Revealed: Trek Remedy and Slash 27.5/650b
27.5 News
Trek Slash
Slash has been redesigned from the ground up to pack everything we’ve learned about conquering the gnarliest trails and enduros into a 650b-optimized king of
the mountain. This bike is built to dominate: the mountain, gravity, your limits, the guy with #1 on his numberplate. Throw Slash down the most technical descent, fly back up. And win.
Lineup:
Slash 9 27.5/650b
Slash 8 27.5/650b
Slash 7 27.5/650b
1. Smooth, controlled braking
Our patented ABP (Active Braking Pivot) keeps your suspension from stiffening up when you’re on the brakes, giving you confident, steady control.
2. DRCV all-terrain control
Our two-chamber DRCV (Dual Rate Control Valve) shock gives you coil performance at air shock weight, for smooth, seamless, all- terrain control.
3. Fine tune your geometry
Our reversible Mino Link lets you relax the geometry when bombing descents, or tighten it when weaving through singletrack.
4. 650b & enduro optimized
Every detail is optimized and sized to maximize the advantages of 650b wheels, and the slightly racier geometry is tuned for the rigors of enduro.
Specifications
  • Sizes: 15.5, 17.5, 18.5, 19.5, 21.5”
  • Frame: Alpha Platinum Aluminum, ABP Convert, Full Floater, E2 tapered head tube, press fit BB, internal derailleur & dropper post routing, ISCG 05 mount, magnesium EVO link, downtube armor, Mino Link, 160mm travel
  • Front Suspension: Fox Factory Series 34 Talas w/CTD (climb-trail-descend) adjustable FIT damper, rebound, E2 tapered steerer, Kashima coating, 15QR thru axle, adjustable 130/160mm travel
  • Rear Suspension: Fox Performance Series Float w/DRCV, CTD (climb-trail-descend) damper, rebound, tuned by Trek in California, 8.25×2.375”
  • Color: Trek Black/Rhymes with Orange
  • Shifters: SRAM X0, 11 speed
  • Rear Derailleur: SRAM X0 X-Horizon Carbon, 11 speed
  • Cassette: SRAM XG-1195 10-42, 11 speed
  • Crank: SRAM X1, 32T
  • Wheels: Bontrager Rhythm Comp Tubeless Ready w/Stacked Lacing, 15mm front hub; 142×12 rear hub
  • Tires: Bontrager XR4 Team Issue Tubeless Ready, aramid bead, 27.5×2.35”
  • Saddle: Bontrager Evoke 3, titanium rails
  • Seatpost: RockShox Reverb Stealth, 31.6mm, zero offset
  • Handlebar: Bontrager Rhythm Pro Carbon, 31.8mm, 15mm rise
  • Stem: Bontrager Rhythm Pro, 31.8mm, 0 degree
  • Headset: FSA NO.57E, E2, sealed bearings
  • Brakeset: Avid X0 Trail hydraulic disc
Key Features & Upgrades
  • Redesigned light, tough frame is 650b and enduro optimized
  • ABP keeps your suspension active while you’re on the brakes
  • DRCV shock gives you smooth, predictable all-terrain control
  • Mino Link adjustable geometry lets you fine tune your ride
  • Fox Factory fork w/Kashima coat
  • Bontrager Rhythm Comp TLR wheels
  • SRAM X0/X1 1×11 drivetrain
  • Avid X0 Trail brakes
  • Bontrager Rhythm Pro handlebar
Specifications
  • Front Suspension: Fox Evolution Series 34 Talas w/CTD (climb-trail-descend) damper, rebound, E2 tapered steerer, 15QR thru axle, adjustable 130mm/160mm travel
  • Rear Suspension: Fox Evolution Series Float w/DRCV, CTD (climb-trail-descend) damper, rebound, tuned by Trek in California, 8.25×2.375”
  • Color: Trek Charcoal/Black Titanite
  • Shifters: Shimano SLX, 10 speed
  • Front Derailleur: SRAM X7, high direct mount
  • Rear Derailleur: Shimano Deore XT Shadow Plus CASSETTE Shimano HG62 11-36, 10 speed
  • Crank: Race Face Ride w/Turbine outer ring, 36/22 wHEELS Bontrager sealed cartridge bearing hubs, 15mm alloy axle front, 142×12 rear w/Bontrager Duster 28-hole Tubeless Ready rims
  • Tires: Bontrager XR4 Expert, aramid bead, 27.5×2.35”
  • Saddle: Bontrager Evoke 2, chromoly rails
  • Handlebar: Bontrager Rhythm Elite, 31.8mm, 15mm rise
  • Stem: Bontrager Rhythm Comp, 31.8mm, 0 degree
  • Brakeset: Shimano Deore XT hydraulic disc
  • Fox Evolution fork w/CTD & travel adjust
  • Race Face Ride crank
  • Shimano SLX/XT Shadow Plus drivetrain
  • Shimano XT brakes
  • RockShox Reverb Stealth dropper post
Specifications
  • Front Supsension: RockShox Pike RC w/Solo Air, 35mm stanchions, rebound, adjustable low speed compression damping, E2 tapered steerer, 15mm Maxle Lite, 160mm travel
  • Color: Trek White/Trek Black
  • Shifters: SRAM X7, 10 speed
  • Rear Derailleur: SRAM X9, Type 2
  • Cassette: SRAM PG-1030 11-36, 10 speed
  • CRAnK SRAM S1200, 36/22 w/bash guard
  • Wheels: Bontrager sealed cartridge bearing hubs, 15mm alloy axle front, 142×12 rear w/Bontrager Duster 28-hole Tubeless Ready rims
  • Seatpost: Bontrager Rhythm Elite, 31.6mm, zero offset
  • Brakeset: Avid Elixir 5 hydraulic disc
Key Features
Continue reading for the Official Press Release.
Wordpress Comments:
