a power lift bike stand.
Bingo!
One of the main new products (out of the many on display) from Park Tool is the PRS-33 Power Lift Shop Stand. Now, a power lift shop stand is definitely not something the average consumer is going to buy. This stand was meant for shops and can lift up to 120 lbs! If your shop works on a lot of heavy DH rigs, electric bicycles or heavy cruisers…this just might be a welcome addition to keep your mechanics happy.
In this video, Eric Hawkins from Park Tool shows us some of their new tools for 2013 including the Power Lift Shop Repair Stand.
The Park Tool Power Lift features:
-Adjustable height from 6” to 78” (16cm-198cm)
-Integrated work tray
-Integrated accessory bar to hang wheels, air hoses, lights and just about any other accessory you can think of
-Electric motor able to smoothly lift 120 pounds (54kg)
-Oversized gussets to mount stand directly to the floor
-100-3D Micro Adjust clamp
Some more new tools for 2013 from Park Tool>>
MTB-3.2 Premium Rescue Tool (disc brake specific tools)
Now with more tools, an upgraded chain tool and a sleeker, smaller size. The MTB-3.2 is built to tackle nearly any road or trailside emergency repair. It’s small enough to take along yet the protected tools feature enough leverage to make repairs quick and easy.
Features:
-Composite protective shell doubles as two super strong tire levers
-10-speed compatible chain tool
-Disc brake piston press
-Rotor truing tool
-1.5, 2, 2.5, 3, 4, 5, 6, & 8mm hex wrenches
-T10, T25 and T30 Torx® compatible drivers
-Straight blade screwdriver
-Philips head screwdriver
-8, 9 and 10mm box end wrenches
-Emergency pedal wrench
-Presta valve core/extension tool (4mm)
-Bottle opener
-Three spoke wrenches (0.127″, 0.130″ and 0.136″/SW-0, 1 and 2 sizes)
-Knife
The MTB 3.2 multi tool will be available January 2013.
i didn’t ck your booth out at interbike last sept. having alot of back problems would like some info on power repair stand. cost freight
mikes bikes
mcpherson ks 67460
