This is the first light we've tested from Knog. It's more of a budget light at $65, putting out 184 Lumens. These lights were designed with quality and style. This light is quite small and it has the look and feel of a quality product, as rubber and metal are molded together to create a very slick device. A metal front for heat dissipation is integrated with a rubberized back for good grip and ergonomics.
The USB charging port for example, is a small plug that folds out of the light. This makes it very convenient for plugging into a laptop, as no wires are needed. When plugging into a USB adapter, an optional wire is included in case there are space issues near the plug. The integrated USB plug was designed by Knog to withstand moisture.
Beam Pattern Photo
We photographed the lights in the same location setting with the same camera settings. The photos were taken in the back yard that is approximately 25 yards long. These photos feature many objects and a distinct background to analyze detail and beam pattern. Compare all Beam Patterns here »
Integrating Sphere Measured Lumens
This light measured 184 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 170 Lumens. The Lumen-hour graph below shows how the light performs over the first three minutes of its battery cycle. Compare all Lumen Tests here »
Strengths
- Excellent materials and construction
- Honest Lumen output
- Good switch
- Handy mounting clasp and charging plug
Weaknesses
- There's brighter lights now at this price
- This brightness level is barely useable, so it's better to get the next light on the Knog line
Specifications
- Price: $65
- Claimed Lumens: 170 Lumens
- Measured Lumens: 184 Lumens
- Lumens per $: 2.83 Lumens
- Lumens per gram: 1.84 Lumens
- Time on High: 1:25 Hours
- Charge Time: 4:00 Hours
- Mounted Weight: 100 grams
- Category: Commuter
Overall Rating
For more information visit usd.knog.com.au.
This article is part of Mtbr and RoadBikeReview's 2015 Lights Shootout. To see all the bike lights tested CLICK HERE.
