Pivot Mach 5.5 Carbon trail bike
140 rear and 160 front for this rowdy trail bike made for 2.6 tires
27.5 All Mountain Trail
Available in Black/blue as well. Photo by Jens Staudt
FAQ
Which size bike should I purchase?
To ensure the best sizing, we recommend that you visit your local Pivot dealer to get a professional fit and refer to our geometry chart to check your measurements. We can, however, provide a rough guideline to get you started. These recommendations are based on our experience, athlete preference and customer feedback:
X-Small: 4’11″ – 5’4″
Small: 5’4″ – 5’8″
Medium: 5’8″ – 5’11″
Large: 5’11″ – 6’3′
X-Large: 6’2″ +
We suggest that you pick your Mach 5.5 Carbon size based on your riding style. The Mach 5.5 Carbon features trail bike long and low geometry with both shorter seat tube and head tube measurements per size – this geometry means that most riders can go up or down a size and should base their choice on riding-style, reach and stem length preferences. Be sure to also consult our dropper post fit guide when making your selection. You can always reach out to us on Live Chat for additional guidance.
Amasa back trail caters to many passions. The smile on the faces of the 4-wheelers was very similar to ours. Photo by Jens Staudt
What dropper post length should I use on my Mach 5.5 Carbon?
The Mach 5.5 Carbon features a low stand-over height and short seat tubes to allow the use of longer travel dropper posts and/or more flexibility for a wider range of rider sizes.
There are some limitations that each dropper post can accommodate for each frame size based on the individual rider’s saddle height, so it is important to check fit before choosing the travel and model of dropper post for your Mach 5.5 Carbon. Use the linked guide to find the right post for your bike:
http://www.pivotcycles.com/wp-content/uploads/2016/06/Mach55Carbon-Dropper-Fit-Guide.pdf
Bernard Kerr climbs out of saddle.
How do I set the sag on my Mach 5.5 Carbon?
We make it easy to get the best ride out of your Pivot bike with a simple sag indicator already installed on your bike, and this follow-along video featuring our own Bernard Kerr: https://vimeo.com/pivotcycles/sag
Sag indicator is one of the best tools around. Photo by Jens Staudt
Can I run a water bottle on the Mach 5.5 Carbon?
Yes, the Mach 5.5 Carbon features 2 sets of bottle mounts on the Small to X-Large frame sizes. One mount is on the top of the down tube and the other bottle mount is underneath the down tube. Every size clears a full size water bottle inside the front triangle.
What hub/wheel spacing does the Mach 5.5 Carbon use?
The Mach 5.5 Carbon uses the Boost 148mm X 12mm hub/wheel spacing. This is a hub design with wider flanges so you cannot take a current 135mm, 142mm, 150mm, or 157mm hub and change end caps to convert an existing hub.
Mach 5.5 feels right at home in  technical loops.
What size seatpost does the Mach 5.5 Carbon use?
The Mach 5.5 Carbon frame uses a 30.9mm seatpost.
What size seat clamp does the Mach 5.5 Carbon use?
The Mach 5.5 Carbon frame uses a 34.9mm or 35mm (as some manufacturers call it) seatpost clamp.
Room for a front derailleur. Photo by Jens Staudt
Can I mount a chain guide on my Mach 5.5 Carbon?
Yes. The Mach 5.5 Carbon features ISCG05 mounts on the frame. Most upper guides on the market will fit and you can either use the ISCG05 mounts or some of the more compact versions that attach to an E-Type front derailleur mount. For full upper and lower guides, we recommend the MRP AMG for the Mach 5.5 Carbon.
What front derailleur does the Mach 5.5 Carbon use?
The Mach 5.5 Carbon uses an e-type Shimano side-swing style front derailleur only. Shimano produces the new e-type side-swing front derailleur in Deore and SLX for 10 speed drivetrains and XT and XTR for 11 speed drivetrains.
What travel fork can I use on my Mach 5.5 Carbon?
The Mach 5.5 Carbon was designed for either a 150mm or 160mm fork. The maximum travel length that can be used on the Mach 5.5 Carbon is 160mm travel.
What is the fork offset on the Mach 5.5 Carbon?
The fork offset on the Mach 5.5 Carbon is 51mm.
New Pivot bars use the WTB Pad-Loc system.
How wide of a tire can I run on the Mach 5.5 Carbon?
The Mach 5.5 Carbon can run 27.5” tires up to 2.6” inches.
How large of a rotor will fit on the Mach 5.5 Carbon?
The Mach 5.5 Carbon was designed for a 180mm rotor and features a 180mm post mount design so you cannot fit a 160mm rotor on the Mach 5.5 Carbon.
What type of rear brake adapter do I need?
No brake adapter is needed for a 180mm rotor. However, many manufacturers make adapters for larger rotor sizes, in which case you would need a 180mm direct mount/post to post adapter.
What cranks will the Mach 5.5 Carbon accept?
The Mach 5.5 Carbon will accept all cranks designed for the BOOST system and compatible with a press fit 92mm bottom bracket. BOOST system means that the rear hub spacing is 148mm and the chain-rings have been shifted out approximately 3mm from where a tradition crank designed for a 142mm rear hub would be so that the chainrings will line up properly with the new position of the cassette on the 148mm rear hub.
