What is it?
The Pivot Trail 429 is the revamped version of Pivot's sweet spot trail bike with enough travel to go fast and play. 120mm of rear travel is matched up with 130mm front.
Highlights
It features a laterally stiff carbon frame weighing in at 6.4 lbs surrounded by a package designed to be quick, agile and capable downhill. Travel is 120/130mm front but it can take a 140mm fork as well. Plus wheels are available, just like the Switchblade with 27.5 x 2.8 packages. Also, 2.6 29er tires fit and DPS or DPX2 shocks are available. Build kits include Shimano 1x11 or Sram 1x12.
What changed?
It's now Superboost+ equipped so it requires a 157mm rear hub and matching cranks.
It's no longer front derailleur compatible so 1x drivetrains ones can be used.
The outgoing 429 Trail did not suppor Shimano Di2 but the recent releases by Pivot have. This one does not support it as well although battery port exists since it's a convenient way to access cables in the down tube. But there are no holes for the derailleur wires exiting the frame. A motivated owner can punch small holes in the frame to route Di2 cables.
Geometry?
Geometry is 74 degrees seat tube mated with a 67.3 head tube complemented by a long reach of 440mm for a medium. Chainstay length is a short 430mm with support for tires up to 2.6.
BB height is 13.5 inches or 343 mm.
How does it ride?
Before we get too far into the tech and spec discussion, we wanted to take a moment to discuss how it actually rode. We got the opportunity to ride it in one of the most demanding and fun trails in Moab, UT, the Mag 7 to Portal trail. It's a trail with a natural pump track playground on top of a rock Mesa. There are short technical and long climbs mixed in and it concludes with one of the most harrowing descent trails in Moab, the famed Portal trail.
A 120mm bike would not be my first choice on this trail because of the endless, drops, steps and the closing highly technical trail. There's just too many ways to hurt oneself if one runs out of talent or the bike runs out of travel. But the Pivot crew wanted to show us the broad sweet spot of the bike so we gladly donned our knee pads and played along.
The rear DPS equipped suspension was active and responsive but it was not a supple pillow. In these conditions, the ride was engaging and communicative but it was demanding as well. Proper loading and unweighting of the suspension during the roughest parts as well as smooth line selection were key to its success. It was no tractor so one couldn't mob the rocks and plow through them. Get the timing wrong and the bike sometimes stalled before clearing the rocky steps.
When it came to descending rock piles and drops though, the bike was quite able. One could feel the bumps more than the latest crop of long travel 29ers but this seemed to get through them quite well. We learned to trust in bigger and bigger drops and obstacles. The key was to become a more active participant and not just hang on for the ride. Proper preloading of the bike and popping up rocks was a great technique.
Cornering, this bike really shined as it seemed very secure laterally. The bike tracked a line very well. The tire combination with a Maxxis Rekon rear and Maxxis DHR II front paid dividends as well with incredible front braking that allowed it stop securely or slow down early to set up for corners. It seemed to corner a lot like the Switchblade, holding a line and changing directions when the rider asks.
Climbing and accelerating, this bike excelled with quickness and agility. The benefits of a 120mm trail bike were demonstrated well here with enthusiastic acceleration out of corners and up punchy climbs.
At the limit of its travel, the bike behaved well, it got stiff at the end of its rear travel but it was controlled near bottom out. Adding volume spacers or opting for the DPX2 rear shock are great options for those that like to hang out in this realm of the rear travel.
At the end of the grueling Mag 7 to Portal ride, everyone came out safe and uninjured. A little beat but with great stories and experiences with a more involved and 'connected' ride on this route.
Those colors
Two colors are available, Crimson and Steel Blue, both in satin finish. Both colors are incredibly attractive with dialed accents so we'd be hard-pressed to predict which one will be the more popular color.
This is a departure from Pivot's efforts that always seemed to include one variation of black. Or other companies would release a gaudy 'cover shot' color and a more subdued one, giving less practical options for the customer. This offering will give the customer two legitimate choices that will make selection more difficult but will make a lot more folks happy.
Sweet Spot
Trail bikes are what most people buy because they are ultimately what fulfills the needs of many who want to explore, play and go fast at times. The new Trail 429 answers many, many calls not just in its base configuration which we rode (29er with DPS shock) but with its many available permutations.
It can handle both 29er and 27.5+ wheels with a 17mm headset cup to adjust head angle and bb height.
It can also take a DPS or DPX2 rear shock. And if the 130mm fork is not enough, a 140mm will not be a problem at all.
Shimano 1x11 and Sram 1x12 will be available configurations as well to satisfy the needs of most.
No aluminum and no frame only options
There is no aluminum frame option currently and Pivot did not sound optimistic about its release in the future. The cost savings over carbon are not substantial anymore because of volumes and the cost of developing an aluminum frame of this complexity.
One unfortunate reality is there's no frame-only option as well. Because of the Superboost+ rear hub and crank and they're limited availability in the aftermarket, Pivot wants to control the build kits to ensure the frames are built up with compatible components. Certainly understandable but a very tough blow for those who want to customize the bike with their own components like wheels, bars, dropper, saddle, etc.
But with Shimano and Sram build kits available and starting at $4700, most buyers will be pleased with the available choices.
Buld kts and pricing
Trail 429 Pricing for 29er or 27.5+ USD
TEAM XTR 1X $7,799.00
TEAM EAGLE XX1 $8,699.00
PRO EAGLE XO1 w/ Reynolds Carbon upgrade $8,099.00
PRO EAGLE XO1 $6,799.00
PRO XT/XTR 1X w/ Reynolds Carbon upgrade $6,999.00
PRO XT/XTR 1X $5,699.00
RACE XO1 $5,199.00
RACE XT $4,699.00
For more information, visit www.pivotcycles.com.
