Chris Cocalis shows us the 2013 Pivot line with the new Mach 429 Carbon that features dw-link suspension technology, ISCG 05 chain guide, and internal cable routing, the new LES 29er carbon hardtail, the best selling Mach 5.7 Carbon, new M4X, Firebird and the Phoenix.
×Pivot Mach 429C XX1
Pivot has upped the ante once again by taking the proven performance of the Mach 429 and adding carbon. All new geometry, a revised dw-link suspension design and the same Pivot hollow box internal molding technology developed on the Carbon Mach 5.7 has allowed us to achieve a new level of frame strength and stiffness with superior ride performance in a lightweight 29er package. The Mach 429 Carbon delivers a perfect balance by taking all of the riding efficiencies of the 29er and delivering the handling characteristics of a 26”. It will make short work of any climb, descents a breeze and all with the comfort and proficiency of full suspension so you can ride at your best all day! Two years were dedicated to the testing and design of the 429 Carbon, the result is a bicycle with uncompromising performance, and that’s simply, just plain fun to ride! Once again Pivot is “Performance Redefined” with the Mach 429 Carbon.- Pivot exclusive hollow box, high-compression internal molding technology allows for greater compaction and smoother internal walls resulting in a lighter, stronger, highly optimized frame design with the best stiffness to weight ratio in the class.
- New geometry and a revised dw-link® suspension design with position-sensitive anti-squat makes for a 29er that pedals, accelerates and handles like a 26” wheel bike.
- New Pivot specific, custom tuned Fox CTD shock technology: Increased performance and adjustment range allows riders to quickly and easily adjust for changing course or ride conditions.
- 100mm rear travel with 100-125mm travel fork compatibility.
- 142mm rear spacing with 12mm through axle and 160mm post mount dropouts for maximum frame stiffness.
- New under top tube internal shift cable routing with clean brake and dropper seat post routing.
- Rubberized leather chainstay, inner seat stay, and down tube protectors for a quiet ride and higher impact resistance.
- Tapered 1.5” headtube, PF92 bottom bracket, and direct mount front derailleur.
- New ISCG 05 (chainguide) mounts included on frame.
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
- $7049
×Pivot Mach 5.7 Carbon
The Mach 5.7 Carbon has set a new standard for what is possible with carbon fiber and suspension bike design. We’ve developed a bike that is lighter, stronger and stiffer than anything that’s come before it. Applying our ground breaking composite technology to the best performing trail bike made and you have a bike that stands atop the competition. Not only will the Mach 5.7 Carbon leave your friends with plenty of bike envy, you will be having a blast leaving them behind!- Pivot exclusive hollow box, high-compression internal molding technology allows for greater compaction and smoother internal walls resulting in a lighter, stronger, highly optimized frame design with the best stiffness to weight ratio in the class.
- dw-link suspension with position sensitive anti-squat allows us to achieve the stable handling and increased cornering benefits of a lower bottom bracket with more travel, all with better pedaling efficiency and a plusher feel.
- New Pivot specific, custom valved Fox CTD shock technology featuring increased rider tunability and incredible small bump sensitivity.
- Under top tube cable guides with straightforward dropper seat post routing.
- 5.7” (145mm) rear travel.
- Tapered 1.5” headtube, Press Fit 92mm wide bottom bracket, direct mount front derailleur, and high-modulus carbon rocker add to the Mach 5.7 Carbon’s superior frame stiffness and incredible long-term durability.
×Pivot Mach 4X XT Pro
True to Pivot form, we’ve redefined the slalom and big air categories with the M4X. The M4X is the choice of top riders and legends of the sport. It’s already taken dual slalom podium finishes and won best trick competitions across the globe. We’ve combined 4” of dw-link tuned suspension, Pivot proven frame stiffness and the perfect slalom geometry to create the M4X, A machine of pure gravity delight. The M4X is perfect for dirt jumps, slalom, pump track and technical jump filled trails. If you like having fun on a bike what’s not to like about the M4X.- dw-link suspension design, with position-sensitive anti-squat, tuned for instant acceleration and superior control while railing corners and boosting jump faces.
