Poison Oak photos and remedies
Spring brings about sun, riding and unfortunately, poison oak
How To
What do we do about it?
Read on for advice about poison oak.
Advice by Francois
1) Know what it looks like and where it lives –  You need to get familiar with all its mutant forms and how to identify it quickly. In spring, it is fairly easy but when the red stalks are gone, you need to be able to tell just by leaf shape alone.
2) Do not go there – Once you know where it lives, just don’t go there when it’s peak season.  Go somewhere else or go in that trail with a hazmat suit.
3) Dodge it – It takes years of training to ride singletrack at 20 mph, spot the poison oak and dodge it with full body english. You need to duck, hop, zig and zag.  If you are going to make contact, slam on the brakes and walk. Do not touch it!
4) Wipe, wash, sterilize your gear immediately.
5) If you’ve made contact, you have a few hours to minimize the damage. This can be the difference between an itch for a day or a pure misery for weeks.  Wash up with Technu Extreme, Turpentine, Dawn dishwashing detergent, a rough dry soap that breaks up oils.
6) Do not scratch. Do not sweat and don’t expose it to sunlight.
7) Do not experiment if you have a severe case.  Don’t listen to the 1001 superstitions out there about sleeping upside down and eating honey from a poison oak honey bee. This is no time to risk failure.
8) If you are exposed. See a doctor and get the prescription for steroids. This is the only real cure. There is a cream, pills, shot for various severity of exposure.
Advice by Sandra Baker
Oh my gosh, where to begin. I am a poison oak/poison ivy researcher.
After exposure to the plants, some of you actually go home, or wait till you are in your car before you clean your skin. For the seriously allergic, you have only a few minutes before the oil starts being absorbed into your skin and the immune system is alerted. Others have more time. Why not have your skin cleanser of choice on your bike? For the unprepared—here is what you do. Did you see the post about mud? This writer was on the right path, except you dont need water in the mixture. Dig down through the ground mulch to clay–real dirt. Clay attracts oil to itself. If the molecules are full of water, it cant, and has to dry. So mud is okay if it has time to dry on your skin, but best is to take dry dirt and scrub your skin over and over with it.
You can smear your body with mud for your ride, but it will fall off. Easiest is Ivy Block, which is made from a special—yep—clay, and it does not show. It has been clinically tested and works pretty well supposedly.
Zanfel has been clinically tested, and can sometimes stave off a rash if you dont wait too long to apply.
Bleach will dry the blisters up, but can leave life long scars. Brake cleaner will get the oil off because it is composed of toxic petrochemicals. Tecnu has the least toxic petrochemical in it, and works well.
For a rash, very hot water or a hair dryer moved in close, and removed before burning the skin works well. It too has been clinically tested and proven effective by acting on the itching nerve network. (yes itch has its own nerve network separate from the pain one. Thats why opiates will not touch itch). I used to get 6 hours of sleep from heat, but a hot shower doesnt cut it. It has to be real hot, and you just put a limb under the water for a second or two.
My credentials: I wrote “The Poison Oak & Poison Ivy Survival Guide”
Advice by R3R3R
Poison Oak
1) Avoidance: Learn to recognize it (that means during all seasons and at all speeds – I can even tell where it will usually grow and can identify it at speed on a mountain bike or a motorcycle). If you know it is there, avoid it. That can mean taking a different line on a trail, or even not taking a trail if you know it is overgrown.
2) Wash: Bring a water bottle with you (easier than rinsing with a hydration pack). If you know you have brushed against some, rinse with cool water as soon as possible. Do not rub, do not use soap, do not use chemicals. Rinse with cool water. If a stream is nearby, you might want to stick your arm/leg in or splash some water on the area of contact.
This is followed up by rinsing in a moderately cool shower as soon as possible after returning from a ride. Don’t forget to also wash all of your gear and even to wipe down your shoes and pedals (and any other parts that potentially came in contact). Otherwise you will get contact exposure from those items later.
