Review: Gemini Lights Xera 950
Lights Lights Shootout
The Gemini Xera is interesting. Although it looks like it has Magicshine roots, Chris Lai and his friendly Canadian crew have worked hard to innovate and spec some good lights in the Gemini line. The Xera has a nice, tiny light head and it puts out a good amount of light. It’s ideal for the helmet use with a Duo or Olympia on the bar.
This year, the Xera has a 100 Lumen bump from last year and that is typical of the upgrade in the whole Gemini line up. Unfortunately like last year, it comes up about a 150 Lumens short of its 950 Lumen claims.
But it’s a light with a very nice form factor and it’s got some nice features to boot.
Specifications
  • Price: $190
  • Claimed Lumens: 950 Lumens
  • Measured Lumens: 789 Lumens
  • Measured MTBR Lux: 80 Lux
  • Lumens per $: 4.15 Lumens
  • Lumens per gram: 3.81 Lumens
  • Time on High: 2:00 Hours
  • Charge Time: 2:00 Hours
  • Mounted Weight: 207 grams
  • Category: High End
Strengths
  • Excellent construction
  • Clean beam pattern
  • Diminutive light head only weighs 56 grams so it makes a great helmet light
  • Good value light
  • Flexibility with battery options
Weaknesses
  • 789 measured lumens is lower than 950 claimed
  • Beam pattern is a little narrow
  • Green switch light is always on
Mounting
This is the standard rubber strap style a few different sized bands include. Helmet mount comes with pipe attachments that can be mounted near the front of the helmet to mate with the rubber strap. This can be aimed left to right.
Mtbr Light Meter Measurements
This light measured 80 Lux on our ambient light measurement facility. The light output measurement is performed by placing a Lux light meter beside the light. Both are pointed at the ceiling (five feet above) of a dark room. This measurement uses the ambient light produced by the bike light.
Integrating Sphere Measured Lumens
This light measured 789 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 950 Lumens. The Lumen-hour graph below shows how the light performs over the first three minutes of its battery cycle.
Compare all Lumen Tests here »
Tunnel Beam Pattern Photo
The location is useful since it has walls and a ceiling that can display a bike light beam pattern. The walls have a lot of graffiti on them and actually show detail when they are lit up by a light with a wide angle. Cones and targets are set up with the far target set up at 120 feet.
Compare all Tunnel Beam Patterns here »
For more information visit gemini-lights.com.
Review: Gemini Lights Xera 950 Gallery
of
Gemini Xera 950
Gemini Xera 950
Gemini Xera 950
Gemini Xera 950
Gemini Xera 950 Head Weight
Gemini Xera 950 Mounted Weight
Gemini Xera 950 Box Contents
Gemini Xera 950 Box
Gemini Xera 950 - 2014 Mtbr Tunnel Test
Gemini Xera 950 Lumen-Hour Graph
Return to 2014 Bike Lights Shootout Main Page »
Related Links
2014 Tunnel Beam Pattern Comparisons »
2014 Mtbr Lumen Tests »
2013 Bike Lights Shootout »
2012 Bike Lights Shootout »
Mtbr Lights Reviews »
Mtbr Lights Forum »
Do you own the Gemini Lights Xera 950? Help us become a better resource and write a review!
(Visited 2,651 times, 1 visits today)
