The new SLX group is quite the bargain at $928, and the powerful brakes, durability, great gearing options and good shifting, make for an excellent package.
Last year, Shimano revamped the SLX group, and it got trickle down technology from the XT and XTR product lineups. SLX has always been about durability and good value, and the 2013 iteration raises the bar for performance and value, with a retail price of $928 for the group (sans rotors and hubs). The group gets a plethora of technical trickery and designs, including the Ice Tech brake pads and rotors, the Shadow Plus clutch on the rear derailleur, upgraded shifters and front derailleur and brakes, and 'Rider Tuned' cranks and cassettes. The gearing choices include a 2x of 38-24, 38-26 and 40-28, and 3x of 42-32-24, and three cassette options of 11-32, 11-34 and 11-36.
I have been using the SLX drivetrain and brakes for the past six months, and I have put it through its paces, tossing it in every type of terrain and harsh conditions, just this side of prodigious quantities of mud. It has been brutally tough, durable, has shifted admirable, and has some extremely powerful brakes. The group that I tested included the following components:
Weights
Front Derailleur
The front derailleur is available in four mounting options, High Direct Mount (tested), Low Direct Mount, High Clamp and Low Clamp for both 3x10 and 2x10 gearing, and retail for $55. They did some minor redesign of the derailleur, and altered the shape and profile, and tweaked the cable routing for better frame, suspension and tire clearance, making it 'suspension friendly'. The SLX front worked nicely, and rolled up and down smoothly, without any stickiness, slop or clunking, giving the usual Shimano front quality shifts.
Rear Derailleur
The rear derailleur is available in two cage lengths, the 2x10 specific SG medium (tested) and 3x10 specific SGS long, and in Shadow Plus (tested) and Non-Plus versions, and retail for $100 and $85 respectively. It can be used in a wide range of 10-speed gearing, with a maximum of a 36-tooth cassette capacity. The SLX gets the second generation of the innovative Shadow Plus, which uses a simple on/off lever to engage the friction clutch damper system, which prevents chain slap and derailment, and quiets and stabilizes the drivetrain. Shimano does offer a new 'Direct Mount' option, which lets you remove the B2 link and attach the derailleur directly to the Direct Mount arm of the frame, but this only works with a frame that was designed to accept this setup, and those are currently somewhat rare.
I liked the Shadow Plus system, and it makes a big difference in keeping everything stable and quiet, and when hammering along extremely rough terrain it's an obvious improvement, though the shifting is slightly stiffer when engaged. Even shifting under load, I never felt the rear give me any issues, regardless of how hard I torqued and slammed the system. The rear has performed pretty darn well, and always did what was asked of it, even when the chain wasn't well lubed, the tuning was slightly out of whack, and I shifted poorly. The rear has been very durable, and has taken a lot of abuse, getting slammed and scrapped against rock squeezes and ledges, and the only thing it has suffered is some mild cosmetic scratches. It might lack the precision of the XTR rear, but it's tough, cheap and seems to deal with 'out of tune' situations more ideally.
Continue reading for more information and full photo gallery.
Cranks
The cranks are available in a 2x10 version with 38-24 (tested), 38-26 and 40-28 gearing options, along with a 3x10 with 42-32-24. They come in 170 and 175mm arm lengths, with a normal bottom bracket (BB92 and BB30 adapter bearings available separately) and retail for $260. The cranks use hollow-forged aluminum arms, and the drive side has a reinforced 4-arm 64/104mm BCD spider and an integrated HollowTech-II spindle. The 2x version uses anodized aluminum outer and steel inner HG-X chainrings, while the 3x uses anodized aluminum outer, composite-reinforced steel middle and steel inner HG-X chainrings. Due to the spider design, you'll need to choose a 3x10 crankset if you want to do a 2x10 with a bashguard.
The tough and beefy cranks weigh just a bit more than the XT model, and use stamped pins and ramps, and aren't quite as sculptured as either XT and XTR. I never felt any flex from the arms, and the shifting was fine, though perhaps not quite as snappy smooth going from the smaller to larger chainrings as their more expensive brethren. The shiny and flat surface of the outer arms didn't show any shoe scuff marks, which was a welcome change, and the only scratches and dings were on the arm ends, due to repeated encounters with rocks. The 38-24 gearing ratio was about perfect for steep climbs, high cadence riders, 29ers aficionados and those who like an old-school granny setup, and it worked in harmony with the 11-36 cassette. Though not as pretty as the XTR and XT cranksets, they are decently light, tough, stiff, cheap and shift just fine, even under adverse conditions and heavy loads.
