Review: Royal Racing Slice Jersey and Signature Shorts
Apparel
Royal Racing Signature Shorts – front and back, note waist system, side stash pocket, front zippered vents, front closures, and rear vents.
Signature Shorts
The shorts use a 2-way stretch nylon and spandex blend that has a DWR coating, and they have a baggy and loose cut, that comes down just below the knees. They did feel a bit tight and snugger just below the waist, but overall they have a decent fit. The material is slightly stiff and thick, which helps with durability, but lowers ventilation and breathability, so they can feel warm on hot days. The stretchy material helped with comfort, and gave the shorts some nice freedom of movement while pedaling and maneuvering around on the bike. The shorts have a small zippered waterproof stash pocket by the right hip, perfect for car remote, two-hand pockets and two zippered ventilation ports on the outer thigh. The stash pocket was rather small, and outside of some keys, a hey key or tool; it wasn’t that useful. Towards the back of the lower thigh was a permanent set of vent ports, which worked in concert with the zippered ones in front to get some air movement through the shorts. The front closure system uses a clasp and two snap buttons, and even though the buttons seemed fairly secure, I found that they liked to pop open, especially when maneuvering around on the bike or sticking your gut out. At least, the inner clasp kept them together, but I found their premature release very annoying. It uses a dual ‘hook and loop’ waist adjuster system, and although it was easy to adjust, the big plastic Velcro closures sometimes got caught on things, though they at least didn’t pop open.
The hanging inner chamois that comes with the shorts is cut sort of loose and baggy, and although they were comfortable and very breathable, they felt like your wearing a pair of diapers or drooping drawers. I ended up using another vendor’s chamois liner, that had a proper girdle like fit with good compression.
They come in Olive Green and Black, in S, M, L, XL and XXL and retail for $120.
Final Thoughts
The zippered side vents were handy, and they did let in some air, and it was most noticeable once you got up to speed. The shorts have a good loose cut, and they never felt constricting, and the just below the knee-length cut was ideal, and it worked well with armor. The material, stitching and construction were all rugged and tough, resulting in a very durable set of shorts. The strategically placed stretch panels made them very comfortable, and outside of the snaps popping open I didn’t have any issues with the fit. The Signature shorts are comfortable, have a decent long and baggy cut, and use tough durable material, but overall they’re hampered by poorly fitting chamois liner and front closure buttons that pop open much too easily.
Pros
  • Tough and durable
  • Comfortable and stretchy
  • Waist adjustment system
Cons
  • Sloppy and lose chamois liner
  • Stash pocket is too small
  • Front buttons can pop open
  • Can feel warm on hot days
Overall Rating
3.5 Flamin’ Chili Peppers
Update from the manufacturer: We saw the issues with the snaps very early and changed them over to different snaps since that first production.  All of our shorts now use a new more standard style snap that is much better than the ones on the first production shorts that you have.
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Mike says:
    Thanks for the review. I’m starting to look for more L/S jerseys now and always love RR stuff. Could you tell me what size Jersey your are wearing and how tall you are. I tend to like my jerseys more fitted as to not be a parachute in the wind. Thanks.
  • Mike says:
    Thanks for the response Brian. I picked one up. Cheers!
