Race Face Next R line of carbon components
Coming out strong with a massive line of lightweight All Mountain components
Components Wheels
Race Face Next R Handlebar
The Next R handlebar has an 8 degree sweep and three different rise options to ensure correct stack height. This is the lowest rise at 10 degrees.
Next R Handlebar
The Next R handlebar features 800mm of premium unidirectional carbon with the shred-ready positioning of our SixC bars. DH strength and Enduro weight for when you really need to lean into it. Sweep on this bars is very comfortable. And key to line is the available 10, 20 and 35mm rise to accommodate an assortment of travel and wheel sizes.
Features
  • Manufactured from UD Carbon with matte clearcoat
  • Carbon optimized ex for improved small bump compliance
  • 35mm bar diameter for incredible strength/weight ratio
  • Width: 800mm
  • Sweep: 8 degree Backward 5o Upward
  • Bar diameter: 35mm
  • Rise: 10, 20, 35mm
  • Weight: 215g
  • Price: $169.99 USD
Race Face Next R Components
An assortment of test bikes were all fitted with Race Face Next R components.
Next R Power Meter
Race Face took the heart of the lightest, most versatile production cranksets and gave it power measurement. The CINCH Power Meter gives one the tool to train for the Enduro and XC glory you truly deserve. Protected in your BB Shell, the CINCH Power Meter is out of harms way of the elements and the tight clearances between frame and crank these days. With an adaptable spindle, buyer can pick from NEXT SL G4 to our Turbine R cranks, and with our CINCH App and both ANT+ and Bluetooth, one can hook it up to a favorite head unit.
Features
  • Power Accuracy +/- 2%
  • Cadence & pedal efficiency data
  • Dual BLE / ANT+ for head unit compatibility
  • Battery life over 400h & USB rechargeable
  • Utilizing CINCH for 1x or 2x configurations
  • CINCH Power Meter App for iPhone or Android
  • Just 65g more than standard 134mm mountain spindle
  • CINCH Power Meter Spindle 134 AM (w/o cranks) – $599.99 USD
  • CINCH Power Meter with Next R Crank Arms – $1149.99 USD
Turbine Dropper
The dropper post has been improved with many lessons learned during the first year in the field.
Turbine Dropper
Turbine Dropper relaunched – hybrid mechanical and hydraulic locking technologies get refined internals to further improve the mountain top experience. A sealed damping system wrapped in 7075 aluminum makes for a lightweight dropper that is locked in the up or down position from pulling or pushing. Internal cable routing compatible for modern frame design and available in the two most popular drop measurements.
Turbine Lever
Turbine 1x lever.
Features
  • Cable actuated, hydraulic cartridge – In nite adjust within travel
  • Return speed adjustable
  • Same 2 bolt clamp system as Turbine and Next posts
  • Ergonomic 1x lever available
  • Standard shifter cable and housing
  • Size: 30.9mm, 31.6mm
  • Weight: 495 grams
  • Lengthy: (30.9x440x150mm w/o lever) 350mm, 375mm, 415mm, 440mm, 490mm
  • Travel: 100mm, 125mm, 150mm, 175mm
  • Head: Zero offset, 2 bolt micro adjust
  • Type: 7075
  • Material: Alloy
  • Price: $379 USD
Local Trails
Local trails were lush with a healthy dose of winter this year.
Pricing Summary
Next R Crank – $549.99 USD
Next R Wheelset (Front + Rear, 27.5 or 29) – $1499.99 USD
Next R Bar – $169.99 USD
Turbine R Bar – $79.99 USD
Turbine Dropper – $379.99 USD
1x Turbine Remote Lever – $59.99 USD
Modular options for CINCH Power Meter
For more information, visit www.raceface.com.
Wordpress Comments:
