Yeti joins the fray with their announcement of two 27.5 bikes, the SB75 and the 575.
We've spent a lot of time on the Yeti SB95 and the Yeti SB66 and have grown to appreciate this elegant suspension design. The SB95 is a capable beast with tons of traction and rock eating ability. The SB66 is a playful machine as it's easy to throw around into corners and in mid-air. Our favorite is clearly the SB95 as it made us safe and confident in unknown terrain. After the big wheels, getting on the SB66 seemed a bit more sketchy in loose terrain. It didn't help us out as much on sandy corners and rock-strewn descents.
So here is the long awaited 27.5" entry by Yeti called the SB75. The '7' stands for the 27.5 inch wheels and the '5' is for 5 inches of travel. It is the happy medium wheel size but we are certain it will replace the SB66, as many other brands have phased out their 26er.
Yeti SB75 Features:
The Yeti 575 also gets the new wheel size in the more traditional suspension design Yeti has used for several years. This new wheel size replaces the 26 inch wheels found in previous 575 models. Travel is at 140mm and the 575 gets ISCG 05 tabs and a PressFit 30 bottom bracket for 2014.
Yeti 575 Features:
We were hoping for a burlier SB model like an SB76 with 6 inches or more of travel. But for now, we'll just stick huge tires on this bad boy (like the Hutchinson Cougar 2.4s) and rally.
Yeti SB75 Features:
- Wheel size: 27.5"
- Rear travel: 130mm
- Internal cable routing on rear triangle
- Direct mount front derailleur
- Tapered inset headtube
- Sealed eccentric suspension system
- Aluminum frame - Carbon is likely to follow next year
- Colors: Turquoise, Black, Yellow
- Switch suspension design found in the SB95 and SB66
- 67 degree head angle
- October Availability
- SB75 MSRP: $2000
Yeti 575 Features:
- Rear travel: 146mm
- Wheel size: 27.5"
- Aluminum frame
- PF-30 Bottom bracket
- 69 degree head angle
- 575 MSRP: $1700