- 100mm rear travel.
- Two sizes (short and long) to fit a wide range of rider heights and preferences.
- ISCG 05 mounts.
- 1.5” tapered headtube.
- FOX Adaptive Logic Kashima shock with custom M4X slalom/dirt jump Boost Valve and compression tuning.
- Additional cable routing for dropper seat posts making the M4X a great trail bike option as well.
- $2399 Frame Only
- ISCG 05 mounts.
- $2399 Frame Only
- ISCG 05 mounts.
- $2399 Frame Only
- ISCG 05 mounts.
- $2399 Frame Only
- ISCG 05 mounts.
- $2399 Frame Only
×Pivot Phoenix X0
The pinnacle of dw-link performance: Pivot has delivered a bike with over 8” of rear travel and proven World Cup performance. With the heritage of 6 World Championships built into it and plenty of podiums on its own, the Phoenix is a serious DH rig, for the serious DH rider. No other DH bike can boast the bump compliance, consistency & control, pedaling efficiency and frame stiffness of the Phoenix. Add to that the incredible attention to detail, quality and long term durability and you have a bike that allows you to set new personal bests run after run. Ask any rider that has thrown a leg over this bike and they will rave about the performance, speed and confidence it has brought to their riding. The Phoenix is the performance benchmark for all other DH bikes to follow.- 8.15” (207mm) of travel.
- Adjustable head angle with 0, and +/- ½, 1, or 1.375 degree settings via the Cane Creek Angleset.
- Changeable dropouts allow easy adjustment of wheelbase to suit course conditions and rider preferences.
- Shock and main linkage are mounted as low as possible in the frame, giving the Phoenix DH excellent cornering and handling characteristics and access to all damping adjustments on the Fox RC4 Kashima shock.
- Complete bikes weigh in at sub 38lbs. (17kg). Race team bikes as low as 35 lbs!
- Standard 83mm Threaded shell with ISCG05 mounts.
- 150mm rear spacing with 12mm through axle.
- Black Phoenix frames ship with Green decals installed with additional sets of Blue and Orange decals included. White frames ship with Blue decals installed with additional sets of Green and Orange decals included so you can customize your rig!
- $6599
×Pivot Phoenix X0
- $6599
×Pivot Phoenix X0
- $6599
×Pivot Phoenix X0
- $6599
×Pivot Phoenix X0
- $6599
×Pivot LES XTR
There are some days when the race just demands something a little (or a lot) more rigid. We know that weight matters and that the pursuit of the win is often based on having the lightest, fastest machine possible. We are excited to introduce something different and still uniquely Pivot to our line: A Pivot without a pivot. With the all new full carbon Pivot Les 29er we’ve created a frame that offers the complete package: A balance of frame stiffness, tuned compliance and straight up performance (and we look good doing it too). In addition to the sub 2.5lb frame weight and incredible ride performance, the Les features our all new patent pending switchable Swinger adjustable dropout System. The Swinger System adds versatility to your bike X2. The included high modulus carbon dropout features our 12 x 142mm through axle design while the optional Swinger adjustable system allows single speed riders the simplicity of a vertical dropout design with quick click indexed adjustable chain tensioning. For single speed riders this is a revelation in simplicity and pure functionality. So, for those wanting to go fast with gears or without, the new Pivot Les offers you the ultimate ultra lightweight go fast tool in a high performance race package like only Pivot can provide. Once again Pivot is “Performance Redefined” with the all new Pivot Les.- Pivot exclusive hollow box, high-compression internal molding technology allows for greater compaction and smoother internal walls resulting in a lighter, stronger, highly optimized, ride tuned frame design.
- Included full carbon molded 12mm X 142mm dropouts with replaceable hanger.