Pivot pad-loc grips feature soft durometer ends and an assortment of color
Can I run non-Boost™ cranks on my Mach 5.5 Carbon?
In some cases you can run a conventional non-BOOST 1X or 2X crank. The Race Face NEXT 1X and other Cinch system 1X cranks are dual compatible between standard 142mm and 148mm Boost rear ends. Some smaller chainring combination 1X (30 and 32T) Shimano XT and XTR 11 will also work. In some cases 2X standard cranks may also work with 24/34, 26/36 and 22/36 combinations. Shimano’s new 11 Speed XTR and XT standard cranks feature both 24/34 and 26/36 chainring options which work perfectly with the Mach 5.5 Carbon frame as Shimano’s chainline dimensions already tend to run wider than others in the market. There may be other 2X non- boost cranks available that will work although it is dependent on specific chainline and chainring size. If the chainline is not out far enough, the front derailleur clearance may be tight when shifting into the small ring as the front derailleur mount on the Mach 5.5 Carbon is also shifted outwards to accommodate the BOOST design.
Additionally, you cannot run cranks designed specifically with a narrower Q Factor such as XTR Race 158mm Q factor crank and the SRAM XX1 156Q crank (In fact, for any SRAM 1X cranks, you need to run their specific BOOST version of the crank).
Bernard Kerr playing in rolly terrain
What is the narrowest Q factor crank that the Mach 5.5 Carbon will accept?
The Mach 5.5 Carbon will accept cranks with a standard Q factor measurement as low as 163mm. You cannot run cranks designed specifically with a narrower Q Factor such as XTR Race 158mm Q factor crank and the SRAM XX1 156Q crank
What bottom bracket is used on the Mach 5.5 Carbon?
The Mach 5.5 Carbon uses a Press Fit 92mm BB. Some bottom bracket manufacturers may refer to it as BB92 of PF92 as well. Every crank manufacture offers Press Fit 92mm BB options.
What is the eye-to- eye shock length and stroke length on the Mach 5.5 Carbon?
The eye-to- eye shock length is 7.875 inches (200mm) and the stroke length is 2 inches (50.8mm).
Pivot now has line of stems extending down to  35mm
If I want to run a different brand of shock on my Mach 5.5 Carbon, what else do I need to know?
The Mach 5.5 Carbon shock uses M8 through bolt hardware on the front and no hardware on the rear. Shock spacer dimensions are 36mm wide front. On the rear of the shock, the spacer hardware and bushing will need to be removed as the rocker mounts directly to the shock body. Some shocks may have a different spec then the Fox shock (that the Mach 5.5 Carbon is designed for) and may not fit properly. Also, as we cannot test every shock on the market, riders assume some risk if they choose a shock that does not fit properly or is not tuned correctly for the bike. The frame is designed around a large volume air can. We run medium compression valving and medium rebound damping.
Can I run a Cane Creek Double Barrel Air shock on my Mach 5.5 Carbon?
Yes, as long as you order the correct eyelet size (15mm eyelet).
Fox Float DPS rear shock. Photo by Jens Staudt
Can I put a coil-over shock on my Mach 5.5 Carbon?
You cannot run a coil-over on your Mach 5.5 Carbon! The Mach 5.5 Carbon was designed to work with the progressiveness of an air spring. A coil-over shock (even one with separate bottoming control) does not offer the progressive spring curve that the Mach 5.5 Carbon requires. Running a coil-over shock on the Mach 5.5 Carbon will result in hard bottoming and damage to the frame.
For more information visit www.pivotcycles.com.
Wordpress Comments:
  • Highway Star says:
    NO 26″, NO SALE.
  • david says:
    wonder if you can run 2.35, 2.4, 2.5 tires on the aluminum rim that comes with the bike? Or are the rims too wide for those?
  • Geoff says:
    Not sure how this bike fits in their line up. While in the market for a new bike, I’m not sure this separates itself from the Switchblade or Mach 6. Tire size alone won’t do it.
  • sloonz says:
    It’s practically a carbon copy of the Ibis HD3.
  • Gator says:
    I might need to go with the 5.5 since ” frame only” not available on switchblade that is totally Ridiculous. I never buy complete bikes, some people know exactly what they want!! Get it together PIVOT!!
  • Saris Mercanti says:
    @Gator
    If I had to guess, Pivot doesn’t offer the Switchblade as a frame only because of the Super Boost rear and cranks. While their are lots of components on the market that work for those standards, there’s bound to be people who would be confused….Just a guess.
    The 5.5 is also a fun bike!
  • Gator says:
    It’s really not that hard to get any of the parts, I called my dealer got the Race Face F300037 143.5mm spindle for my Next sl crank. Called my wheel builder got a 12×157 DH hub, the so called super boost with the flange moved out a few MM is a joke.
    I guarantee no one in the world can feel the difference between super boost hub and a Onyx 12×157 rear hub with the same carbon hoop “28 hole” with Sapin CX ray spokes. The rim makes the biggest difference!! It’s all about educating your dealings so they can relay the correct info the the customers, really simple!!
    If the Mach 5.5 climbs better than the Switchblade on the rocky East Coast it may be my next bike!! I need to demo both bikes to decide, my gut tells me Pivot will come through soon!!
