Review: Lezyne Super Drive XL
Lights Lights Shootout
The Super Drive XL is a stubby little LED light that puts out 589 Lumens for $120. It has a nice bar mount, improved from last year and it can be mounted on the bar or the helmet.
This has the ‘infinite’ battery which is field replaceable, so the rider can keep replacing the battery to extend run time.
The light output Lumen graph is flat throughout its battery cycle. That is what it’s designed for, if you want a light that will deliver its promised output throughout the battery run time, in all kinds of inclement conditions and hot weather.
Note that when you turn the light on, you will not get the 575 Lumens as advertised in the box. You have to go through a special sequence (pressing the button for 6 seconds) to go in to the special overdrive mode. It’s not difficult to enter this mode, but we are fairly certain many users will never realize that they are not in 575 Lumen mode by default. But a good feature is the light will remember what mode you were in last time and it will keep it there.
Specifications
  • Price: $120
  • Claimed Lumens: 575 Lumens
  • Measured Lumens: 589 Lumens
  • Measured MTBR Lux: 52 Lux
  • Lumens per $: 4.91 Lumens
  • Lumens per gram: 4.27 Lumens
  • Time on High: 1:30 Hours
  • Charge Time: 3:00/4:00 Hours (Hidden overdrive mode, can sense high powered usb charger)
  • Mounted Weight: 138 grams
  • Category: Flashlight/Commuter
Strengths
  • Honest lumen rating at 575 Lumens
  • Lumens over time graph is as flat as it gets. That means you get the same about the same amount of light throughout the run time.
  • Good to have kit option
  • Good beam pattern with side visibility
  • Field replaceable battery extends run time
Weaknesses
  • Light got a quite a bit fatter than last year
  • Having the claimed output level in a hidden Overdrive mode is not ideal since it will be missed by many
  • Rear battery cover is easy to cross-thread and a bit difficult to screw in
  • Switch is very stiff
  • Having a high-powered lithium battery bouncing around your bag or pocket can be unsafe
Mounting
Mounting is the same as last year with the two sizes of plastic mounts for the two diameters of handlebars. It works but is a bit of a pain to keep together and tighten properly.
Mtbr Light Meter Measurements
This light measured 52 Lux on our ambient light measurement facility. The light output measurement is performed by placing a Lux light meter beside the light. Both are pointed at the ceiling (five feet above) of a dark room. This measurement uses the ambient light produced by the bike light.
Integrating Sphere Measured Lumens
This light measured 589 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 575 Lumens. The Lumen-hour graph below shows how the light performs over the first three minutes of its battery cycle.
Compare all Lumen Tests here »
Tunnel Beam Pattern Photo
The location is useful since it has walls and a ceiling that can display a bike light beam pattern. The walls have a lot of graffiti on them and actually show detail when they are lit up by a light with a wide angle. Cones and targets are set up with the far target set up at 120 feet.
Compare all Tunnel Beam Patterns here »
For more information visit www.lezyne.com.
Return to 2014 Bike Lights Shootout Main Page »
Related Links
2014 Tunnel Beam Pattern Comparisons »
2014 Mtbr Lumen Tests »
2013 Bike Lights Shootout »
2012 Bike Lights Shootout »
Mtbr Lights Reviews »
Mtbr Lights Forum »
Do you own the Lezyne Super Drive XL? Help us become a better resource and write a review!
