Review: NiteRider Lumina Micro 220
Lights Lights Shootout
There’s the Lumina 550 and next in line is the smaller sibling, the Micro 220. It shares the same chassis design but in a small stubby package. It’s a cool light for $70 and it measures at 240 Lumens, so it’s a great commuter light.
Mounting was improved with a clamp that is tightened with a hand lever. This ensures a proper hold on the bar for those high-speed, rocky descents. The USB charging port is now moved to the bottom of the light with a better seal. This protects it from moisture and dirt much better.
The real story here is the Lumina family of lights has expanded for more options.  And it’s not just a bunch of weaker versions of the light in the same case. They actually put some thought and engineering in the other versions. They are as follows:
NiteRider Lumina Micro 220 – $70 micro light with 240 measured Lumens
NiteRider Lumina 550 - $110 light with 558 Lumens
NiteRider Lumina Flare 650 – $170 light with integrated tail light making it ideal for helmet mounted commuting
NiteRider Lumina 700 – $140 with 692 measured Lumens
Specifications
  • Price: $70
  • Claimed Lumens: 220 Lumens
  • Measured Lumens: 240 Lumens
  • Measured MTBR Lux: 25 Lux
  • Lumens per $: 3.43 Lumens
  • Lumens per gram: 1.90 Lumens
  • Time on High: 1:30 Hours
  • Charge Time: 3:30 Hours
  • Mounted Weight: 126 grams
  • Category: Flashlight/Commuter
Strengths
  • Actual output of 240 is more than 220 claimed Lumens
  • Excellent design and clamp
  • Good value for the money
  • Mount is easily removed and can be used as a great flashlight
  • Great form factor and packaging
  • Beam pattern has been cleaned up with a nice trapezoidal shape that is flatter on top and shines more light at the bottom
Weaknesses
  • Run time could be better and should be at least 2 hours
Mounting
Instead of the snap on strap, the Lumina Micro 220 now has a mount that is a c-clamp type and is tightened with a hand adjustable screw. This allows a secure connection to keep it from moving out of place during rocky descents. Standard helmet mount is included.
Mtbr Light Meter Measurements
This light measured 25 Lux on our ambient light measurement facility. The light output measurement is performed by placing a Lux light meter beside the light. Both are pointed at the ceiling (five feet above) of a dark room. This measurement uses the ambient light produced by the bike light.
Integrating Sphere Measured Lumens
This light measured 240 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 220 Lumens. The Lumen-hour graph below shows how the light performs over the first three minutes of its battery cycle.
Compare all Lumen Tests here »
Tunnel Beam Pattern Photo
The location is useful since it has walls and a ceiling that can display a bike light beam pattern. The walls have a lot of graffiti on them and actually show detail when they are lit up by a light with a wide angle. Cones and targets are set up with the far target set up at 120 feet.
Compare all Tunnel Beam Patterns here »
For more information visit www.niterider.com.
Review: NiteRider Lumina Micro 220 Gallery
of
NiteRider Lumina Micro 220 Box
NiteRider Lumina Micro 220 - 2014 Mtbr Tunnel Test
NiterRider Lumina Micro 220 Lumen-Hour Graph
Return to 2014 Bike Lights Shootout Main Page »
Related Links
2014 Tunnel Beam Pattern Comparisons »
2014 Mtbr Lumen Tests »
2013 Bike Lights Shootout »
2012 Bike Lights Shootout »
Mtbr Lights Reviews »
Mtbr Lights Forum »
Do you own the NiteRider Lumina Micro 220? Help us become a better resource and write a review!
(Visited 2,477 times, 1 visits today)
