Review: Morsa Cycling Mount
Holds several devices, saving space on handlebars
Gear
The Morsa mount is shown with a light.
The Morsa mount is shown with a light and Garmin GPS attached (click to enlarge).
The Lowdown: Morsa Cycling Mount
Jeff Bobbitt wanted to use his extensive automotive engineering experience to design a better bike mount. What he came up with is an ingenious system that is modular and versatile. It can hold several devices, saving space on the handlebar.
Stat Box
Mount: Up to 2 devices on 1 mounting arm Material: Carbon composite nylon
Mount position: Out-front or behind the bars Mounting holes: Reinforced
Device position: Multiple positions Weight: 28g (mounting arm); 10+g attachments
Objective: Free up bar space MSRP: Mounting arm $20, plus $10 per attachment
Features: Strong, light and shock absorbing Rating: 5 Flamin' Chili Peppers 5 Chilis-out-of-5
Fit: 31.8mm diameter bars
Pluses
Minuses
  • Versatile with various setups
  • Use of torque wrench technical for some users
  • Mount is secure and sturdy
  • Versatile but limited market
  • Reinforced plastic absorbs vibration, doesn’t cut plastic device mounts
  • Bar mount is hinged and easily opens for install
  • Affordable and modular
  • Construction and hardware is top-notch
  • Designed and made in USA
Full Review: Morsa Cycling Mount
Are you short on handlebar space, specifically in the coveted center spot? Do you wish you had a cleaner mounting system or a more modular one for all your devices? This 54g one-armed carbon reinforced nylon mount can hold pretty much all common devices — and do it securely.
The mounting bolt comes with a precision machined washer.
The mounting bolt comes with a precision machined washer (click to enlarge).
What’s cool about this mount is it’s modular. You buy an arm where you can hang attachments and you can decide exactly where to locate the devices. The arm costs $20, attachments are $10 each. The mount is designed to hold two devices securely, but given the right devices that are not too heavy, we were able to hang three.
The Morsa mount with a light, camera and Garmin.
The Morsa mount with a light, camera and Garmin. The mount is not really designed to carry three devices but since it’s so sturdy and capable, we had to try it (click to enlarge).
The design and construction is awesome. Attachments can be hung on either side and they can slide forward and backward for optimum position. Some attachments can tilt up and down and some are secured by an oval connector so it can’t rotate. The nylon is reinforced with carbon for strength, and the bolt interfaces are reinforced with shaped washers and embedded nuts.
The Morza mount is here with the Gopro.
The Morza mount is here with the Gopro (click to enlarge).
All the mounts can be rotated for the optimum angle for viewing, lighting or video recording. There is a bevy of options available for mounting a device from the left, right bottom or top.
Continue to page 2 for more on the Morsa mount and a photo gallery »
