The CamelBak Volt 13 LR hydration pack is extremely comfortable, light and conformable, and features their new 100 oz Antidote lumbar reservoir, which resides at the bottom of the pack. The lumbar (LR) design places the water low on the hips and back for stability and comfort, and it conforms to the shape and oddities of your body for a great fit.
The Volt 13 LR weighs 700 grams (pack and reservoir), and has softly padded back, hip, and shoulders, and is constructed with their Ultra-light materials, using a combination of ripstop and stretchy nylon. The wraparound body uses their LV back panel, and Ultra-light 3-D Mesh Independent Suspension with Slider Sternum Strap. It has a 10 liter storage capacity with excellent organizational pockets, and comes in two colors, Pirate Black/Graphite and Brick/Dove, and retails for $125.
Features
The upper portion of the pack has a long and narrow zippered main compartment, which opens in clam shell style for easy access. It has three meshed organizational pockets, one large and two smaller ones, and the larger one has a Velcro closure tab. On the front is a smaller zippered compartment, with two meshed pockets and a key clip. Between the front and main compartments is a storage sleeve with stretchy side panels that expands to accommodate bulkier items, including apparel and armor. All the pockets and compartments combine together to give 600 cu in or 10L of storage space, although the middle sleeve adds quite a bit of additional volume. It has two upper compression straps for cinching down the load, and helmet strap hooks located on either side for attaching your helmet for carrying.
The padded hip belt uses 1-inch webbing with a front clip, and has zippered cargo pockets on each side. In addition, the pack is equipped with lumbar compression straps (orange pull tabs), which draws the bottom of the pack into the back as the reservoir's water volume decreases, keeping things stabilized, with the weight in tight to the body. The 100 oz. or 3L Antidote reservoir with the Quick Link connector, sits in a zippered pouch at the lower back, slightly wrapping backwards around the hips.
Antidote Lumbar Reservoir
The new larger 100 oz/3 liter Antidote lumbar reservoir has a trapezoidal shape and sits down low on the back instead of the traditional vertical layout along the spine. The bite valve worked quite nicely, and was easy to draw, and didn't leak. The screw cap for the fill port takes only a quarter turn to open or close, and it does not get stuck and require brute force to open. Just line up the arrow on the cap with the circle icon 'O' (with arrows pointing in tightening direction), and turn it a quarter turn clockwise until it lines up with the solid circle icon by the top hanging hook. It only takes a light touch to close the cap, and its water tight and snug.
The fill port has a wider diameter hole for easier filling, cleaning and drying, and has a handle which hooks onto the drop slot of the packs zippered pouch, helping to keep it stable and secure, and makes it handier to hold onto the reservoir. They added an auto shutoff quick disconnect, named the Quick Link, which allows you to disconnect the reservoir from the drink hose, which facilitates cleaning, filling and drying.
Impressions
The Volt 13 LR carries over most of its design from the excellent Charge 10 LR, and has added some great new features, yet has still retained the functional low lumbar weight carrying and stability characteristics of its brethren. The Volt 13 LR gets the bigger 100 oz reservoir, larger hip pockets, a front pocket and an overall increased storage capacity. The lumbar design pulls the weight off the shoulders, and moves it onto the lumbar and lower back and hips, offering increased stability and weight carrying characteristics, and draws the center of gravity in close to the torso.
The LV back panel uses their 'integrated ventilated system', and it's soft and conformable, and offers good comfort and ventilation, though with everything squished up against the lumbar, it can get damp in that particular spot. The bottom of the pack rolls around your hips and feels like a favorite comfy pillow. The hip belt and back panel were nicely padded, and highly flexible, so it conformed extremely well to the contours of your back, and it carried the weight in a balanced manner. The shoulder straps were minimally padded, and I found them decently comfortable as long as you kept the load to a reasonable weight. The pack itself is light, and I never felt the weight, even with the full three liters of water and the additional gear being carried, though when the reservoir is completely full, it pushes slightly on your back. By having the weight of the water pulled down into your lumbar and not on your shoulders, along with the rest of the gear being snuggled tightly into the back; the pack seems to disappear, while offering excellent stability. The conformability and stability of the design mean the packs doesn't flop around on rough terrain, and mostly stays put. I did notice that it lifted upwards on occasion and bounced around a bit more on extremely rough terrain and drop offs, especially in direct comparison to the Charge 10 LR, the latter having a Velcroed in place characteristic.