Cassette
The SLX cassettes are available in 11-36 (tested), 11-34 and 11-32 toothed options, and use stamped steel for the cogs, and retail for $85. The 11-36T setup has gears of 11-13-15-17-19-21-24-28-32-36, the 11-34T has 11-13-15-17-19-21-23-26-30-34, and the 11-32T has 11-12-14-16-18-20-22-25-28-32. The three largest rings are attached to a spider, and the next five are pinned together, while the last two inner ones are loose. The cassette has been very durable, and hasn't shown any signs of premature wear, even though I torqued and loaded them hard. They don't have the silky-smooth shift feel of XTR, but they did an admirable job. The 11-36 cassette worked ideally when combined with the 38-24 cranks, especially if you like a good granny, although you do miss the crankability at high speeds, which a 3x10 or a larger chainring would excel in. Though they aren't light at 372 grams for the 11-36, they make up for it in robustness, durability, and price.
Chain
Not much to say about the $45 chain, as it has been tough and durable, and has shifted adequately, even though I didn't lube it very often, and let it get immersed in rain and snow, and ground up with sand and dirt. The only oddity is that the chain is directional, and I initially installed it incorrectly the first time, and the front shifting wasn't nearly as crisp and smooth in direct comparison.
Shifters
The RapidFire-Plus shifters come in two versions, the normal clamp with removable optical gear displays (tested) and ISPEC integrated clamp, which attaches directly to brake body. The shifters comes as a front and rear pair, and includes housing and cables, and retail for $110. The front shifter has a switch on the bottom, that converts it to either a double 2x or triple 3x drivetrains, making it compatible for both systems. The ergonomic shifter's paddles have a 2-way release trigger for thumb or finger actuation of the Dyna-Sys specific cable-pull.
The shifters performed just fine during the entire test period, and the front had a tolerable throw when tossing it up a gear, while the rear has a nice crisp click, due greatly to their Advanced Light Action shifting design. The rear could downshift one gear at a time, while upward movement could be worked in one, two or three gear shifts at once, depending on how hard, and far you pushed the paddle. I do wish the normal clamp was hinged, as it would make swap-outs easier, but that is a minor nitpick in an otherwise great shifter. I removed the optical gear display immediately, since they seem sort of superfluous to me, but some may like the reinforcement of what gear they are in.
Brakes
The SLX brakes are comprised of the reservoir, and tool-free reach adjust lever with a hinged handlebar clamp, and two-piece machined caliper with oversized 22mm ceramic pistons, and IceTech pads with radiator cooling fins. They are available as a front with a 1000mm hydraulic hose or a rear with a 1200mm length, and retail for $140 each (rotors and adapters sold separately). The pre-bled system uses mineral oil, and comes with an additional olive and barb for shortening the tubing if required. I didn't use their fancy IceTech rotors, since they aren't available in a six bolt version for SLX, so I tested basic default steel ones.
They're immensely powerful with the 180/180 rotor combination that I tested, and no matter how long or steep the descent was; I never felt any loss of power or suffered brake fade. They did make a subdued steel on steel noise when cranked hard, but it never seemed to cause any performance issues. Although they have plenty of power, they could feel a bit grabby, and it was difficult to feather them for technical maneuvering. It was pretty simple to bring your speed down or come to a complete stop with a good pull on the brakes, though I would have liked better modulation. The power, ServoWave mechanism and ergonomics of the lever, made one-finger usage the norm, and the brakes gave great control and confidence in any terrain. I did shorten the brake lines, which was a pretty simple task, and fortunately; they didn't need a bleed.
Bottom Line
The 2013 SLX group has gotten a slew of technology from XT and XTR, giving the little brother of Shimano's mountain bike group better shifting and braking. For me, the surprise of the group was the powerful brakes, which offered great control and stopping power, with fade free use, even on the longest and steepest downhill runs. The Shadow Plus rear derailleur really does tame the chain slap and noise of the drive train, and it's a nice addition to the lineup. The 'Rider Tuned' cranks and cassettes offer a slew of gearing options, and I really enjoyed the 2x10 38-24 cranks with the 11-36 cassette, which greatly helped slogging up long steep climbs.
The new SLX group is quite the bargain at $928, and the powerful brakes, durability, great gearing options and good shifting, make for an excellent package. Compared to the XT and XTR groups, it's a bit heavier, isn't as sculptured and aesthetic pleasing, and doesn't have the exact precision and silky smoothness during shifting.
Pros
Cons
Overall Rating: 4 Flamin' Chili Peppers
Value Rating: 5 Flamin' Chili Peppers
Weights
- Cranks (2x10 38-24T 175mm) - 745 grams
- Bottom bracket - 88 grams
- Brakes - 602 grams
- Rotors (180mm) - 138 grams each
- Shifters - 295 grams
- Cassette (11-36) - 372 grams
- Front derailleur (High Direct) - 178 grams
- Rear derailleur (Shadow Plus) - 302 grams
- Chain - 279 grams
Front Derailleur
Rear Derailleur
Cranks
Cassette
Chain
Shifters
Brakes
Bottom Line
Pros
- Excellent value and price point - it's cheap!
- Powerful brakes
- Tough and durable
- Good shifting, especially under adverse conditions and heavy loads
Cons
- Heavy
- Not quite the exact precision and silky smooth shifting of XTR/XT
- Parts aren't as sculptured and aesthetic pleasing as XTR/XT