The reason that this method works is that water apparently neutralizes the urushiol oil (the toxin in poison oak/ivy/sumac) and also washes it off. The key is to wash before it penetrates the oil layer on your skin. Some folks can tolerate the urushiol on their skin for a long time. For me, it is about 3-6 hours (long enough for a ride). Some folks will get it either way, esp. if the branch or leaves scratch your skin and break through the oil layer immediately. From what I’ve seen, keeping your oil layer intact is important (I also advise wearing full length gloves and long sleeves if it is not too hot). If you use skin products or soaps before the ride that keep your skin really dry (cleansers, alcohol, etc.) you could end up having less protection against poison oak.
I think that technu provides an additional barrier (the kind you put on in advance) but I don’t think it would stop a branch scratch. I think they also have a washing product as well. I don’t use any of that. I am careful not to touch the poison oak, and I rinse immediately if I think I have brushed it. After returning home, I rinse my gear and myself before soaping up or using any other products. I almost never get poison oak anymore (yet I ride around it all the time). The exceptions seem to be when it scratches me, or if I forget to wash my gear completely after a ride.
If you do get it, try not to scratch (it will spread, last longer, and may leave scars). I know, it is easier said than done…
Advice by Ebeer
Poison oak is spread by the oils in plant. There are no great options for those are a particularly sensitive, but these are some options that might “help”:
1) Wear long socks or pants
2) Use Ivy Block (supposed to create a chemical barrier that prevents or maybe discourages oils from absorbing into the skin)
3) Carry alcohol wipes or special Ivy wipes with you when you ride. Wipe down at breaks or when you think you may have been exposed
4) Wash immediately after rides. There are many options here: Maries Ivy Soap, Technu, etc. Many including myself report that Dawn dishsoap is effective as any of the very expensive alternatives. The key is to wash quickly, wash with cool water, and get out of clothes that may have been exposed.
5) Do not scratch. EVER.
Post some photos in this thread and we’ll feature them in this article: http://forums.mtbr.com/california-norcal/assignment-poison-oak-photos-remedies-717226.html
So share with us your unfortunate experiences. How badly have you been exposed?  How do you combat this evil weed? What is your version of poison oak in your area?
Wordpress Comments:
  • Nate says:
    I am not terribly allergic to urushiol, so of the three mentioned, cactus would be my worst nemesis. However, you left off some notable ones. Here in TX, bullnettle is rather painful. A plant with a similar reaction farther north would be stinging nettles. Bullnettle tends to be low growing, so risk is low. I’ve seen stinging nettles over 7ft tall.
  • Chuck Dungan says:
    Im in Oregon and poisonoak is a killer.Tecnu for sure to cure the rash. I also take herbal poison oak drops that seemto decrease my abilityto catch P/O.
  • Francis says:
    The problem with poison oak is that if you don’t take care of it, it can stop you from riding for weeks. Since then, I’ve educated myself against the enemy.
  • BadHabit says:
    Heat up oak and ivy rash with a blow dryer and itching stops for hours.
  • NEPMTBA says:
    In my car I carry a squirt bottle with Dawn dish soap mixed with water, after the ride I squirt it in my arms, legs, then dry off, till I get home and shower!
  • Paul de Valera says:
    I have a great but extreme method for getting rid of that crap. I take a Scotch Brite pad and some ajax and scour my flesh off in the affected area. Being a mtbr, I’m used to scabs and scabs beat “the oak” any day of the week. I sand down to the layer where you get that yellow ooze and a little blood, that usually does the trick, the itchy evil is replace with a thin but largeish scab. fixed. Ointments and cremes don’t seem to do much at all. This way you stop the spread and can get back on the bike the next day.
    • Brian Teal says:
      Heh! I JUST posted this beneath yours and didn’t even read yours yet! I do it with bleach, but maybe I’ll try Ajax next time. ;^)
  • Brian Teal says:
    I catch PO so easily, but I ride through it a lot, so here is what I have found to work best for me…
    1. If I go through PO on the trail, I stop at the first mud puddle I see and grab hand fulls of mud and rub it all over the area I think I touched it. It then dries and takes the oils off (I think, because it works).