- Optional Patent Pending Swinger adjustable dropout system provides quick, consistent, indexed chain adjustments for single speed use along with fast wheel changes and no change in brake adjustments.
- Full internal shift cable routing with under bottom bracket access port design for hassle free installation.
- Tapered 1.5” headtube, Press Fit 92mm wide bottom bracket, and direct mount front derailleur simplify set up and maximize stiffness.
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES XTR
- $6699
×Pivot LES
- $6699
×Pivot LES
- $6699
×Pivot LES
- $6699
×Pivot LES
- $6699
×Pivot LES
- $6699
×Pivot Firebird SLX
The Firebird is the ultimate technical terrain, all-mountain weapon. For everything from enduro events to the gnarliest trail rides; there is no better tool for the job. With 6.6” (167mm) of travel packaged in the most efficient pedaling suspension design ever developed, it’s no wonder why the Firebird is a favorite among magazine editors, Enduro and Super D riders all over the world. The Firebird’s climbing traction, acceleration, and descending capabilities are legendary and unsurpassed in the world of long travel trail bikes. No matter if you’re sending it in Whistler, going for the overall in Downieville or riding a 6 hour epic through the Rockies, the Firebird will impress. Simply put, it is the definition of the ultimate long travel trail bike.- 6.6” (167mm) rear travel and 160mm to 180mm fork compatibility (170mm standard).
- Rearward wheel travel path for incredible square edge bump performance and unparalleled pedaling performance.
- Full 1.5 headtube accepts the Cane Creek Angleset, allowing the rider to further tune the handling. Several Firebird models now come with the Angleset as part of the stock build.
- ISCG O5 mounts included for single ring and chain guide compatibility.
- Patented Pivot floating front derailleur mount keeps the chain in the sweet spot of the derailleur for better chain retention. Combine with our custom MRP LRP 2X chain guide for perfect shifting performance and worry free chain retention in
- even the roughest conditions.
- post mount dropouts for maximum frame stiffness.
- The Firebird (like many bikes in our line) is all about versatility; allowing riders to do everything from 24 hour endurance races, to park/gravity riding, Super D and the occasional DH race but its real home is aggressive trails where the ride up is just as technical as the ride down.
- $4499
×Pivot Firebird SLX
- $4499
×Pivot Firebird SLX
- $4499
×Pivot Firebird SLX
- $4499
×Pivot Firebird SLX
- $4499
What’s with ISCG tabs on the 429 but not on the 5.7?
Beautiful bikes
When can I get a 650B Mach 5.7? I’ll be waiting for that one.
$150 for SS dropouts!?! My God Man!
It’s amazing how much larger the carbon tubing is compared to the alloy versions for only a 7% increase in stiffness.
Really dissapointed with the Carbon 429. Thought it would be a lighter version of the Alu 429 aimed at XC and Marathon racing, but with ISCG tabs and dropper post routing, this doesn’t seem to be the case? Seems more like a competitor of the Giant Trance – but that has more travel.
Pivot should have left the 429 as a lightweight race machine, and then made a 29er version of the Mach 5.7.
sweet rides, but i like the nose picker @ the 8 min mark
Disappointed not to see a 650b bike from Pivot. Chris is usually leading the trend. So hopefully see one by Sea Otter. I could care a less about the 9ers. I’ve only ridden 2 that I would buy and Santa Cruz makes both of them.
I have old pivot 5.5 . Very agressive trail bike. waiting for new 650B type.
When pivot going to have 650B?
I have a mach 5.7 Carbon. beauty bike. Not the reason for my comment. I worry a little about their internal routing. Even the cable routing on the 5.7 is bad it you want to run full length hosing. They only have an option for a segmented rear derailleur cable.
I tried the segmented cable housing but in the Pacific NW here in BC, It wouldn’t last very long. With full length cable housing they bike suspension pivots usually ware out before the shift cables need to be replaced.
