Review: Bontrager Ion 700
Lights Lights Shootout
At Eurobike this year, Michael Browne from Bontrager said “I have a cool light for you!” I said, “Send it over and we’ll check it out,” with polite skepticism. After all, Bontrager has never made a bike light before and this is a very crowded field.
Well, I’ve used the light for a month now and color me impressed. Just like with many new Bontrager products, they did their research with this one and they’re offering a competitive advantage in this market. And what’s special about it are two things, price and form factor.
Brightness and Form Factor
It is a tiny light that is manufactured to the highest standards. It is bright light in a tiny package. It’ll fit on your bars, your helmet or in your pocket.
Price
The price is $100 and that trumps all of the competition. Measured Lumens for the Ion 700 is 661 Lumens The closest competitors are:
Niterider Lumina 700 – $140 for 692 measured Lumens
Serfas True 750 – $160 for 773 measured Lumens
Light and Motion Urban 700 – $160 for 708 measured Lumens
So as you can see, the Ion 700 has some very good competitors that have been doing this for a while. But with its price and form factor, it’s got something to offer to consumers.
Heat and Temperature
The Ion 700 does not have a lot of heatsinking and it does not step down in brightness as it gets hot. The LED is allowed to dim itself if there is not a lot of moving air. Thus this light can get quite hot and it becomes less efficient in warm temperatures without a lot of moving air.
It’s fine for normal use, but there’s better options in areas in warm climates and conditions where the rider is stopping a lot.
Specifications
  • Price: $100
  • Claimed Lumens: 700 Lumens
  • Measured Lumens: 661 Lumens
  • Measured MTBR Lux: 68 Lux
  • Lumens per $: 6.61 Lumens
  • Lumens per gram: 5.51 Lumens
  • Time on High: 1:45 Hours claimed
  • Charge Time: 5 Hours
  • Mounted Weight: 141 grams
  • Category: Flashlight
Strengths
  • Construction and beam quality are top-notch
  • $100 price point bests the competition in the 700 Lumen category
  • Side lighting is just perfect as it aids commuters but doesn’t get in the way of mountain bikers
  • Size and weight are smallest in this category
Weaknesses
  • The light can get hot as there is not a lot of heatsinking
  • Not quite up to 700 Lumen claims (but within LED bin error range)
  • Run time of 1:45 is optimistic since light is allowed to go down to 10% of initial brightness
  • Mount is not very sophisticated and no helmet mount is included
Video: Bontrager Ion 700 is compared to other 700 lumen lights
Mounting
Mounting is done with a small rubber mount with a hook strap with one length. This strap is built to accommodate all handlebar diameter by stretching. We tested it with a 31.8 bar and it worked fine. It is adjustable for smaller diameter bars by unscrewing a tension screw and adjusting the rubber strap. The light can be aimed left to right with a ratcheting swivel with fairly big degrees of adjustment. The tightness of the swivel can be adjusted by a retention screw.
Charging is performed with a micro USB port at the bottom of the light.
Mtbr Light Meter Measurements
This light measured 68 Lux on our ambient light measurement facility. The light output measurement is performed by placing a Lux light meter beside the light. Both are pointed at the ceiling (five feet above) of a dark room. This measurement uses the ambient light produced by the bike light.
Integrating Sphere Measured Lumens
This light measured 661 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 700 Lumens. The Lumen-hour graph below shows how the light performs over the first three minutes of its battery cycle.
Compare all Lumen Tests here »
Beam Pattern Photo
We photographed the lights in the same location setting with the same camera settings. The photos were taken in the back yard that is approximately 25 yards long. These photos feature many objects and a distinct background to analyze detail and beam pattern.
Compare all Beam Patterns here »
Bottom Line
If you can find this light, buy it. Buy two or three and set up one or two on the bars and one on the helmet. It is well-engineered and at $100 it is an amazing value.
For more information visit bontrager.com.
Return to 2014 Bike Lights Shootout Main Page »
Related Links
2014 Tunnel Beam Pattern Comparisons »
2014 Mtbr Lumen Tests »
2013 Bike Lights Shootout »
2012 Bike Lights Shootout »
Mtbr Lights Reviews »
Mtbr Lights Forum »
Do you own the Bontrager Ion 700? Help us become a better resource and write a review!
Wordpress Comments:
  • Angry Endruu says:
    Bring this light to germany !
    All the lights ins this shoot out test are forbidden in germany to use it on streets and you can´t buy it in german online and offline bike shops.
    I´m so sad ….
  • Mr. I says:
    I have a Kali helmet with a GoPro like attachment. Can this light work with this attachment style? If not, any other suggestions?
  • Francis Cebedo says:
    This is what you need. http://www.amazon.com/Light-Motion-Helmet-Mount-Stella/dp/B001I261L6
  • duder says:
    Cygolite 680 trumps this.
  • TLS HOU says:
    Need down load to my MAC for the Operators Manual for the ION 700, have acrobat reader and it still does not download from the official Boater manual site. Please help!!
  • UTExpat says:
    While the beam is adequate, specs say 3 hour run time at 450 lumens, 1.75 run time at 700 lumens. My commute is generally about 1.5 hours each way and I run it at 450, so I have not pushed the envelope until a couple of Saturday recreational rides within the past month. On BOTH rides, I set the light to 450 and the red warning light illuminated at 1.75 hours. In other words, battery life is nowhere near what was claimed. Additionally, no matter how much I torque the screw in the mount, rough roads will cause the aim angle to move either up or down. It goes up on my Secteur and down on my Cannondale. I believe both are 31.8 bars. As I read reviews online, I wonder if the reviewer actually used the light in any real world sense.
  • Larry says:
    Please note that the manual says “WARNING: Battery can overheat. After battery is fully charged, do not leave light plugged to power source”. I was told that was mostly to keep the lawyers happy.