    2. If I do get some bumps appearing, I rub them hard with bleach and a rough towel, to almost breaking the skin open (come on, toughen up wimps ;^). If I can keep it clean, the bumps and wound are gone within 3 days, better than a week or two of constant scratching! Be careful not to let the raw skin get infected though, keep it clean…
  • Andrew says:
    The Ajax/bleach method is pretty sketchy…but I’ve also had PO/PI bad enough that I just want to chop the afflicted part of my body off.
    For anyone riding near the coast- if you can cruise on your bike to the ocean, it’s worth taking a dip – however cold- in the water to get it off you and all your clothing.
    I also take rhus toxicodendron pills…little sugar coated pellets of the extract, and it seems to provide help increasing tolerance (might be false), as well as getting over the outbreaks.
    Correct me if I’m wrong, but I believe PO/PI are also cases of reverse immunity…you become more susceptible to it the more you catch it. My least favorite plants on the planet.
  • slocaus says:
    I was fortunate to stumble and crawl through the PO, while surveying and building trails, with the west coast expert on the vile stuff. Here is his website. http://www.curtbeebe.com/index.html
  • bcinlas4 says:
    After a rince with cold water, I rub down with brake cleaner. It eliminates all traces of any oil. It works for me, but I’m not overly sensative to it.
  • wheel 84 says:
    Lather Lemon Joy on all exposed areas prior to riding, Wash it off with cold water later, It blocks the oil. I still try to avoid poison oak, but I haven’t got it yet using this
    method. A paint balling pharmacist told this to a friend. Lemon Joy, accept no alternatives.
  • jMoore says:
    Preventative:
    ::: roll on deodorant to your exposed arms and legs before exposure. I’ve found this works really well (in Ohio >> Poison Ivy) when I apply immediately before the ride.
    ::: immediately after a ride I apply Tecnu Poison Ivy soap to all exposed skin
    If I still get it:
    ::: for light cases I apply Tecnu several times a day. After 3 days it usually dries up.
    ::: for heavy cases I’ll use Tecnu Extreme where I take a ultra hot shower (you actually get a major endorphin rush with hot water on the itchy spots!) then apply the Tecnu scrub … repeat with hot water then the scrub. It usually goes away in 3 or 4 days or so.
    Untreated it’ll last 2 weeks on my skin.
  • Sandra Baker says:
    • Steve says:
      Sandra, As a life long poison oak sufferer I want to thank you for your sound advice. I have spent countless, itchy hours researching the stuff and cannot stand for people recommending bleach etc. as a solution. You guys are kooks and you are going to burn your skin off.
      A couple great products I have found are made by IvyX. They make single serve pre and post contact wipes. Perfect for tossing in your camelback or car. Dawn dish soap also works just as well as technu IMO, but you need to be clinical with it and really scrub well with a wash cloth. Pretend you are getting axle grease off your skin everytime you ride and you should be in the clear.
      Once you get it you are pretty much screwed. Prednisone is really the only solution, but Benadryl (the pills) can also help. I have yet to find any evidence that any topical anti-histamine does anything, but there is some that systematic anti-histamines will help.
      The heat approach will overwhelm the nerves and give hours of relief, but I also find that it can make the rash and sores puff up and leak a bit more, basically look worse. So I try to just tough it out, but go to the heat if I can’t stand it.
  • Francis says:
    Thank you Sandra Baker!!! Wonderful info.
  • mtnbikej says:
    I have found that any of the “orange” hand soaps you find at the automotive stores works wonders on the oils from PO. The pumice and degreasing qualities of these soaps does a great job at removing the oils. Also, a 1 gallon jug can be had for around $10. I will usually lather up and wash off exposed areas 2-3 times at the inital bathing after the ride. In addition, use cold water during first bathing if exposed. Hot water will open up the pores of your skin allowing the oils to penetrate quicker. If you do get PO and a rash breaks out, continue using the pumice soap and warm water to get any left over oils off.
  • Andrea says:
    Ice. Ice packs on the itch if I didn’t catch it soon enough. Straight ice. All the rub it off, petrochemicals, technu in the world doesn’t do for me what a frozen-as-he|| ice pack does. It’s probably hitting the itch receptors the same way as the hot shower…
  • Itchy Bawls says:
    I find the best way is to combine all the approaches.
    1) Give yourself a good paint thinner coat before riding to prevent poison oak oil from sticking.
    2) after riding douse yourself in gasoline.
    3) light your self on fire (just for a minute, you want to be a little crispy on the outside but still chewy on the inside).
    4) douse yourself in bleach after about 10 seconds of burning to put out the flames.
    5) use the battery acid to exfoliate that dead crispy skin right off.
    You will be left with a nice fresh layer of pink virgin skin!*
    *Do not use this technique more than once per week as layers of skin take a few days to regenerate.
    • WSmac says:
      …ooooh…. to have pink virgin skin again!…. THANKS! :)
      uh.. can I use this even IF I haven’t been exposed to poison oak?
  • Andrew says:
    I used to use Ivy Block and Tecnu religiously but it seemed like I would always get a nasty case of PO after riding, even if I was almost certain that I had not touched PO. With the help of my doctor I eventually figured out that I had developed an allergic reaction to the ingredients in Ivy Block and Tecnu and was reacting to that and not PO.
    mtnbikej is right about the orange hand cleaners, they work great. I also find that dish soap is fairly effective.
    When I wash I scrub exposed areas first being careful to keep the rinse water away from uncontaminated areas of my body. I scrub and rinse exposed areas 2-4 times depending on level of exposure. I would say that I spend up to 30 minutes on my “poison oak scrubdown” after exposure. I think a good way to visualize how hard it is to remove the oils is to think of how hard it is to get the black stains off your hands after working on greasy bike parts or working on a car. It can take a few minutes of scrubbing just to get black grease stains off your hands with hand cleaner. Imagine that you have those black stains all over your body and scrub accordingly. If you do this you will only get PO where you have had direct plant contact. You will have no problems with the rash spreading.
    The best piece of advice though, is to ride with long sleeves on and then to carefully strip and bag your shorts, socks, gloves, and jersey as soon as you get back to the car. Then put all that stuff through the washing machine with extra detergent and hot water.
  • David Turner says:
    SIMPLE GREEN! I carry a spray bottle and roll of paper towels in the van and immediately after riding anywhere near PO wash all exposed skin 2x with Simple Green then rinse with water. When I get home I wash helmet and shoes with Simple Green and toss all the other kit in wash machine. My wife skipped the Camelback wash years ago and the straps were carrying the oil, of course she figured this out the hard way with big swaths of blisters around her shoulders (tank tops….) If I KNOW I will be riding anywhere near PO, I also make sure not to forget the sunscreen on all exposed skin. I know that sunscreen is supposed to be part of our pre ride prep, skin cancer etc, but sometimes I skip it as I hate the slimy feel, unless I know there is PO around! This effectively seals the pores and with these two topical I have not hand a single outbreak in over 10 years.
    DT
  • Chris Gaunya says:
    Tecnu works really well for me. I haven’t tried the dirt bath on the trail but I will keep it in mind. Usually, I get home take off everything I was wearing while riding and throw it in the washer immediately including my shoes. Then I jump in the shower and scrub with tecnu or orange dish washing liquid. I am very sensitive to poison ivy and have spent my fair share of miserable summers as a kid.
  • Rich Nichols says:
    OK, hear it is. Put soap on your fore arms, hands and shins, before you ride! As soon as you can: peel your clothes into the wash. Wash your hands and fore arms with cool water ( so the pores in your skin stay closed) and soap Three times. Tecnu if you have it. wash lower legs three times. now wash the rest three times. If you feel you are getting a rash. Rub the area with Tecnu for two mins and rinse …And don’t fall in It!
  • Theo says:
    After years of building trail around poison oak the best way to make sure you don’t get a really bad reaction is to be sure you have some PO. I try make sure I’ve got a little PO in my system at all times so the reaction is not as drastic. I’ve had it very bad in the past but since I’ve been trying to have it I’ve not had a serious reaction. Do not take this as an encouragement to roll in PO! Also, put a small bottle of the strongest soap you can stand in your pack…that way if you do accidentally land in a PO bush(as I have) you have some chance of getting rid of it.
  • clint says:
    PLEASE BE AWARE BLEACH, GASOLINE OR OTHER HARSH CURES CAN PUT YOU IN THE HOSPITAL.
    It is not recommended to ever,ever use any items of that nature and I have know personally an individual who nearly cashed in after using bleach.
    The best and safest item you can use is a called ZANFEL which can be purchased over the counter at most drug stores.
    It is not cheap but it works and works very well and take notes cause I will let all of you in on a tip I learned previously.
    If you suffer from easily getting poisen ive,oak or what ever as I do and I work outside in this stuff daily during the warm months here in michigan.
    You want to use the ZANFEL to remove the oil and stop the itch BUT if the itch persist you want to go get your wifes hair drier in the bathroom set it on high and heat the area that has been affected.
    As you heat the area, it will itch like crazy for a moment BUT as its heated and becomes hot enough that you have to move the hair drier away so you dont burn yourself the itch will go away.
    Not only will it go away, it will be gone for the night ( up to 8 hours ).
    As I say heat till you cant stand it, move the drier back to regulate the heat on the area but keep the heat there for as long as you can handle, once the itch stops enjoy the relief..
    I do this along with the zanfel a few times a year and its a blessing and prednizone ( spelling??) does not work at all for me,,,
    You can thank me later..
  • Joel says:
    Yes on the ZANFEL. Anyone who rides needs a tube of this stuff in the bathroom. Wash up with Tecnu first, but then have then hit exposed spots with Zanfel and keep doing so if it starts to itch. Early, before it blisters.
  • Martin Schmidt says:
    Oral Ivy works for me.
    • Michael A says:
      Oral Ivy works for me too. Have had the best luck with this, and like the approach the most as you really seem to build up a resistance, as opposed to constantly playing catch-up trying to remove the oils or completely avoiding contact with the plant.
      I typically would get rrrrrreally brutally bad breakouts all throughout the summer until I started a regular regime of oral ivy starting in the late winter/early spring. Not eveyone may have the same luck with oral ivy, but my experience has been that I will still get the poison ivy/oak, but in very small amounts, usually only resulting in a couple of blisters that do not seem to itch as much, and clear up very quickly. I can deal with that nooo problem. I would rather put up with a small, tolerable amount than have to be uber paranoid all the time and be washing and rinsing and washing like crazy and using all kinds of weird remedies.
      My reactions for about 8 years have been Horendous, with next to no major exposure to the stuff. the last 2 years after starting with the oral ivy I have had minor breakouts that come and go but never really take over, and have actually managed to be able to WORK up to my eyeballs in the stuff. I have a small brook on my property that I have been working on clearing out all the deadfall, and pulling the vines down out of the trees. Major overgrowth of poison oak with vines a few inches in diameter, just like mentioned in the article. Crazy exposure, with very little reaction.
      Here is my approach:
      Prevention: Oral Ivy (Its a concentrated amount of urishiol that diminishes your reaction to exposure, which you just dilute in water and drink. Simple as that.)
      Washing: Gojo and or Poison Ivy Soap (Found this stuff in a local power equipment store that arborists use. Its a bar of soap made of saponified animal oils, jewel weed and spring water. Doesnt cost a fortune and lasts quite a while.)
      Relief: Hot water, as hot as you can tolerate.
      • Michael A says:
        Here is the info I found on the stuff:
        Boericke & Tafel Oral Ivy™ Directions.
        For prevention:
        3 to 5 drops in 1/4 glass of water daily by mouth 7-14 days before exposure and continue throughout the poison ivy season.
        For treatment of symptoms:
        10 drops in 2 ounces of water every 2 hours as needed. As symptoms improve, decrease to once every 4 hours, then twice daily until symptoms disappear. Place drops under tongue in 2 ounces of water at least 15 minutes before or half hour after eating, brushing teeth or drinking anything except water.
        Ingredients: (HPUS): Rhus toxicodendron (Poison Ivy) 3X
        •Natural Homeopathic
        •70% Alcohol
        •Prevents symptoms of Poison Ivy, Oak, and Sumac
  • Thomas says:
    In Belgium we only have Nettle Plants and the worst of all things in the world Ticks KILL EM ALLL!!
  • Jonathan says:
    Ivy Block has been discontinued. Ivy Defense is still available and also has sun block in it. I am very allergic and have found both products pretty effective at preventing poison ivy but not 100%. I still get multiple cases per year, but without them I would get poison ivy after every ride.
  • Karl says:
    It grows on my property, so I get it all the time no matter what I do! Prevention is great, but once you have it, the best thing to do is not itch. There is a Benadryl lotion that has changed my life, takes the itch away and is cool feeling.
  • Dmitriy Zasyatkin says:
    “Oral Ivy”, which is homeopathy, is the only thing that I’ve found to be effective at preventing it (building up a tolerance) and treating it once you have it, besides the steriod shot. If you’re highly allergic, don’t wait until you get a rash, start taking a few drops a day to build up a tolerance so that you won’t be affected because you probably won’t be able to recognize and avoid the plants all the time.
  • EpicAndy says:
    Faceplanted in a pile of the stuff this weekend at Demo. Then I blew up a wheel. Full rash by the time I made it back to the car.
    I look funny.
    ASS — you may now laugh.
  • Rudy says:
    Definitely don’t scratch. Ever! There are some natural ingredients like lavender that really help with the itch, and with the inflammation too. I’ve had pretty good success on a small patch with a product called Lavender and Calendula Soothing Balm from Botanic Organic. Made right here in Northern California. http://botanicorganic.com/products/babybalm
    I’d be curious if others have tried it and how much success they’ve had.
  • tracey says:
    Great went MTB trail that never been there and then learned that I got poison ivy two days later !!! went urgent care to get steroid shot… I use my dog tea tree shampoo to wash my body and baking soda.. but still feel itchy… IS there any products that you can put on your body before ride MTB to keep from getting poison ivy or else???
    • Mtbr says:
      Dang–that sucks! Technu is a good preventative step, followed by a cold water rinse at your car post-ride. Running water as hot as you can stand it over the affected area releases histamines and brings relief for several hours–just don’t scald yourself.
  • Eric White says:
    This stuff is magic for Urushiol oil:
    http://www.allstop.com/poison-ivy/poison-ivy-treatment/index.html
    If I hadn’t tried it with amazing success I would not have believed it.
  • Grimgrin says:
    As someone mentioned before, I am also immune (or very very resistant) to the poison. After reading this article and comments I will definitely start carrying some treatment materials for other people though.
  • ean says:
    If you have been in poison oak don’t rub your eyes and try not to take a leak.
  • Matthew says:
    I grew up in SoCal, and that nasty plant was everywhere I liked to play – creekbeds, hiking/biking trails, parks, fishing holes etc… I get it severely. I have learned some tricks to make it go away faster after exposure and/or the rash develops. Go to a swimming pool with chlorinated water… then stay in there as long as possible. If a swimming pool is not available… go into the ocean and stay in there as long as possible. I believe the chlorine and/or salt dries the rash quicker and prevents spreading. Also, before the rash gets all nasty and blistery, when it is still in it’s beginning stages, I will take a fingernail scrub brush and attack the red area with straight Chlorox bleach. I’ve scrubbed layers of skin off… and it burns like hell, but I think it minimizes the blistering, be careful though because scarring may occur. I have not had poison oak in years because if I see it I stay away. I hate it so much that if a bear/mountain lion was chasing me, and my only two options of escape would be through a poison oak patch, or to jump off a cliff that would surely result in broken bones… you can bet I wouldn’t hesitate to jump. There is no reason poison oak should even exist… if God made one mistake, it is the poison oak plant.
  • I_Like_Pie says:
    Look up “Mean Green” on amazon and read the reviews. No need for thanks.
  • Bob n Knob says:
    Mike at Michael’s Bicycles in Newbury Park loves nature and the outdoors. He told me that he studied up on building an immunity to poison oak by eating it. Just did a search and found: Jack Elliott’s Santa Barbara Adventure
    I doubt I ever will but for those that are thinking of buying a hazmat suit may want to give it a try.
    BTW I also have heard that for those that are not allergic to it, every time you get exposed it, it slowly breaks down your immunity to it.
    And I don’t care how bad you’re exposed it would never stop me from drinking beer.