The pack has their nifty helmet hook, which allows you to snag your helmet straps onto a small clip to carry your helmet when it's not being worn. I did find that something the helmet straps would pop up out of the hook if the helmet got pushed upwards or got bounced hard. The lumbar compression straps, which are located on each side of the hips, are hidden inside the wings, and help pull the bottom of the pack into the back when the extra girth of the used up water reservoir shrinks during usage. It keeps the pack, load and weight stable and centered on the back, and can be done on the fly. Although its primary use is for the reservoir, it can also be used to trim and alter the way the pack sits on your back, giving one micro tuning customizations.
The main compartment had a nice long zipper, which opened along most of the pack's length, allowing efficient access to everything without having to dig around for hidden items. The three mesh pockets in the main compartments are located at the bottom of the pack for stability and to keep the weight on the hips. They offered effective organizing for tools, parts, and other sundry items, and the small Velcro closing tab on the inner one kept things in place. The pump holder sat up higher in the pack above the pockets, and worked nicely to keep the pump secure and out of the way. The hip belt's two cargo pockets are quite roomy, and I really liked the increased volume compared to the Charge 10 LR, and I used them for my cell phone, camera, tools, and keys. The middle sleeve pocket was excellent for overflow storage, and the stretchy material on its side allowed a jacket or armor to be placed in it.
The Antidote lumbar reservoir system worked extremely well, and the new screw closure only takes a quarter turn to open and close, and the wide mount is easy to pour into and clean. The larger 100 oz capacity was nice to have, as it made longer rides tolerable without having to resort to carrying an extra water bottle. To remove the reservoir, unzip the rear compartment, pull it out and unclip the tube. You can fill the reservoir back up, clip the tube, push the tails into the hip belt, and then hook it back on and zip it shut.
Although the pack has been moderately robust, you need to be careful since its made from lightweight fabric. I tore a hip pocket to shreds when I snagged a tree branch when I was dive bombing down a trail, and another hip pocket has some worn areas from scarping against rocks. Every other section of the pack hasn't shown any signs of wear, and I tend to abuse stuff to death, so I might be an anomaly.
Measured Specs:
- Pack Weight (no reservoir) - 518 grams / 18.3 oz
- Antidote Reservoir (with hose) - 182 grams / 6.4 oz
- Total Weight - 700 grams / 24.7 oz
Bottom Line
The CamelBak Volt 13 LR is a great pack, and synergy of the lumbar design, low slung reservoir, conformable back panel and hip belt, and functional suspension system makes for a very stable and comfortable entity. The pack adheres to your back, and it carries the weight centered properly on your hips and lumbar. It seems to all but disappears and stays in place, although on some drop-offs and rougher terrain, it does get some lift and bounces around. The lumbar compression straps helped pull the bottom of the pack into the back when the reservoir started to shrink in size, and it was useful for doing customized load and fit trimming. Besides the great load carrying and stability characteristics, the pack had some other excellent features, including helmet hooks, the main compartments clam shell opening and mesh pockets, the roomy side cargo pockets, and the stretchy middle overflow sleeve. Pockets galore! The new larger 100 oz (3 L) of water can get you through most rides, and the 10L (600 cu in) of storage space is adequate for most adventures, especially when adding in the middle sleeve, though it doesn't carry heavy loads that well. It's made from lightweight materials, so you do need to be careful with its lower level of robustness.
The Volt 13 LR's innovative design, lightweight materials, soft padding, and its highly flexible nature, create a plush and comfortable pack, and it becomes one with the back, and has enough water and storage space for most rides.
Strengths
- Antidote lumbar reservoir
- Comfortable, conformable and nicely padded
- Weight and pack disappear
- Main compartment clam shell opening
- Large hip pockets
- Lumbar compression straps
- Middle overflow sleeve
Weaknesses
- Lightweight material isn't the most robust (hip cargo pockets take the most abuse)
- Back can get sweaty
- Doesn't carry heavy loads well
- Pack can bounce around and lift up on drop-offs and rougher terrain
Overall Rating: 4.5 Flamin' Chili Peppers
Do you have the Camelbak Volt 13 LR? Help up become a better resource and write a review on the product.
