Reynolds Interbike Booth
Interbike Sponsored post
Rob Aguero shows us how Reynolds has used their years of carbon fiber experience and technology and applied that to their 2103 mountain bike wheel line. New for 2013 is the 650b Carbon and Alloy, the 29er Carbon and Alloy and the 26″ AM carbon wheelsets with the Reynolds all mountain hub.
Visit the Reynolds Interbike Booth on RoadBikeReview here.
Reynolds Interbike Booth Gallery
of
Reynolds 650b Carbon
  • 1500g per set
  • Full MRS carbon tubeless rim
  • 29mm width
  • 21 mm Internal Channel
  • 6-bolt ISO rotor compatible
  • Double-butted stainless steel spoke, external nipples
  • Front 9mm QR, 15mm and 20mm thru axle
  • Rear 10mm QR, 135/10 and 142/12 thur axle
  • Tubeless ready
  • New Reynolds MTN, red, straight-pull hubset
  • Bold black-white-red Reynolds graphics
  • Reynolds MTN hub with interchangeable end-cap system
  • Rim tape, skewers and valve stem included
  • 1500g per set
  • 29mm width
  • Tubeless ready
Reynolds 650b Alloy
  • 1580g per set
  • 28h/3x front and rear
  • 24mm width
  • 21mm internal channel
  • New Reynolds designed, black, straight-pull subset
  • Tubeless ready
  • Stan's Notubes Bead Socket Technology (BST)
  • Rim tape
  • Hub with end-cap system
  • DT spokes
  • 6 bolt rotor compatibility
Reynolds 29er Carbon
The 29er carbon wheelset offers a combination of a wide rim (29 mm outside and 21 inside), a low spoke count (24 holes) and ultra-light spokes (DT-Revolution, 2 x laced). The inward leaning rim walls and radius help with bead locking, minimize pinch flatting, but they also structurally stiffen the rim. The wheels were designed with durability, strength and stiffness to accommodate almost any riding style. Wheels are tubeless compatible.
  • Full Carbon tubeless rim
  • 28 mm profile
  • Rim tape, end caps, skewers and valve stem included
  • 28mm Rim Depth
  • 2x Spoke Patterns
  • 1575g Weight
  • 6 Bolt ISO rotor compatible hubs
  • Rear 10mm QR, 135mm/10mm and 142mm/12mm thru axle with included axle caps
  • DT Revolution Front/Rear Spokes
Reynolds 29er Alloy
  • 1625g per set
  • 24mm width
  • New Reynolds designed, black, straight-pull hubset
  • Tubeless ready
  • Rim tape
  • DT spokes
Reynolds AM Carbon
Reynolds AM is a tubeless mountain wheel designed for maximum performance under the harshest treatment. However the AM is a little stouter, and slightly heavier. But fear not: the AM loves to climb, and manages to go uphill with nearly as much airy grace as it descends.
  • 26 mm profile
  • 3x Rear/ 3x Front 28 hole Spoke Patterns
  • 1590 weight
Reynolds Mountain Hub
New for 2013, our proprietary straight-pull hubs are 55g per set lighter than previous J-bend hubs, and they offer more points of engagement. We like the way they benefit wheel stiffness with a wider bracing angle of spokes. For maximum compatibility, we sell every wheel with a complete set of end cap options: for the front - quick release, 15mm thru axle, and 20mm thru axle. For the rear – quick release, 135 x 10 thru axle, and 142 x 12 thru axle.
Reynolds Niner Bike with Reynolds Wheels
Our goals for our Mountain Bike Wheels are as lofty as the peaks themselves: we demand high-performance wheels that are stiff, yet comfortable – tough fighters with precise acceleration. They must eat trail vibration, feel stable at all times, and enhance their rider’s cornering ability. By utilizing Reynolds’ proprietary carbon technology, the good engineers of the Reynolds Composite Studio have achieved these goals – and more – with the 2013 Mountain Line. We are proud to introduce the 2013 XC, AM, 29er and 650b.
Reynolds Mountain Wheels Pop Display Graphics
Reynolds Interbike Booth Inside
For over a century, the name Reynolds has stood for quality, design and performance in bicycle components, because we’re renowned for creating products that deliver a cycling experience unlike any other. The margin of victory has never been more acute—in competitive cycling or in business. Therefore, our passion for leadership drives us to continuously improve performance—in our products, our processes, and our customers. Whether you ride to live, or live to ride, you’ll experience a whole new level of performance and enjoyment on Reynolds wheels.
View from Reynolds Observation Deck "Champagne Room"
Wordpress Comments:
